I was told that the AT3482P cartridge is a suitable replacement for the original. i tried it and it doues not track the sund properly. what should i do next?
    President:
  • 1,653 Answers
Make sure the vertical tracking force is between 1.0 and 1.5 grams
Check that the output of 5.0mV and impedance of 47k is sufficient for your system
Also make sure that the stylus point is not damaged and teh cantilever is not distroted
Also make sure thatthe phasing is correct for the cartridge connections and that it is mounted inthe correct position and offset.
Posted on Nov 14, 2009
My B&O MMC CL cartridge began to distort, skip, and it lost dB. I replaced the MMC CL with a B&O 4000 cartridge and it plays just fine.
Is the stylus assembly perfectly perpendicular from the front of the cartridge when it contacts the record? A misaligned unit will cause the issues you stated.
Nov 09, 2015 | Audio Players & Recorders
Replaced the magenta cartridge and it still says "order magenta cartridge". How do I correct this problem?
Did you replace with an orginal HP cartridge or a reman. Either way, it sounds like the chip that tracks toner usage is bad on the cartridge. If original HP, contact HP and get them to repalce it. If remanufactured cartridge, contact the people that refilled the cartridge.
Jun 04, 2011 | HP 645A Magenta Toner Cartridge (C9733A)...
PLEASE HELP ME WITH ERROR 6A80[canon 4600]
first you proper installed software by original driver cd deliverd by cannon after if problem still continue then check cartridge but cartridge should be ok , specialy in cannon cartridge demo cartridge working for very short period replace new one originally cartridge, or if your printer sensor ribbon deeply scrached it should be replace.
Feb 19, 2011 | Canon PIXMA iP4600 Color InkJet Photo...
HP Deskjet 5550 quit printing red color. Installed new color cartridge HP57. Quit printing red again after 5 pages. Is it a printer problem or cartridge problem?
Have you check your color cartridge if they are properly installed.
Make sure your are not using a refill cartridge.
Replace your tri-color cartridge with original an HP tri-color cartridge.
Aug 26, 2010 | HP DeskJet 5550 InkJet Printer
I have got an hp deskjet 2480, i have just refilled the original cartridges but printer is printing poorly. Are original cartridges suitable to refill?
The simple answer is no,the main differences after you have given the cartridges a small shake is when you refill the cartridges,which are not supposed to be refilled your ink is not the same viscosity(density and (thickness!) as manufacturers products.This is why your quality is bad,I know it is an expensive buisness and thats why the printers are cheap in the first place --because profitt is made on cartridges.
Aug 18, 2010 | HP DeskJet 920c InkJet Printer
With new cartridge indicates low ink level,
The ink level gauge may not work properly with refilled cartridges. Because of this, you might get low ink message after refilling. To install the refilled cartridge you might need to override the ink level gauge. Overriding the ink level gauge disables the printer’s ink level tracking feature, but allows you to use refilled cartridges. To override the ink level gauge, please check your printer reference guide. After disabling the ink level tracking feature you should check the ink level visually and as soon as the ink level gets low you need to refill the cartridge. You do not want to try to print with an empty cartridge. Trying to print with an empty cartridge may damage your print-heads.
otherwise you will have to replace the cartridge .
Oct 21, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
New cartridge for Technics SL -BD22D
the prestige gold might be a little bit of overkill for this turntable meaning the turntable is middle of the road and the cartridge is hi-end.
To get a closer match for your TT try a yahoo search for "AT3482P-DE" (with the quotes) and the result will be the closest match to what this turntable is designed for. also you can find your TT's owner manual here
http://www.vinylengine.com/library/technics/sl-bd22d.shtml but you will have to register to download the free manual. in that manual you will find the shape of the drawings for the cartridge is the same. both made by audio technica
Feb 03, 2009 | Panasonic Technics SL-BD22D Turntable
Cartridge
"at3482p-de" <--do a search for this at yahoo. the resulting cartridge is correct for your model. it comes with the needle as all cartridges do. There are better ones you can get but this one is aprox. equal to the original supplied with the unit. In short any pmount type cartridge will fit/work in your player.
Jan 29, 2009 | Technics SL-BD22 Turntable
The printer doesn't recognize the new original HP color cartridge
There is a small spring that holds the ink cartridge in the ink holder. You will see it stick out from the right hand side of the ink holder where the ink cartridge slides in. If that spring isn't being held to the ink holder by two plastic tabs, (I.E. the plastic tabs are broken) the printer will never recognize the cartridge. If the printer is still under warranty I would contact HP or an authorized repair center for HP. Both the black and color ink holder has this spring. I know of no way to repair this kind of breakage.
Jan 08, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Wrong colours!
Hi Dannydoda,
I understand that, you are using different compatible ink cartridges and having problem with colors.
HP printers has a small built in firmware, which can detect the original ink cartridges and the ink level.
Using other compatible ink cartridges may damage the print heads of the printer.
I suggest you to replace the ink cartridges with original or Genuine HP cartridges.
You can also try some of the steps to fix the issue as given in the web link.
please click on the web link given below and perform the steps carefully.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00042885&cc=us&lc=en&dlc=en&product=79499
This should fix the issue.
Have a great day!
Mar 21, 2008 | HP PSC 2210 All-In-One InkJet Printer
27 people viewed this question
 Grubhead
Grubhead
