Question about Husqvarna Chain Saw 20" Bar
Husqvarna 372 xp gas tank not venting has a new gas cap did not work
    President:
  • 2,220 Answers
I looked at a 2007 IPL, your saw has a separate fuel tank vent. Husky is terrible about providing a nomenclature and you may need help from your local Husky dealer to identify components.
Find your "Illustrated parts lists" here:
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – for use with IPL
06 1500198
06 = year produced – 2006 (single digit before 2000)
15 = week produced - March
00198 = 198th unit Husky produced that week
HTH
Lou
Posted on Nov 14, 2009
I installed a new after market gas tank on mi 365 huski when i start it, it runs at full throttle, with and without the throttle cable attached
Recheck your assembly...Something is either has the carburetor throttle plate held open or you have an intake air leak. Nothing to do with the tank other assembly problem.
Dec 15, 2014 | Husqvarna 362 365 371 372 Aftermarket...
55 rancher leaks thru the gas tank vent
a small amount of fuel leakege shouldnt hurt anything most gas tank vents are in the fuel cap if so replace cap
Nov 15, 2011 | Husqvarna Chain Saw 20" Bar
Automati oiler not working
Check the tube is that clean and if its ok check the cap air vent of oil tank if its works then oil pump is faulty.
Feb 02, 2011 | Husqvarna 350 18 Inch Gas Chainsaw 52CC...
When saw is running it dies unless i undo the vented gas cap then the saw will keep going is there any other way on other than the gas cap for it to vent or help breath? on a 372 xp
The vent on the 372 is not in the cat, it is situated on the right hand rear side of the fuel tank, the early vent was a black pipe pressed into the tank with a white ( vion ) plug in it, this can be pulled out by screwing a self tapping screw into the middle of it and pulling out with a pair of pliers, the later breather is in the same place but consist of a green valve pressed into the tank, it then has a black pipe conected to it which comes up into the crankcase and sits onto a nipple under the air filter, this can be pulled out with a pair of pliers and replaced, the later breather is very prone to blocking, due to CE law and gas escape from fuel tanks the breather is very fine.
Jan 25, 2011 | Husqvarna Operator's Manual 365 372xp ...
I have a husqvarna 350, seems to have gas problem may be gas tank vent problem losen gas cap will run replase cap will run and then quit.
I would carefully remove gas cap and clean with mild soap and hot water using tooth brush to clean dirt and dust from both sides of cap. If possible blow out with air and mak sure it is thorgouhly dry before you put it back on your saw. If this does'nt help I would try anew cap. Hope this helps. Thanks
Nov 14, 2010 | Husqvarna Chain Saw 20" Bar
New Lawn mower cutting off after 40min of run time
Sounds like you have found a possible solution to your problem. If the cap is not able to vent, it will create a vacuum. If this happens again, try just loosening the cap and see if the mower will run before filling it up again.
Sep 30, 2009 | Husqvarna Lawn Tractor - 54in. Deck, 26...
Husqvartna Gas Vent
Hi
First check the fuel filter ,inside of the gas tank:After that, try to find out where is the airating sistem(gas tank vent):For example a hose with a sprig into it,or any other sistem. Check it.
best regards savumihai71
Dec 08, 2008 | Husqvarna Chain Saw 20" Bar
Chainsaw kills when I press the throttle
My 372 xp did that and when I talked to the repair shop they even showed me. There is a fiberglass gasket that is used to mount the carburetor to the engine. I have no idea on how this happens, but I saw it with my own eyes. The gasket had actually folded over. They replaced it with a rubber one and have had no problem since. The saw was hard to start, would run as long as I didn't try to cut anything and when I did it would open up and then die. I could be giving wrong information, but that sounds exactly like the problem I was having.
Oct 08, 2008 | Husqvarna Chain Saw 20" Bar
Husqvarna Chain Saw 20" Bar Logo
1,233 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
