My ikon LS-2000 will not scan any longer. When I try to start I get the message that "no active device found"
  • 4,281 Answers
First make sure usb cable of scanner works fine.
Make sure scanner driver is installed correctly and works fine.
Reinstall scanner driver if still same message .
This error occurs when scanner is not recognized by computer.
Posted on Nov 14, 2009
My ford icon 1.6i only accelerate at 2000 rpm and idel between. 0.900/1000rpm and use accessive fuel..pullaway is weak??
Problem with my Ford Ikon 1.6? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Jun 10, 2012 - The same problem presist on slow speed also. ... Still the problem presist on sudden acceleration and when we strart up in signals. .... Ford ikon 2002 clx 1.6i starting problems start quick on running can it be the starter?
Ford Ikon fuel consumption, miles per gallon or litres/ km ...
www.cfcr.eu/ford-ikon-fuel-consumption-miles-per-gallon-or-litres-km
Ford Ikon fuel consumption, miles per gallon or litres/ km ... How much fuelconsumed Ford Ikon 1.6 i, liters / 100 km or miles per gallon. Ford Ikon 1.6i it is a ...
Oct 24, 2015 | Ford Cars & Trucks
Wont start
Very complex hi-tech car
I have a 2004 LS
You need a programmed key,two actually
Then the signal goes to a module behind the
instrument cluster & then to the starter relay
& then you can start the car
You need professional scan tool to get enhanced
codes & then use the trouble charts to diagnose
How is the battery?
Nov 28, 2012 | 2000 Lincoln LS
Nikon LS 2000 scanner is reporting a hardware error
Hello Mike,
According to a previous post this is your answer by:
johnmichaelc
The symptoms of stepper motor failure are a loud grinding noise during scanning followed by the enlightening message:
"The scanner has reported a hardware error. The present function cannot be continued. Sense: 0x04620000"
Oct 29, 2009 | Nikon LS 2000 Film Scanner
Nikon scan was unable to find any active devices
The LS2000 is older than XP and has some fairly tight requirements to work. The recommended SCSI adapter is an Adaptec 2906, and you will probably need to backrev the ASPI layer driver files to version 4.7 (available on adaptec.com site). You may need to boot in Safe Mode to remove the later versions of the ASPI files before you can install the 4.7 files. You will also need to update your Nikon Scan software to version 3.1.2, available online by googling "nikon scan 3.1.2".
Mar 22, 2009 | Nikon LS 2000 Film Scanner
Dell laptop wont recognize ls2000 scanner
The LS-2000 is a "legacy" device to XP and the Nikon software. It needs to be connected to a true SCSI bus adapter, and it's actually pretty finicky about which ones will work in XP. Sorry, you won't be able to use this with your laptop.
Feb 28, 2009 | Nikon LS 2000 Film Scanner
2000 Saturn LS, high idle durning cold weather. (2500 rpm)
Scan for codes, post any that are found, it could be a bad TPS sensor. Could also be a build up of carbon on the top (valve) portion of the engine. Try a few cans of "Sea Foam" through the intake manifold.
Dec 27, 2008 | 2000 Saturn Ls 4dr Sedan
PC (Dell) won'r recognize scanner (nikon ls 2000)
This is a problem with SCSI bus speed too fast for the legacy device. The recommended SCSI controller is the Adaptec 2906, which will recognize legacy devices and slow the bus speed for them.
You also need an older ASPI driver set, version 4.70 available from Adaptec at http://www.adaptec.com/en-US/speed/software_pc/aspi/aspi_v470_exe.htm
Before you install the 4.70 version you need to be sure to remove any newer versions of these files: Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}ASPI32.SYS Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}WOWPOST.EXE Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}WINASPI.DLL Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}WNASPI32.DLL
These files may be found in WindowsSystem or WindowsSystem32. In order to delete them, you will need to restart your PC in Safe Mode. Once they are gone, restart your computer normally and run the ASPIINST.EXE program which was extracted by running the file downloaded from Adaptec.
Finally, you need Nikon Scan 3.1.2 for the LS-2000, available at http://support.nikontech.com/app/answers/detail/a_id/81
Nov 18, 2008 | Nikon CoolScan V ED Film Scanner
Nikon Scan doesn't recognize scanner
I have the same problem (on XP, Nikon Scan 3.1.2) ... IF I turn the scanner on before the computer (or turn the scanner on and then reboot) then Nikon Scan recognizes it. Can't say I'm happy with the solution, but it works consistently for me.
Apr 18, 2008 | Nikon LS 2000 Film Scanner
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
