Question about Garden
Wheel horse 1054 hard to start
Hard to start once you get it running it will run for a while and then just quit. then it is hard to start again.
  • 24 Answers
SOURCE: hard to start cold but once running is ok
I believe you have a throtle body correct? IF so you have poor fuel pressure, plugged filter of injector.If by some miracle you have a carberated engine the the fuel is leaking from the bowl. Get a carb rebuild kit.
Posted on Aug 23, 2009
  • 583 Answers
SOURCE: hard starting diesel
only 2 things can maake a diesel run rough at start up ,,1--- air in the system 2----- 1 or more of the glow plugs not working. this sounds like the latter ,if you have a couple of glow plugs not working ,it will miss on those cylinders until it warms up ,and the smoke is mostll exesive fuel when it does fire . recommend you check the glow plugs
Posted on Oct 11, 2009
  • 11 Answers
SOURCE: 1997 achieva hard to start sputters, runs fine
sounds like the fuel pressure regulator,also make sure the fuel pump and sending unit are working properly. happened to 99 olds of mine! good luck
Posted on May 07, 2010
  • 351 Answers
SOURCE: A 312A Wheel horse. It stopped running the last
clean carb also check points
Posted on Oct 08, 2010
hunter19_46m
  • 7482 Answers
SOURCE: I have a 50 inch rzt with a 22 horse kawasaki
Sounds like you will need to clean the carburetor or replace your carburetor internal rubber parts like the diaphgram and O rings.
Be sure to use compressed air to blow out all the fuel and air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Sometimes you can get by with priming the carburetor or using starting fluid and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Keep in mind that the float for the carburetor must be level when you go to reassemble the carburetor or follow the instrucitons you get with the carburetor kit.
If the mower/weedeater is over a year old, then I also recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their orginal position before you started.
This is a FREE answer,Please rate me
Posted on Oct 12, 2010
Cub cadet gtx 1054 cutting grass and the tractor stop running. Will not start
check wires and connectors--check the inline fuse --seat switch -battery look over the wiring possible wire damaged or disconnected
Aug 14, 2016 | Cub Cadet GTX1054 54 in. 27 HP Kohler...
Tip
Trojan Horse Removal
A virus is program that has malicious content in it and replicates itself and a Trojan horse is program that will only work if the user executes it. Sometimes, a Trojan horse covers itself as a fake folder while in fact, it's an .exe file.
The good thing about Trojan horse is that it is not that hard to get rid of them. But the bad thing about Trojan horse is that it is a little bit difficult to find them.
Although, it does not corrupt files or delete data stored on your hard disk until you execute it. Once executed, it will allow the hackers to indentify your credit card number, social security number, bank account details or some other private information.
You can delete or remove the hidden Trojan horse with the help of antivirus software. Either, you can also try the manual process to delete it or you can follow these steps:
STEP 1 Open the System Information Utility (msinfo32.exe). You can find the System Information Utility by typing “msinfo32.exe” in ‘Run’. This program lists all the processes running on any Windows system, even those processes that are hidden from the task list. Now open your virus scanner and run the executable or .dll through it.
STEP 2 Open your antivirus software and run a virus scan. If you don't have a antivirus software installed, download AVG Anti-Virus Free Edition 7.5. And run a scan using it. After the scanning process is completed, delete the value that was detected from the registry (before doing this step, take a backup of the registry files):
A) Click ‘Start’ > ‘Run’.
B) Type "regedit".
C) Click "OK".
D) Go to the subkey:
HKEY_LOCAL_MACHINESoftwareMicrosoftWindowsCurrentVersionRun
HKEY_LOCAL_MACHINESoftwareMicrosoftWindowsCurrentVersionRunServices
HKEY_CURRENT_USERSoftwareMicrosoftWindowsCurrentVersionRun
HKEY_LOCAL_MACHINESYSTEMCurrentControlSetServices
E) Now delete any value from the right pane that was detected during the scan process.
F) Exit the Registry Editor.
on Mar 16, 2010 | Computers & Internet
My 12.5 hp on my wheel horse starts and runs for about 15 seconds and then starts throwing what looks like a mixture of oil and gasoline out the carb and then stalls out
the needle valve in the carb is not seating replace the needle and seat and change the oil let it run without a load and change it again
May 18, 2012 | Garden
J Deere LX277 has stopped. Engine is running great,,,wont go forward or back...transmission fluid level is good..help
I don't have a John Deere. Had a Wheel Horse once; same problem. There is a transmission switch in back beside the right rear wheel; slides in and out. MAYBE this helps!
Mar 21, 2011 | Computers & Internet
I have a wheel horse 1054 and i need the belt size
You can get a part number and order one from this website:
wheel horse belt
Mar 01, 2011 | Computers & Internet
There are 25 horses and 5 tracks in how many times the race was conducted among 25 horses by arranging them in 5 tracks to find the best horse among 25 horses
Run 5 races, with 5 horses per race.
Thus, all 25 horses have competed exactly once.
Pick the winner from each of the 5 race,
and run one more race, namely a 6th race, with those 5 horses.
The winner is the fastest horse of all 25 horses.
Sep 26, 2010 | Computers & Internet
Troy-bilt horse engiine runs good , tines work,
The wheel shaft on a Horse tiller is one piece so if the shaft turns on one side it will turn on the other. make sure the pin that holds the wheel on is not missing that would let it spin on the shaft.
That's the only thing I can think of that would cause that problem. Hope that helps.
Frank
Aug 29, 2010 | Troy-Bilt Garden
Starts then bogs down and quits running
Check and change the fuel pump relay...the one in the black box inside the engine compartment....hope this will help
Jul 07, 2009 | 1998 Isuzu Rodeo
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
