Question about Gaggia Titanium Espresso Machine
Machine makes coffee but no steam . - Gaggia Titanium Espresso Machine
  • 1,089 Answers
HI
More than likely you have a blown fuse on the steam boiler or your steam boiler needs to be replaced.
Posted on Nov 14, 2009
Doesn't make enough steam
This usually happens when the machine needs descaling.Then we have more water than steam.
Mar 30, 2014 | Saeco Aroma Espresso Machine
Ascaso Dream steam wand leak
Hi Emily,
You have 2 issues.
Steam wand leaking while making coffee - This indicates that the seals on the steam tap o rings need replacing.
Coffee pouring over the handle when making coffee - this indicates that the group gasket needs replacing.
Replacing the group gasket is easy takes 10 min
Replacing the o rings on the steam tap may take a little longer..
All you need is a group service kit Ascaso gasket kit Dream Arc Basic
Feb 28, 2012 | Ascaso Dream Espresso Machine
Makes a bang sound and spit sout steam
Try first to pour out some hot water first from steam wand and then try to make coffee.
Jun 30, 2010 | Krups Small Appliances Espresso Machine
Gets no steam
If you can make coffee and the coffee is hot that means the machine works fine and the only problem you have the tube nozzle clogged. So first switch of the machine a turn the knob to off position. Remove the steam nozzle cover and with the use of a needle or steel thin wire insert it to steam pipe all the way in so to make at least a small opening. Try again to work the machine and if you have atleast some steam continue use the steam so any dirt will spit out. The dirt might be dry milk or evn some big parts of scale which have been unstuck from machine during descaling and they have not desolve so to come out from the pipe. So the next time you will make descaling try to leave the machine with descale solution more time inside the machine before rensing.
Good luck
Please remeber to vote for this answer
Mar 13, 2010 | Saeco Incanto Classic Espresso Machine
Saeco Odea Go - Hot water leaks from bottom of machine
That's leaking from the hoses coming out from the boiler,if the machine is new it should be still under warranty, may have to take it back to the service center.When making coffee the lines are under pressure and the water never have a chance to pass through the ground coffee.
Feb 03, 2010 | Saeco Odea Go
Espresso machine not steaming
If the machine heats up for coffee, then the steam wand tips are probably blocked. Use a paper clip or needle to clear out the holes at the end of the steam wand.
Jul 03, 2009 | Coffee Makers & Espresso Machines
STEAM PROBLEM
Does the steam itself smell, or just the milk. If yes on the steam run the descale again. If no on steam then check the perfect cream wand the black plastic arm connected to the steam wand, dissamble and clean, make sure all the holes are clear.
Mar 26, 2009 | Gaggia Syncrony Logic 74884 Espresso...
Can't make coffee
Try to open the steam knob and make a cup of water.
Dec 30, 2007 | Saeco Vienna SuperAutomatica Coffee...
Open Questions:
See all Gaggia Titanium Espresso Machine Questions
Gaggia Titanium Espresso Machine Logo
164 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Oloyede Monsuru
Roger Jackson
Roger Jackson
Level 1 Expert
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
