Question about AEG Dryers
Where can i find dryer mate parts for a vent hood , the product is a external vent hood from the clothes dryer called a dryer mate by nemco
2 Suggested Answers
SOURCE: I am looking for a vent cover for the dryer that
I had the same problem and the ones from Lowes, Home Depot etc doesn't fit. I called Buildersbest who makes the vent to ask where I could buy 1-8-U-VENT-SAFE (1-888-368-7233) and they sent me replacement louvers for free!
Posted on May 17, 2010
My maytag gas dryer work on dry cloth and stays hot but as soon as i put wet cloths in it they wont dry ?
My dryers timer wouldn't work correctly and the clothes were taking forever to dry. I decided to check the vent. My advice....Always check your dryer vent before spending any money on unnecessary parts or service calls. This Nest was pulled out of my vent with my shop vac sucking out and my house vac blowing out from inside. It finally broke free and now my dryer works like new.
Sep 24, 2011 | Maytag Atlantis MDG7400AW Gas Dryer
Dryer will produce heat but will not dry clothes
Greetings,
several things to check...i usually pull the vent off of dryer and run load of cloths..if it drys ok...we know the vent was the issue..if its vented to the roof..the screen usually gets stopped up inside the hood. if it still doe's not dry with the vent off. there has to be an air circulation problem.. Check the blower wheel fitting tight enough...they come loose, but normally have noise along with it...
Jan 27, 2011 | Frigidaire Electric Dryer
I just purchased this dryer from the Sears outlet. There is no external damage noted. The dryer is warming up enough to leave the clothes semi-damp. I would like to know is there something I can do prior...
Make sure your dryer vent is open. or is hooked up right and not kinked.... If it is a long run or hard to get to pull the dryer out alittle from the wall and disconnect the dryer vent and run the dryer with the vent unhooked just make sure you have some open ventilition in the room because this is a gas dryer and you will have some Flue gas from the dryer that will be vented inside.
Dec 19, 2010 | Kenmore Elite Oasis 7808 Gas Dryer
Clothes are not drying as fast as before. Lint trap is not collecting ling.
venting issue. check vent tube for restriction. A quick way to know if it is external is disconnect vent tube run a load of clothes if they dry well then it is the tube, if it is the same then it is internal and the dryer will need to be disassembled and cleaned from the lint trap back. Good Luck Tim
Nov 29, 2010 | Maytag Centennial 7.0 Cu. Ft. Super...
THE DRYER ISNT DRYING THE CLOTHES ALL THE WAY. IT TAKES 3 CYCLES TO DRY THEM. WHY?
If the dryer is generating heat, the first thing I'd check is your vent. Even a partially restricted vent will drastically increase your dry time. Vent hoses are easily crushed behind the dryer and the flap inside the exteriod hood can be blocked.
Dec 30, 2009 | Dryers
I am looking for a vent cover for the dryer that is a dryer mate by nemco. It is 5" by 5" square. Where can I locate one?
Nov 22, 2009 | Dryers
Condensation is forming on the walls when I use my clothes dryer
Simpson may have a kit available for accomplishing this. Also, your dryer may have several optional ways of venting.
Mar 27, 2017 | Dryers
Bosch Dryer doesn't dry clothes
With the dryer not connect to the external venting turn the dryer on and see if there is air coming out ot the vent from the dryer. Is this flow of air strong or weak?
If weak then there could be a problem inside the dryer some where. Perhaps the fan is not operating properly. Just my thoughts.
You say you have check the beginning and end of the duck vent pipe. How about seeing if it venting duct is clear from one end to the other.
Good luck
Jul 13, 2008 | Bosch Axxis WTA4400 Dryers
Kenmore dryer
this promblem is about always a vent promblem or not cleaning the drier filter if your using the plastic vent check if its mashed behind the drier you must have 4inch of vent all the way throuch if its mashed or folded over its cut down to 2inches if it hangs under your house then comes up to the outside vent housing it can fill with water if the outside hood door isnt oping that will do it too its in your vent some where what i tell cust to do is run 4inch pvc from out side hood up through floor then run short metel vent to pvg attach with clamp to confirm vent restriction take vent loose for one load and see if it dries in right amount of time
Dec 28, 2007 | Dryers
Dryers Logo
323 people viewed this question
Top AEG Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Gaark
Are you an AEG Dryer Expert? Answer questions, earn points and help others
