Question about Poulan Featherlite Gas Blower, with Low Emission Engine, 150 M
I ran the leaf blower for 5 minutes with straight gas instedn if mixed gas. Now I can't get it running. Can it be fixed?
  • 279 Answers
If the unit is still not siezed, it should be able to be repaired. Change the fuel and put in the mix, replace spark plug and check air filter. Good luck...Lee
Posted on Nov 14, 2009
Backpack gas blower
Monching, You will have to hope there is not too much damage done already from running straight Gas. Empty all straight gas from blowers tank and refill with proper minimum 50:1 gas oil mix. Start blower and run on 1/2 throttle for a few minutes to be sure its going to be OK. If seized, you will have to try and unseize and if lucky it may run if not too much damage internally. You should run a heavier oil to gas mix 32 or 40:1 in an engine that's been seized. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
this is what happens when someone run straight gas in two cycle engine
Fixing seized up echo weed eater
Stihl FS120 Grass Trimmer RAN WITH NO OIL IN GAS Blown Top End
https://www.askmehelpdesk.com/tools-power-equipment/ran-leaf-blower-without-oil-36071.html
Jul 12, 2016 | Craftsman 25cc 2-Cycle Gas Blower/Vac
How do you start it?
I means "ON" and o means "OFF"
choke should be closed to richen the fuel mix to start open it slowly after it starts and runs
also note most (2cycle) gas powered leaf blowers require a gas/oil mix to run properly , straight gas will destroy blower motor
Apr 15, 2015 | Garden
My weedeater worked one time and then it stop working not sure why it stoped i need to know how to fix it
well did you run straight gas or mixed fuel...
straight gas... throw it away and find another one
mixed... we need more info like how long it's sat ???
Aug 09, 2014 | Weedeater / Craftsman Igniton Module...
Gas and oil mixed in 4 cycle backpack leaf blower
If it is a 4 cycle blower, you do not mix oil with the fuel....It takes straight Gas. there is an oil cap to put engine oil in crankcase, this only usually takes 2,3,4 oz. of oil. Sounds like your Spark Plug probably fouled out from having oil mixed in your gas. I would recomend changing your Spark Plug and put some Fresh GAS only in the blower, dump the old stuff out !!! You should be on your way Blowing in No Time !
Nov 27, 2011 | Troy-Bilt 32cc 4Cycle Backpack Blower
Started with straight gas- can it be flushed and restarted with gas /oil mix?
Yes you can dump out the straight gas and mix some two cycle fuel mix I would mix it a little rich like 32 to 1 thats eight ounces to two gallons of gas but if you ran it with straight gas for a long time it wont help
Nov 07, 2009 | Echo Inc. 25.4 CC Backpack Blower
Do you use mixed gas for a ryobi weed eater??
Unless it has a tag or decal on it saying it is a 4 cycle then it uses mixed gas/oil at about a 50:1 ratio. Straight gasoline will freeze the piston in the cylinder in mere minutes.
May 23, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Gas only or add mix?
mix!!! regular gas will ruin it
May 17, 2009 | Homelite 'Yard Broom' Leaf Blower
Gas mixture in Leaf Blower?
The 4200 gas backpack leaf blower requires 50:1, 2 cycle oil mixed in the gasoline
Apr 17, 2009 | Garden
Homelite leaf blower bogs down.
I don't mean to over simplify this, but are you using fresh gas? Gas blowers are extremely ticky when it comes to gas. They like it SUPER fresh. And while the gas and oil mixture should be right, it can be off a little bit and still run. Try draining all of the gas out, and then filling up with fresh mix. This is ALWAYS my first step with gas blowers, and it fixes the problem 75% of the time. Also make sure your spark plug is clean. If you are not sure, a new plug couldn't hurt.
Hope this helps!!
chad
Sep 29, 2008 | Homelite 'Yard Broom' Leaf Blower
Poulan Featherlite Gas Blower, with Low Emission Engine, 150 M Logo
273 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
