Question about De Dietrich DOP390 Pyrolytic Electric Single Oven
I need to remove an integrated oven - any advice please
    President:
  • 1,653 Answers
The main advice is to make sure that the AC power breaker and isolation switches are off before you do anything else. Once the oven is pulled forward support it on a bench if it is up high or on a piece of wood if it is low. Then disconnect the electricty supply cable from the rear of the oven and either terminate it safely or remove it from the isolation switch.
Posted on Nov 14, 2009
How do I remove the clock/timer assembly that is integrated into the glass fascia panel of an Electrolux oven EOB63100K? The new part I have purchased is complete with its own small fascia panel
Open the oven door and remove the two screws. Pull out the oven and disconnect it from the power source.
To replace the timer you should to remove the two upper cabinets of housing of the oven.
Dado
Feb 18, 2015 | Electrolux Ovens
Wiring up
  • If it is a single oven attaching a 13amp plug and connecting it to a socket is fine. If it is a double oven it needs to be connected to a dedicated cooker circuit from your fuse board via a cooker control switch with 6mm twin and earth cable.
Apr 02, 2014 | Ovens
Integrated Worktops
Usually screwed internally within the door edge of the oven it is rare but may be lugs on the top edge within the oven facia panel.
Jan 09, 2012 | Ovens
F-7 code has been flashing, along with constant beeping. This has happened about 5 times over the past 2 months. Eventually it stops but now we resort to flipping the fuse off to get rid of the noise. ...
Hello Marylou,
The F7 code means the same thing on all domestic (USA) brand ovens.What is means is that a button on the touch pad is shorted (welded together) out. Since you did not include brand or model#
i will give you the following advice, if your touch pad is a seperate part that plugs in clock (also called the oven control,or eoc..electronic oven control) then just the touch pad can be replaced,on certain brands or even some models within a brand the touch pad is integrated into the clock/oven control or eoc in that case the complete touch pad/control asm. is what needs to be replaced
Hope this helps and if it does please give me a 4 thumbs up rating
Gene
Jul 29, 2011 | Ovens
New World TGO 70 grill not working because door was closed
THIS IS PROBABLY BEST LEFT TO A QUALIFIED ENGINEER. To reset the grill thermal cut out. This is located under the metal panel at the top of the unit and it is necessary to ether partially or fully remove the whole oven from its housing to get at it. 1. Disconnect electric supply. 2 remove the 2 housing retaining screws. These are located either side of the at the top of the grill cavity. 3.Pull the whole oven /grill unit out and support it underneath to stop it falling forward. 4. Remove metal cover covering top of oven. 5. the safety cut out is a small component that has 2 wires connected to it by spade terminals, in the middle of which is a small red button. push this button gently with the end of a pencil or screwdriver until it clicks. This should now be reset and allow the gas supply to the grill to resume. Finally reassemble making sure that the integrity of the gas and electrical supplies are, in no way compromised and test.
Aug 20, 2009 | Ovens
I have a Frigidaire stove, when I turn the oven on the element lights up the smell of gas is real strong and then it lights and sounds like an explosion.
Have you spilt anything on the burner? If so it will need to be cleaned,you will need to do the following (you need a pin, a matchstick, a drinking straw and a torch):
Make sure the oven control and the electric isolated is off please, remove the shelves, using the torch, inspect the oven burner, if there is no apparent blockage, disregard the following advice and seek the help of a 'Gas Safe' engineer in your area.
If it is blocked,using a pin or matchstick clean the holes in the burner, and use the drinking straw to blow the debris away. Move away from the burner, and see if it lights.
If this fails to work it could mean that the ignition is in the incorret position allowing for explosive ignition. See advice from a 'Gas Safe' qualified engineer.
I hope this helps.
Jul 06, 2009 | Frigidaire FGB24T3A Gas Single Oven
Melted aluminum foil
Steel wool is the best bet, but it would be easier to replace the floor panel. I had a customer do the same thing. depending on how bad it is replacement mat be a easier option, about $35 for the new panel, and about a month to get the part. two screws on the floor of the oven next to the back wall. The manual does say not to use foil on the oven floor.
Good Luck!!
Thanks
Dec 15, 2008 | Kenmore 33169 Gas Single Oven
B1641 Fan Element Renewal.
If you can see the element once you have removed the inside rear panel, then remove any screws that you can see, and ease the element forward, pull the wires off, but do not let them slip behind the rear wall of the oven, or it means removing the whole oven, to fit the wires back on.
If you cannot see the screws, or they are fastened from the rear, then it will have to come out of the housing.
Hope this helps.
Please leave feeedback.
Dec 05, 2008 | Neff B1641 Single circotherm super...
Oven no heat
check fan element hasnt blown remove back plate in oven after switching off from mains of course and remove the retaining screws and you will see a fan and around that the element it will be obvious to see if its blown as there will be a hole on the casing if so replace and viola.
Jan 16, 2008 | Neff B1641 Single circotherm super...
De Dietrich DOP390 Pyrolytic Electric Single Oven Logo
286 people viewed this question
Top De Dietrich Ovens Experts
ashburton
Shehu Pro
Shehu Pro
Electro Med Services...
Are you a De Dietrich Oven Expert? Answer questions, earn points and help others
