Question about Samsung SGH-A747 Cellular Phone
People can hear me sometimes, but not others. I can always hear them and text, but more often than not they cannot hear me.
I can make calls and receive call and ppl can hear me but i cant hear them on my sharp fx plus
Sometimes network problems make this,
other wise phones speakr problam.
Jan 25, 2013 | Sharp FX Plus
Can't hear people on the other end??? Samsung U600
Hi on my samsng g600 i can accept calls but i cant hear the caller yet the caller can hear me,please help!
Jul 30, 2009 | Samsung SGH-U600 Cellular Phone
Other person can't hear
It could be connection. The cable might not be sending the right information to the computer.
It might also be their computer. Ask them to try restarting their program. If it doesn't work try fiddling with the wire.
If you have a built in mircophone, then I suggest contacting your coomputer's manufacturer and ask for a repair.
Jul 06, 2009 | Yahoo Messenger
Gas does not always ignite
The igniter is not properly.Every time you go to light the stove you should hear a clicking sound.If you only hear it sometimes suspect the igniter..
Mar 31, 2009 | GE Kitchen Ranges
CHOOSING PREDICTIVE TEXT
Go to 'Create new Message' and move down into the text box.
Press and hold the * [star] key for about 2 seconds and the format should change to predictive text and remain that way. if you want to change the letter case press the * key very briefly.
hope that solves it
Jan 26, 2009 | Samsung SGH-G600 Cellular Phone
I have a sgh A747 and sometimes when I answer a call they can't hear my voice.
If people cant hear your voice only "sometimes" then it should be just a signal problem. If the person on the other end of the line cannpt hear you always then the problem is with your phone. So you can give your phone to the service center.
Thanks.
Nov 29, 2008 | Samsung Cell Phones
Remove hearing impaired text from screen
If you are using a cable box, then the closed captioning is turned on & off with the cable box, not with the TV remote.
Jul 07, 2008 | Sony BRAVIA KDL-46V3000 Television
Text Msg
Mine sometimes refuses to send text messages as well. When I hit the 'send' icon it flickers but nothing happens. The message remains on the screen as if I am still writing it.
When this happens I reset it. Usually one reset is enough but sometimes I have to reset it two or three times for it to work. (By reset I mean sliding off the battery cover and putting it back)
About the other person not hearing you I had this problem also but found it was a very simple thing - something greasy (perhaps food or something) had gotten into the tiny hole at the bottom of the IPAQ (near the connector) and was totally blocking out the sound. I just cleaned out the opening and it then worked fine.
Also be careful not to cover it with your finger. That happens often to me. I have now learned to move my finger when someone tells me they cannot hear me.
If that doesn't solve the problem for you then I'm afraid it is a faulty microphone and will need to be repaired.
Jun 26, 2008 | HP iPAQ hw6515 Pocket PC
I can not delete text messages on this phone
sometimes on my Env when i am trying to delete my text messages the "okay" button will not work. this happens only when i am trying to delete a text message. the solution i have found is quite simple. just turn the phone off completely and then turn it back on in a few minutes. if this does not work then try removing the battery when you turn the phone off. this always seems to make the button work and i am able to delete the messages.
Mar 27, 2008 | LG enV VX9900 Cellular Phone
Cant send texts
Make Sure You Have A Decent Signal Strength.
Move Around Till You Get A Goood Signal.
Good Luck :)
Regards,
Sophiee.
Mar 05, 2008 | LG Shine KE970 Cellular Phone
Samsung SGH-A747 Cellular Phone Logo
139 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
