Question about Dell 962 Photo All-In-One InkJet Printer
Dell AIO 962 printer faulty
Amber exclaimation (!) light flashing on front panel. Printer does not function - that is, will not print and will not photocopy. Scanning is working okay. LCD display has message "right cartridge incorrect". This refers to the colour cartridge which was replaced few weeks back and used infrequently since.
Any ideas?
  • 6 more comments
  • Anonymous Jan 13, 2008
    light on front blinks and says i am out of ink. Also file for operation corrupts and i have to delete and download over and over
  • dotann Jan 31, 2008
    The ! light beside the power on button is blinking, cannot make a copy and dhows Error 2200. Help!
  • Top Kat May 02, 2008
    The Dell printer displays a fault saying the right cartridge is in misalignment and it won't print or copy anything. This is as the other poster indicated a light flashing and the indication says that the right cartridge the Color cartridge is misaligned. When trying to align the cartridge through the maintenance program the indicator continues with the same message. And the printer doesn't work at all. All power and other functions appear normal. Any suggestions?
  • Anonymous May 28, 2008
    Exactly the same problem as above.
    Try everything, except to install another one. Since I don't want to spend more money in this printer. Anything else that I can do now?
    L.S
  • vamurphys Jun 02, 2008
    I ordered, received and installed new printer catridges from DELL on-line, for my AIO962 printer. I still get the error messages,
    "Right cartridge incorrect" and "Left cartridge incorrect"?
    Anybody know what to do?
  • Odai Basha Sep 28, 2008
    my dell photo AIO 962 is working but it says thatthe left cartridge is incorrectly inserted but im sure that it is inserted correctly.
    please help,
  • randys1 Feb 21, 2009
    I continually get the "right cartridge incorrect" message. This will not allow me to print, even in black only.........any suggestions, plenty of ink still in the color cartridge.
  • Anonymous Mar 28, 2009
    amber exclaimation mark lit; won't print
    Scholar:
  • 35 Answers
The error you are referring to could be related to either the cartridge or the printer, so please perform the steps below to check if the issue lies in the printer or the cartridge.
Power on the printer and open the top cove, the cartridges will align in the middle of the printer, remove both the cartridges form their slots and interchange them, yes put the Black cartridge in the Blue slot and the Color cartridge in the Black slot, then close the top cover of the printer and power off the printer and restart it, at this point of time check if the error message is changed or not if the error message is not changed and till showing the same as “Right cartridge is incorrect” then you can try to update the printer firmware form the Dell support site, here is how you can do it.
  1. Go to www.support.dell.com.
  2. Click on Drivers & Downloads.
  3. Under Option 2: Select a Product as printers.
  4. Locate the printer(s) 962 printer and click Go.
  5. Select an Operating System that is installed in your computer then choose downloads and look for Firmware.
  6. Download and install the firmware, then restart the computer and the printer, however please make sure that you do not restart your computer and the printer when the download and the installation is in progress.
If the issue is still not fixed after you upgraded the firmware then I believe that you will have to replace it. However if the error message changes to Left cartridge incorrect after you have interchanged the cartridges earlier then try these steps below.
  1. Remove the color cartridge and clean the metal contacts of the cartridge with a dry cloth thoroughly please make sure that you are using a soft dry cloth to clean the metal contacts of the cartridge.
  2. Make sure that the cartridge holder snap which sits on the top of the cartridge is fixed firmly.
  3. Make sure that you are using a Dell branded cartridge and it is not a refilled one cause Dell printers often give error message when you use a refilled cartridge or a cartridge of some other brand.
  4. If the issue is still not resolved replace the color cartridge.
Regards
Malik Khan
Posted on Jan 26, 2008
6ya staff
SOURCE:
When I try to scan or print a message comes up telling me to ck power and usb connections. I have unplugged and restarted computer 4 times and still have problem
It could be a communications error message, the printer is not communicating with the computer.
  • Disconnect and then reconnect the USB cable.
  • Disconnect and then reconnect the printer power cable.
  • Restart the computer.
  • Remove and reinstall the printer software
  • If your printer does not function properly or communication error messages appear when using your printer, you can remove and reinstall the printer software.
