Question about Garden
I have a mantis rototiller which I have not used for 13 years. I would like to get it up and running again, Is this something that I can do, or should I just take it to a repair shop?
  • 279 Answers
Try this: Replace the fuel with fresh, change the spark plug, check and replace the air filter. The carb may have problems but try those things first. Also replace the oil in the crankcase. Do all those things and let us know how it went. Good luck...Lee
Posted on Nov 14, 2009
I got a Honda mantis rototiller,gx25 model 4 stroke,its got a new carb../ plug / gas / oil / fuel filter / ignition switch, its getting gas to carb/ getting spark but it wont start up .....help me..
If you have proper timing, compression, gas and a spark, the engine should fire/run.
Have you tried a spritz of starter fluid to see if it fires ?
The flywheel could have sheared the key and affected timing.
About the last thing I can think of is valve adjustment, specifically the intake valve, although I think it would be difficult to pull the crank rope if that's the problem.
Feb 13, 2018 | Honda Garden
How to change mantis rototiller clutch
Dissembling the clutch uses special tools to prevent damage to other parts. A trusted shop would be able to do this cheap, then you can reassemble without special tools
Apr 19, 2013 | Mantis 2-Cycle Tiller
No color on the carb adjustment screws?
look for H and L cast on carb. body near screws
May 22, 2012 | Mantis 2-Cycle Tiller
Mantis only runs with choke half on.
Try fuel with 30% injector cleaner (or 25% auto transmission fluid) Something is clogging the fuel route.
May 11, 2012 | Mantis 2-Cycle Tiller
Worm gear has a hard spot, and doesn't turn freely. Tines will run for a short period of time and then stop.
You will probably need to replace the worm gear and any other worn parts in the gearbox. Check your owners manual for part numbers. If extensive repair is needed and your machine is several years old you may be better off with the Mantis trade in program for a new tiller. I found this to be the case with my own tiller last year. Call or go to www.mantis.com.
May 24, 2011 | Mantis Little Wonder Tiller/Cultivator...
New mantis worked perfectly last season. Stored it for the winter. Tried to start it this spring. Pull cord is frozen up. Can't pull it out.
First, call Mantis and get their advice. It may be covered under warranty (I believe it comes with a 2 year warranty). If not under warranty remove the spark plug and try to pull the starter rope. If you can pull it out squirt a little 2-cycle oil in to the spark plug hole and pull it out several times before reinstalling the plug. Then try to start it again. If you can't pull it out after removing the plug try removing the engine cowl that contains the starter rope and see if you can pull it out then. If you can't then there is something wrong with the starter rope mechanism. Try some oil or Liquid Wrench on the spring to see if you can free it up. If you can then the piston may be seized. Again, squirt a little oil ni the spark plug hole. Take a ratchet wrench and socket to put on the crankshaft nut. Try to turn it. Do not apply to much force. I would send it back to Mantis for repair or replacement unless you are mechanically proficient enought to take the engine apart. If you have been using the correct fuel/oil mixture this should not happen.
May 21, 2011 | Mantis 2-Cycle Tiller
Mantis tiller keeps shutting off
One screw is fuel and one is air, try turning the screws in all the way then open three turns and start from there.
Apr 07, 2010 | Mantis 2-Cycle Tiller
White smoke honda mantis rototiller
You're okay the white smoke is the oil burning off the muffler. In time it will stop, just park it somewhere and let it run until it's done. If the problem persists check your air filter and make sure it's not stained with oil, if so you can wash the foam part with soap and water but the paper will need to be replaced. (DO not put foam back on unit until dry.) The oil level should be up to the bottom lip of the dipstick access when the engine is evenly horizontal.
Apr 03, 2010 | Honda 25cc 4-cycle Mini Tiller
Dethatcher pins on my accessory for the honda FG 110 are broken
MANTIS TILLERS USE THE SAME ATTACHMENT CALL THEM @1 (215)355-9700
Jan 29, 2009 | PDP Systems Dethatcher Attachment for...
I am looking for fender for honda fg100 rototiller?
If It is a Honda FG100 like in the title the part number is 65141-V06-003
If it is a FG110 like in the description the part number will be 63411-V25-000 FENDER, RR. and 65141-V25-000 FENDER, FR.
Nov 24, 2008 | Honda Hmantis Mantis Garden Tiller with...
Garden Logo
32 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
