Question about Ingersoll Rand UP6-20-150 120 Gallon Rotary Screw Air Compressor, 20 HP, 150 PSI, 75 CFM
Compressor wont pump air - Ingersoll Rand UP6-20-150 120 Gallon Rotary Screw Air Compressor, 20 HP, 150 PSI, 75 CFM
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 40 Answers
Check inlet valve
Posted on Aug 10, 2010
10 gal kobalt compressor makes a clicking sound and wont pump up my tires
look for blocked non-return valve from compressor line to tank
check that each poppet valve for each cylinder is operational as the small springs break and do not allow the air to pump up
Apr 12, 2015 | Air Tools & Compressors
Heat pump compressor wont come on in heat mode, works fine in cool mode, we get heat occaisionally for about 2 min, then the compressor shuts off. it is a fridgedaire window unit.
Try setting the thermostat at a normal heat setting. By raising the temperature too high the unit thinks that the heat pump won't be effective and go into strip heat mode.
Nov 17, 2013 | Frigidaire Energy Star Room Air...
I have a model# 919166442 air compressor that all at once quit building air pressure. when it gets to 40psi the engine keeps running but air pressure wont rise
There is a check valve that has gone bad,this allows air into the tank,and does not allow the air to go back toward the compressors head.This can also cause the compressor to lock up.
May 17, 2011 | Craftsman 15 gal Air Compressor 3 hp UMC...
Wont turn over
did u check oil level in pump end take belt off and try 2 turn pulley iff no go pump is seized pull off head and see iff ring is broke
Jul 31, 2010 | Ingersoll Rand SS3J5.5GH Wb Ir Portable...
The compressor turned on pumped up and shut off and wont start up
Inccrease the line pressure to 90 PSI, a air ratchet is a very high volume air tool and the compressor may not be able to keep up with it.
Jul 14, 2010 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
I have a Craftsman 1 hp, 3 gal air compressor model #921.153101 that wont pump air, the motor runs fine, the hose is clear what can I do to get it running?
Remove the air filter and see if the inlet is sucking air if so the unit is pumping,if not the valves could be bad or the piston is broken.
Apr 26, 2010 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
I have a 30 gal 125 psi 5hp air compressor and It will not pump up. I took the top off and I noticed the line from the pump to the tank was loose so I tightened it and it still wont pump up.It seems to me...
Take the outlet line off of the top of the compressor and turn on, if you feel a substantial amount of air coming out of the compressor then the compressor is probably ok.
Sep 08, 2009 | Campbell Hausfeld 28 - Gallon Air...
Not holding air
First remove the air filter on the compressor. Start the compressor and place your hand over the air intake. You should feel it sucking your hand in. If you don't feel it then it's your pump. If it passes this test then get a spray bottle with soapy water and spray it all over the unit. Look for bubbles and repair those leaks.
For pump repair steps I need to know if it is a piston pump or rotory. If your not sure, no problem. I need the make and model # of the compressor for further instructions.
Mar 28, 2009 | Air Tools & Compressors
Ingersoll Rand UP6-20-150 120 Gallon Rotary Screw Air Compressor, 20 HP, 150 PSI, 75 CFM Logo
117 people viewed this question
Top Ingersoll Rand Tools & Hardware - Others Experts
elunsford
Phil Walker
Phil Walker
Are you an Ingersoll Rand Tool and Hardware - Other Expert? Answer questions, earn points and help others