    1. Click Start®Programs or All Programs®Dell Printers®Dell Photo AIO Printer 962®Uninstall Dell Photo AIO Printer 962.
    2. Follow the instructions on the computer screen to remove the printer software.
    3. Restart your computer before installing the software again.
    4. Insert the Drivers and Utilities CD, and then follow the instructions on the computer screen to install the software.
    If the installation screen does not appear:
      1. In Windows XP, click Start®My Computer.
    In Windows 2000, double-click My Computer from your desktop.
      1. Double-click the CD-ROM drive icon. If necessary, double-click setup.exe.
      2. When the printer software installation screen appears, click Install or Install Now.
      3. Follow the instructions on your screen to complete the installation.
    Communications error message
    The printer is not communicating with the computer.
    Dec 06, 2010 | Dell 962 Photo All-In-One InkJet Printer
    Having problems downloading drivers for Dell 962
    I have a samsung notebook without a place to insert a disc and need to print files from my e-mail using a dell aio 962 printer how do I do this without using the software disc that came with the printer
    Jan 26, 2010 | Dell 962 Photo All-In-One InkJet Printer
    Cannot print over network on Dell AIO 962 using Dell 3300 wireless print adapter. Previously had no problem printing over the network, but for some reason my linksys WRT54G router reset to defaults so I...
    Dell 3300 Wireless Printer adapter has always been a hard nut to crack. To begin with, completely remove the printer drivers from your computer using the utility http://ftp.us.dell.com/printer/R166248.zip .Then download and save the latest version of your printer drivers and the wireless adapter utility from the support website. Use this file for the installation rather than the CD that was shipped along with the printer. Use the link: http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=19&l=en&s=dhs&os=WW1&osl=en&catid=&impid=&SystemID=PRN_ALL_A962 . Reset the wireless printer adapter by disconnecting all cables, pressing and holding the Reset button at the back of the adapter using a paper clip for almost 10 seconds and plugging in the power cord back in while the reset button is still pressed. All lights will flash for a while and then the wireless light will go stable. Now follow the steps to install your printer and adapter described in the link: http://support.dell.com/support/topics/global.aspx/support/dsn/en/document?c=us&cs=19&dl=false&l=en&s=dhs&docid=756E3AC8B96309EDE040AE0AB8E10ABF&doclang=en
    Thanks,
    Abhishek
    Oct 15, 2009 | Dell 962 Photo All-In-One InkJet Printer
    I have a similiar problem with my Dell AIO Printer 962
    reinstall the printer and fax cd that came with your computer
    Jul 10, 2009 | Dell 962 Photo All-In-One InkJet Printer
    My Dell AIO printer keeps blinking right ink cartridge incorrect.Exclamation light keeps blinking too.
    Try going to the Dell site and searching for that printer model. Then see if you need to have both ink cartridges populated and filled with ink, to make it work.
    You might also clean the contacts on the ink cartridges, to make sure the printer knows you have both cartridges in the printer, even though they're not both filled with ink.
    It just might require both to be filled, before it will print for you.
    See what Dell says.
    Good luck.
    -a.
    May 22, 2009 | Dell 962 Photo All-In-One InkJet Printer
    Connecting the WGPS606 to Dell AIO 962
    Try installing a lower end printer to the same port. For example HP LaserJet 3.
    Mar 30, 2009 | NetGear WIRELESS PRINT SERVER 54MBPS...
    Dell 962 all in one printer
    the yellow blinkin exclaimation point is usually an indication that there is a printer cartridge problem. It usually means the ink is low.
    Mar 08, 2008 | Dell 962 Photo All-In-One InkJet Printer
    Dell AIO 962 can't send scanned info
    Try reinstalling the printer software by downloading the latest version from support.dell.com.Also try using the printer with a different system if avialable.
    Dec 27, 2007 | Dell 962 Photo All-In-One InkJet Printer
    My Dell AIO 962 Printer does not respond
    The printer is dead and needs replacement. If covered under warranty, u can get a replacement from Dell. Speak to Dell support and they can give you alternative solution.
    Nov 08, 2007 | Dell 962 Photo All-In-One InkJet Printer
    Dell 962 Photo All-In-One InkJet Printer Logo
    1,156 people viewed this question
    Top Dell Office Equipment & Supplies Experts
    jasbo
    jasbo
    Ekse
    Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
