Question about Kenmore 59940 Kitchen Hood
Blower fan operation
When I push the button the fan raises but the blower does not activate. This problem happened all of a sudden since it worked Christmas. Where do I start to look?
Thanks, Gary
    Problem Solver:
  • 12 Answers
I would order a new Controller Board. Depending on the exact version, it could be a problem with a relay, or a triac on the board, that are meant to power up the motor.
Posted on Jan 25, 2008
Cabin air on 2005 Dodge Dakota stop working
If the blower fan is not operational,check fuses. If the blower fan was working but all fan speeds were not working, possible fan motor resistor. You can try slapping on the botttom of the passenger dash area with the fan motor in the on position with the palm of your hand to see if that will activate the motor. If it does, the motor will need replacement.
Jul 01, 2015 | Dodge Cars & Trucks
Kia amanti air condition
It could be your blower motor. It is located on the bottom passenger side of the dash board under/behind the glove box. There is a cover you can remove and you can touch the blower motor. once you have the cover off start the car and turn the fan speed to high then try hitting the blower motor and see if you get air flow. if this works you need to replace the blower motor. If not you need a test light and start checking fuses and see if you have power to the motor.
May 12, 2014 | 2006 Kia Amanti
Just bought a 05 SLE Bonneville...and on the way home the push button on/off fan button would not turn the fans on. The fans worked fine when the car was driven up from North Carolina. In Minnesota, we...
After talking to a local mechanic, he suggested tapping on the blower motor. I tried that, and the blower motor did work. At first he thought it was the blower control module. I had the blower motor replaced, and all is fine now.
Jan 23, 2010 | 2005 Pontiac Bonneville
Heater blower fan not operating
First, check the fuse. If that is good, chances are the blower motor is in need of replacement.
Sep 06, 2009 | 1991 Dodge Dakota
95 Park Ave blower fan ran with ign off then stopped working
Sounds like a bad blower motor resistor, or if you have electronic temp control, a bad control unit.
Jun 09, 2009 | 1995 Buick LeSabre
Ac/heating problem
Same problem for me. Local garage seems to think replacing the control module in the dash will solve the problem. I also have clicking sounds behind where the relay junction box is (under dash). My problem is intermitant so I'm also thinking that replacing a relay or two might also help.
Mar 19, 2009 | 2000 Dodge Grand Caravan
Blower fan does not work for either heat or a/c
you would have to replace the fan and its on the passenger side under the hood.it has three screws and a plug to take loose and then you can install a new fan
Jan 25, 2009 | 1998 Ford Escort
Microwave seems to turn on when door latch is opened
What's happening is you are activating one door switch a little before the other, and that is causing your light, fan, and turntable to come on. The plastic parts are not perfectly rigid, so they flex a little when you press the button, and that causes the lag to be more apparent. Even if you press the door open faster and look really close, you may notice the light, fan, and turntable coming on for a split second. That's perfectly normal. The relay on the control board must also be turned on before it will actually be cooking.
Feb 22, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Bosch DHD965AUC Won't Lift Up
i've got the same problem. i'm solving it by replacing the motor that moves the arm that lifts the sucker. i think the part number is AP3193909 good luck!
Nov 18, 2006 | Bosch DHD 865 Stainless Steel Kitchen Hood
Kenmore 59940 Kitchen Hood Logo
225 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
