posted by emore norman on Jan 08, 2008
My fridge (danby), makes a whistling sound. It is high pitched and very annoying
Comment by emore norman, posted on Jan 11, 2008
The only thing that worries me is that even when the fan stops turning (when I open the freezer door), the whistling is still there. It lasts about 5 min. or so. If it is the fan motor, wouldn't the whistle stop when the fan stops? I am going to buy a fan motor and put it in, and hope for the best. thanks for your advice.
1 Other User Has The Same Problem
Comment by fibrorock, posted on Feb 12, 2008
My side-by-side GE Hotpoint rerigeratorstarted making a whistling sound about a month ago. It is coming from the freezer, maybe the fan or the ice maker. It stopped dispensing water through the door about the same time. Now the ice maker is not making ice. Any ideas.
Solution #1
posted on May 03, 2008
Mine was making a moaning, whistling noise coming from just above the ice maker. It happened when the fan speed changed. I learned on this site that the motherboard was probably defective.
Rather than go thru GE, we found a new one online for 66 bucks. I replaced it in about ten minutes and it's all fixed. Poor materials on the original, but this site was very helpful.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Jan 13, 2008
Guest
Rank:
Apprentice
Rating: 0%, 0 votes
Rating: 0%, 0 votes
thanks for the interest in my problem. Yes, I can see the fan in the freezer. It's on the back wall of the freezer, and I can see the fan slow down & stop when I open the door. It is a home fridge.
Solution #3
posted on Jan 08, 2008
Your question is a bit vague, but usually this sound is the evaporator fan motor, located inside the freezer compartment. If so, the fan motor is a relatively easy thing to replace.
Comment by hotuna, posted on Jan 12, 2008
Is this a commercial fridge? Do you have a door switch that shuts off the fan when the door is opened? You didn't give me any specs. so I don't know really what Im dealing with. I'v seen commercial freezers shut the evap. fans off when the door is opened, but not a domestic fridge. So unless you can see the fan, how do you know it has stopped after the door has opened?
Let me know.
Let me know.
Rating Locked! (?) emore norman has rated this solution as Not Rated
Suggest a new solution for this problem
Post a New problem for GE GSS25JFPCC / GSS25JFPWW Side by
Email this problem
Email this problem
Can you Help with these Refrigerators problems?
GE GSS25JFPCC / GSS25JFPWW Side by Side...
dispenser light very dim
Replaced door dispenser light... Answer This...
Fridge and freezer warm at top,...
I have a GE GSS22JFMD WW side... Answer This...
Loose door handle
Loose door handle
The door handle on my GE... Answer This...
defrost cycle
defrost cycle
mod#gsh25jfta. seems to stay in... Answer This...
GE Fridge - Model #GSH25JFTA CC...
Our Fridge (freezer side of a... Answer This...
Repair Service
Find Refrigerator Repairman Near You:
Find Parts
