Question about Honeywell Heating & Cooling
How can I tell if my honeywell L8148A1017 is bad. I tap and it works all wires seem to be tight
    Guru:
  • Honeywell Master
  • 587 Answers
HONEYWELL WEBSITE:
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
Posted on Nov 22, 2009
Honeywell primary controller keeps shorting, replaced 4 this year
Hmmm. Are you speaking about an 8184 primary ? Oil primary? If you've replaced 4, check to make sure ur neutral wire is tight at every junction. What can u tell us of the resulting g damage to the primary?
Jun 02, 2017 | Honeywell Heating & Cooling
Car issues
WHAT CONDITION ARE YOUR BATTERY CABLES ? THEY MAY SEEM OK, BUT SOMETIMES REPLACEMENT IS NECESSARY ! BATTERY TERMINALS MUST BE CLEANED, SMEAR SOME VASOLINE ON TERMINALS BEFORE MOUNTING THEM, BESURE TERMINALS ARE TIGHT !!! THE (NEGATIVE) CABLE OR GROUND IS VERY IMPORTANT ! A GOOD CONNECTION IS PARAMOUNT !!! INSPECT STARTER/SOLONOID CONNECTIONS, THEY MUST BE CLEAN, PROPERLY CONNECTED , TIGHT !!! TIGHT IS TIGHT, TOO TIGHT IS BROKE !!! MAKE SURE BATTERY IS IN GOOD,CLEAN CONDITION, FULLY CHARGED !!! YOU DID REPLACE THE STARTER WITH A NEW SOLONOID I HOPE ! ITS THIS ELECTRO-MAGNET THAT INGAGES THE STARTER INTO THE FLYWHEEL TO CRANK THE ENGINE . THEY WORK TOGETHER ! TAPPING ON THE STARTER TELLS ME, POSSIBLE LOOSE CONNECTION, EITHER INSIDE OR OUTSIDE SOLONOID . ALTERNATOR PROBLEM ? TAKE TO AUTOPARTS STORE, HAVE THEM CHECK BOTH THE BATTERY & ALTERNATOR . ITS FREE ! CHECK THE ALTERNATOR BELT FOR WEAR, WHETHER ITS TIGHT, LOOSE, ETC., A WORN OR LOOSE BELT WILL SLIP, NOT ALLOWING THE ALTERNATOR TO DO ITS JOB, CHARGING THE BATTERY !!! ONE MORE THING, ITS IMPORTANT TO KEEP THE ENGINE TUNED-UP, ESPECIALLY BOTH AIR & FUEL FILTERS, SPARK PLUGS & PLUG WIRES SHOULD BE REPLACED AS WELL, THEY DO WEAR OUT !!! DISTRIBUTOR CAP & ROTOR NEED ATTENTION ALSO, REPLACE THEM ! BACK TOO YOUR SRARTER/SOLONOID, SOMETIMES EVEN NEW ELECTRICAL PARTS GO BAD, IT HAPPENS ALOT, THEY COME FROM MEXICO, CHINA, ETC., NEED I SAY MORE ???
Mar 24, 2013 | Dodge Grand Caravan Cars & Trucks
My Aquastat Relay is not sending power to my oil furnace burner
tap on it with a plastic screw driver if it works shut down system ac spray sys and relay wioth isoprople achohol manually moving relay 2 clean contacts,let dry or use a dryer as achahol as its flameable try again!! mine is doing the same thing gonna clean it in am as im out of achahol. let me know if works! miker9955@aol.com mike
Dec 29, 2012 | Honeywell L8148A1017 Aquastat Relay...
We have a honeywell th220b1000 thermostat that has a red, brown and yellow wire only. The heat doesnt seem to be working. Can you tell me what could be wrong? Help.. thanks..
Those are abnormal colors... but...
make sure the The "Rc and Rh" terminals in the t-stat are hooked to the "R" in the furnace...
The "W" to the "W"
And the "G" to the "G"
Then providing that the programing is correct in the t-stat everything should work for you...
heatman101
Dec 07, 2010 | Honeywell Heating & Cooling
Just had a honeywell th4000 installed but the heat won't cut off? The temp keeps rising had to cut it off just so I wouldn't burn up? Tried setting the temp down to about 67 but the temp just kept rising
Sounds like they either wired wrong or they got the white wire touching the red wire. Take the cover off the thermostat and see if you can tell if the white wire is touching the red wire. Installers are bad about leaving tag ends on the wires and they end up touching other wires. Good luck
Nov 30, 2009 | Honeywell Heating & Cooling
Where is a 1996 nissan 240sx radio ground wire at?
well coming from the radio harness its hard to tell unless you have an adapter. On my s13 i just drilled a wire to the steel frame that hold the dash together and that works fine. make sure its nice and tight and use a self tapping screw
Jun 18, 2009 | 1996 Nissan 240SX
Honeywell T882 Chronotherm Clock Thermostat needs replacement
The two wires from the transformer are to run the clock in the old thermostat. If you connect the two other wires to any heating thermostat, it will work. Don't forget to disconnect the transformer wires. Hope this helps
Nov 10, 2008 | Honeywell Electronic Programmable...
Problem with Honeywell RTH230B Thermostat
Sounds like you have it wired wrong..   Pop the top off and give me to color of the wires and tell me which letter each color wire is on.. that will tell us right away if you have it wired wrong
May 27, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
176 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
paulcarew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
