Question about Miele Premier-Plus Built-in Dishwasher
When I turn on my dishwasher there is no water getting to it. I have checked the water line and they are on. Model G 665.
  • 68 Answers
Check the float switch to see if it's jammed.
Posted on Nov 14, 2009
Testimonial: "Thnaks, I am trying to locate a manual for this machine so I can locate the water pump. Any idea where I can buy one?"
4 Suggested Answers
  • 530 Answers
SOURCE: kenmore 665 no lights on panel water in bottom
This is commen with these. you need to take the door and remove the screws around it. You need to gain access to the controller. on the controller you will see a white peice with 2 balck wires going to it that is your fuse. replace this and that will solve your problem.
Posted on Jun 02, 2009
  • 297 Answers
SOURCE: Kenmore dishwasher model 665 stalls in mid cycle
you have a clog somewhere.
Posted on Jul 15, 2009
  • 135 Answers
SOURCE: water leaks above motor when the machine is turn on.
The seal around the pump / motor assembly may be bad. The seal can be purchased seperate from the pump.
Posted on Sep 05, 2009
665.13049k110 kenmore dishwasher won't drain.
Check that the drain pipe exit point is higher than the water inlet and drain connection on the machine, thats a comin problem, also check and clean the drain pump situated at the front of the machine at the botom underneath the cover
Oct 03, 2017 | Kenmore Dishwashers
Dishwasher keeps running to long
Most likely the hot water temperature is the problem. If you have a separate hot water inlet check that the water temperature is ok. But if you only have a single cold water inlet then the heater inside dishwasher may be faulty. Check if the dishwasher is still cold when you terminate the cycle.
Heater is part 13 in this diagram.
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Dishwasher-Parts/Model-66515752000/0582/0130000/P0101063/00003?blt=06&prst=&shdMod=
Apr 04, 2014 | Kenmore 665
Kenmore model 665
Power off, check for clogs and if water supply to arm ok. Remove any build ups and reconnect. Good Luck.
Jul 23, 2013 | Dishwashers
Recently ran well low - no dishwasher not filling
Yes there is a screen in the water valve of the dishwasher. you'll have to shut off to the water line coming in to the dishwasher and disconnect the water line. then take off the water valve to get to the screen. you could have a stopped up screen or a bad solenoid switch on the valve.if you know how to use an ohm meter you can check the solenoid for continuity.
it is better to just replace the valve than to try to take the water valve apart and clean it.
you will want to check the float switch first before you do any of the above.
Jun 07, 2010 | Kenmore 13869 / 13864 / 13862 Dishwasher
Kenmore 665 no lights on panel water in bottom
Jun 02, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
check for a clog at the water valve under the dishwasher.Remove lower panel of D/W(dishwasher)Shut off power supply to D/W.Remove the water supply line from your water valve(its most likely mounted underneath to the left side of frame.After removing this ,very slowely turn water back on just enough to determine if you have a clogged line. Let me know when you are there.
May 20, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
My kenmore ultra wash model #665 does not pump out water.
my model #665 dishwasher will not pump water into the unit
Apr 25, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Kenmore 665 Dishwasher Not Draining
try checking drain lines for the dishwasher for clgs and under the screen in the bottom of the dishwaher
Dec 01, 2007 | Dishwashers
Model 665/157874000/Undercounter Dishwasher
Hi First I would check to see if the water may have been turned almost off under the sink, it will be the Hot water side. if that don't help then check for something plugging the line. let me know what you find, or we can go deeper krazytech
Aug 30, 2007 | Kenmore 24 in. 15874 Built-in Dishwasher
Miele Premier-Plus Built-in Dishwasher Logo
301 people viewed this question
Top Miele Dishwashers Experts
mpservices
Craig Butler
Craig Butler
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
