I replaced the internal CMOS Battery now the biod will not see the SATA Drives HP 9740US
    President:
  • 2,600 Answers
Make sur ein the bios that the sata ports are enabled. Since the bios was reset during the battery change, the ports may have been disabled.
Posted on Nov 14, 2009
DELETE BIODS
clear out your cmos take out your battery wait one min. then put in battery
Mar 28, 2014 | Computers & Internet
How do I remove/replace the hp compaq presario cq60-615DX internal battery. Not the CMOS one; the other large one at the back. There is no slider/lever. thanks
In order to remove the battery pack you should slide the Lock key to the Unlock position and keep it there until you have removed the battery. In the following video (at 00:08) you can see how to do it and replace the CMOS battery also. Hope that helps. How to replace the CMOS Battery in the Compaq Presario CQ60 Laptop
Here is the manual you can read more and see how to on page 46.
http://tim.id.au/laptops/hp/hp%20g60%20compaq%20presario%20cq60.pdf
Feb 18, 2014 | HP Compaq Presario V2000 Notebook
Reboot problems
Hi Dear,
The problem you discussed is hardware related, IT has to do with the cmos battery or the Sata cable.
Disconnect/Connect CMOS battery and reconfigure BIOS settings again based on defaults
- Replace "ALL" SATA Cables and reconnect all drives
Regards
Samson Ved
Oct 18, 2013 | Gateway GT5670 Desktop PC
My hitachi 320gb is not detected in Bios setup
One bad lead or faulty connection point can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive boot up
test all leads that attach to your hard drive including electrical extensions SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty or just replace them they could be faulty
even something as small as an electrical extension or a faulty fan lead can cause you problems computer needs all of the data and power to travel through every working device and to have an end for a computer to be able work properly
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive check all electrical extensions make sure they are securely seated even the cd/dvd drives need to have current go through make sure these devices are working
check the CPU make sure it has thermal paste and dust free secure seating
also check your computer ram modules and cmos battery make sure they are dust free and securely seated some motherboards cmos batteries are soldered in
hope this helps you
Feb 25, 2012 | Hitachi HDS721032CLA362 / 0A39264 Deskstar...
HP Pavilion m7330n: Possible corrupt bios, solutions anyone?
what OS? is this XP? with SP3 or not? needs it. if XP.
you never need to delete old hdd, drivers ever.
reg booster?
would not reboot. the HDD fails>?
its not really BIOS, corruption at all,
if the CMOS battery is above 2.9v then no corruptions happen.!
the ROM part will not corrupt but the ram part can , easy, Battery.
check this battery any time bios forgets things this battery is the
no forget feature (CMOS NVRAM battery backup)
Bios can boot to any dvd, or cd, if you plug it and and select it.
BIos can boot the HDD, or SSD, or USB stick. and more, F9 key?
never use reg booster, avoid it like the plague,
any reg modifying programs are nothing but trouble. !!!
m7330n circa 2005. a desk top (or media center) Athlon 64 X2
so what DVD are you installing,
Sata, or PATA
tell what you have and why you need and adaptor,(btw i have them all here, from you name it ,to what eva.)
the HDD is SATA.
but what is the DVD jacked into?
dvd drives come in;
PATA
SATA
USB
what is yours?
May 06, 2017 | HP Pavilion Media Center TV m7330n...
My computer had a message that the internal battery was low and to replace. The computer now will not turn on. Where can I get an internal battery and can I replace it on my own. I own an HP G60-235DX.
that internal battery is the cmos battery, its the one that looks like the watch battery.
steps to change it :
http://www.ehow.com/how_6914231_change-cmos-battery-hp-laptops.html
Mar 01, 2011 | HP G60-235DX Notebook
My laptop does not see the hdd
Check your CMos setup and see if the hard drive is recognised there.
Feb 03, 2011 | Toshiba 320GB MK3265GSX SATA 3Gb/s 2.5"...
I need to find and replace the CMOS battery in a Compaq Presario 1200
write down the model number or the volt of your CMOS battery and go to any computer hardware shop..
buy the CMOS battery corresponding to your model number or your battery's volt...
all the CMOS battery are almost similar
Dec 19, 2009 | Compaq Presario 1200,1600 (297657-001)...
Seagate SATA 80GB Master Drive and Seagate IDE 80GB Salve Drive
Dear,
You have to make IDE drive as slave. For this put the jumper to slave in IDE drive. Possibility of CMOS battery is rare, but you can confirm it by checking your system time in BIOS. If system time is ok then there is no problem in CMOS battery and you need not to replace it.
Thanks,
Rakesh Kumar
Jul 23, 2009 | Seagate Barracuda 7200.10 500 GB SATA Hard...
I bought a HP dvd1270i to replace my dell internal dr. did i f'up
No it doesn't matter what the brand is as long as its the right Type-Sata, or IDE AKA pata
Jun 17, 2009 | Dell DVD-ROM for Dimension (6t903)...
48 people viewed this question
jasbo
jasbo
