Question about LG Incite Cell Phone
Our LC Incite phone freezes at the AT&T log-in screen. I can't figure out how to get pass this screen. I've tried rebooting and removing the battery, but nothing works. Your thoughts.
HTC my touch 4g frozen
my touch phone screen freeze.what is the cause?
Dec 31, 2012 | HTC Cell Phones
What is the 16-digit Subsidy Unlock Code for LG Incite?
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
If For puk & pin cod problem So Please
Very Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office oprator
Enter The Puk code and Yes
Enter The pin code and Yes
So Puk code Open and Problem will Quickly Solved
Aug 26, 2012 | LG Incite Cell Phone
LG INCITE TOUCH SCREEN PROBLEMS
if you take out your battery, then put the battery back in it should unfreeeze.
Apr 01, 2010 | LG Incite Cell Phone
How to replace lg incite digitizer
http://www.lg-incite.com/lg-incite-tutorials/how-to-replace-digitizer-on-lg-incite/msg40310/#msg40310
Complete instructions on how to tear down the Incite to replace the digitizer. Be aware that most if not all replacement digitizers do not include the adhesive, which is a separate part number. Most people can reuse the existing adhesive, but if not, scrapbook adhesive works.
Jan 16, 2010 | LG FOR INCITE CT810 AT&T CLEAR LCD SCREEN...
How do i stop my incite from freezing
If the phone keeps freezing, you need to reset the phone to initialize the whole system back to the factory settings.
Jul 30, 2009 | LG Incite Cell Phone
My lg incite has a passcode on but i dont have the code
WARNING!! This will most likely reset the device entirely losing any contacts/pictures/information
When you forget your
password, the only way to hard reset the device is via the hard key sequence.
1. Power the device OFF.
2. Press and hold the following hard keys in sequence.
left side - down rocker button - right side camera button - front right phone button
Keep pressing keys until your LCD screen turns on.
Align screen will appear if you success hard key reset.
Jul 07, 2009 | LG Incite Cell Phone
Lg incite screen locked
Remove the battery first. Then hard reset the Incite. It woks for me, but you may need try sereval times. Good luck.
Jun 06, 2009 | LG Incite Cell Phone
Locked LG Incite phone with nonresponsive touchscreen
You have to reinstall the rom
http://www.wireless.att.com/answer-center/main.jsp?t=solutionTab&solutionId=KB102425
May 27, 2009 | LG Incite Cell Phone
Will not start
Try reseting the phone by using the stylus to poke the reset hole in the side of the phone. You can also remove the battery and then place it back in the phone to reboot.
Apr 18, 2009 | LG Incite Cell Phone
Treo 755p screen freeze
Sir U ve to Flash ur phone: its look like to install a new OS in it .u need a tool called box phone its expensive just repairman use it. so seek for one or use our ones by using this repair service and put ur zip code of area.
rate me plz^^
Aug 05, 2008 | Palm Treo 755p Smartphone
LG Incite  Cell Phone Logo
167 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
