Question about Eicon DIVA ISDN T/A (310153) Modem
I can install Diva adsl usb software on my computer when using XP. Now have new computer with Vista and can bno longer be installed.
    Master:
  • 425 Answers
Yes you can.. read this... Software Download Listing
Posted on Aug 18, 2014
2 Suggested Answers
SOURCE: ADSL Modem Huawei SmartAX MT841 USB driver not supporting Window Vista Name update of Vista
Hi!
Do not use the usb port or cable. use the RJ 45 port instead. and configure PPPoE and connect using UTP / STP cable with RJ 45 connector straight crimped.
Posted on Mar 01, 2009
I connected my diva x to my PC and it is not discovered, can't transfer or copy files
In Windows 7, it should recognize and install automatically. If you're still using XP or Vista, you're out of luck.
May 28, 2014 | Blu Zoey T176 Mobile Phone
Unable to check cartridge ink level on new computer.
i think the problem is on that software.pls check the software cd or DVd. if it is fully compatible with windows vista.
Jun 13, 2009 | HP OfficeJet 6310 All-in-One Printer...
Usb audio driver won't install from original cd
Installing USB sound card (any windows)
  1. Do not connect or plug the USB sound card
  2. install the software and driver
  3. restart the computer
  4. connect the USB Sound Card
  5. windows found new hardware
  6. select find hardware automatically.
  7. if windows cant find the driver select browse CD (contain driver)
i have 3 soundcard installed in my computer (XP Pro SP2,Vista Enterprise,Ubuntu Linux) 1 built in and 2 USB.
built in I use for speaker, 1 USB I used for monitor to my DJ mixing software, 1 USB I used for telephone(VOIP)
Apr 02, 2009 | Crosley Traveler Turntable
Cannot run Fujifilm Software for FinePix with Windows Vista
1) If you right-click on the executable file, can you use the
"Compatibility" TAB to run it as an XP program?
2) Many XP device drivers will fail to install or execute properly
under windows VISTA, and I suspect it is the camera's USB
or Fire-wire (IEEE-1394) based device driver that is causing
the problem, not the main application.
Unfortunately there is NO easy solution for this,
except to get an upgraded software package (for Vista)
from the Camera Manufacturer.
3) There are also two possible work-around(s), but both require
some knowledge and software installation:
DUAL-BOOT
Install both Windows XP and Windows Vista on your
computer using two separate hard-drive partitions, and
a boot manager.
A partitioning tool like "Norton Partition Magic", formerly
"Power Quest" or "Acronis Tools" can be used to partition
the hard-drive non-distructively (your data is preserved):
a) Resize (shrink) the existing Windows partition.
b) Create a new partition for Windows XP (about 10 Gigs)
c) Install Windows XP-Pro onto the new partition,
d) Add both the XP and Vista partitions to the BOOT.INI
file on the boot drive.
Both windows XP and Vista do have multi-boot capability,
but the Windows XP boot manager may not recognize Vista,
in which case you may have to re-install or re-pair the Vista
installation. The Vista boot manager will recognize WinXP.
Running VISTA is generally a bad idea, because it is obscenely
slow and inefficient compared to XP, and because it is infected
Microsof't draconian and arrogant copy protection schemes,
known as DRM = Digital Rights Management.
Towards this end, Vista also insists that all installed multi-media
devices must be "Recording Industry" compliant and approved,
to make music and movie piracy more difficult. Many media
copying programs and CD-rippers will also refuse to run,
by design.
All this "Added Technology" is stealing your money, your
computer resources, your performance, and your right to
backup your media, at your expense, for the benefit of
the movie industry Mafia.
Use Vista only when you have to, boot to Windows XP for
most of your applications.
VIRTUAL MACHINE
Both Microsoft and VM-ware (as well as others) make
a software product called a Virtual-PC, which allows you
to emulate multiple operating systems under windows,
including older windows, MAC and Linux.
VMWare is by far the best, the most reliable and the
most flexible, at about $200 US.
Martin
May 07, 2008 | Computers & Internet
Hp printer problems with vista
Hello, you will need to complete the add new hardware wizard, sometimes the drivers are corrupted and the wizard ends before all installation takes place (undertaker02 this is also for you) Do this:-Log on to your computer by using an administrator account.
2. Click Start, and then click Run.
3. In the Open box, type regedit, and then click OK.
4. Locate and click the following registry key:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Enum\LPTENUM
5. Right-click the registry key, and then click Delete.
6. Under Confirm Key Delete, click Yes.
7. Close Registry Editor, and then restart your computer.
When Windows XP restarts, it will detect the printer and install support for it. After the printer is installed, it will no longer be detected each time you start Windows XP.
Apr 28, 2008 | Microsoft Windows Vista Ultimate Edition
Internet connection for vista
unfortunately, there is nothing that you can copy and transfer from your XP based desktop. The best solution is to call your provider and ask them for a Vista driver update for your usb modem.
Hope this helps.
Apr 11, 2008 | Computers & Internet
Updated to windows vista any updates available for Eicon Diva 2440 adsl router
try the makers website,but i think this unit uses a usb connection ,this is never a good idea, vista has many problems and i have not doubt this is another one of its problems,as it does not suffer older equipment well.
good luck
Terry,
Mar 08, 2008 | Computers & Internet
Installing Windows XP alongside Vista
First you want to install xp and then only you want install vista because higher version will not take lower version.
Feb 26, 2008 | Microsoft Windows XP Professional for PC
Setting up linksys adsl2 modem
The ADSL, Ethernet, and USB ports are located at the back of a Linksys modem. These ports are where the phone cable and computer will be connected. The ADSL Line should be connected to the ADSL port and the computer either be connected to Ethernet or the USB port., If u r using a ethernet cable no need to run the setup cd just connect the ethernet cable and contact ur isp..
do not worry about ur sagem modem, let it be inside.. just connect ethernet cables alone..
To setup a Linksys ADSL Modem with usb cable you need to perform two steps:
  1. Connecting the Devices Together
  2. Installing the USB Driver
Step 1:
Connect the phone cable to the wall jack with ADSL service and then connect the other end to the ADSL port of the modem.
Step 2:
Make sure the power adapter is plugged to an available power outlet.
Step 3:
Connect the USB to the USB port on the back of the modem and then connect the other end top the USB port of the computer.
Step 4:
Power on the modem. After connecting the device together, install the USB driver. For instructions, follow the steps below.
Step 1:
Power on the computer.
Step 2:
When the Hardware Update Wizard window appears. Click Install the software automatically (Recommended).
NOTE: Windows XP has pre-installed drivers for the ADSL2MUE and will automatically install the USB driver for the modem.
Step 3:
Click Finish.
Nov 06, 2007 | Computers & Internet
Computers & Internet Logo
106 people viewed this question
Top Eicon Computers & Internet Experts
David Payne
David Payne
Are you an Eicon Computer and Internet Expert? Answer questions, earn points and help others
