Question about Mtd Arnold Corp 38" /42" Mulch Kits
The drive petal went loose. mower will not move under power. blades still turn.
    Problem Solver:
  • 8 Answers
Sounds like your motion contol linkage has disconnected itself. Depending on your tractor, this will either be a cable, or a metal rod.
In some rare cases the motion contol is engage by taking the slack out of drive belt by manipulating the position of an idler pulley. If this is the case... check for belt breakage (it may employee 2 belts, 1 for drive, and one for the blades).
Posted on Nov 30, 2009
Husqy cth2542 starts and can move both in forward and reverse and seems to rev fine, but as soon as the blade is engaged) the engine looses power and turns off if the blades are not disengaged.
It sounds like a safety switch issue. It may be possible one of the deck PTO safety switches has gone out or the connector plug is loose or broken. Some newer mowers have fuses located either somewhere around the dash or under the seat check to see if there are fuses and if one is bad it could cause a similar problem to a bad or disconnected safety switch
Jan 01, 2017 | Garden
Won't Fully Engage Drive Gears
If the machine has been sitting idle for a period of time it is probable that the cutter spindles have failed / rusted bearings. They suffer from wet grass/ water seepage when working and when let stand idle for a time will rust up the balls in the bearings. Loosen the drive belts and see if the cutters can be turned freely by hand .
Jun 20, 2013 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
Huskee model 287707 blades wont spin belt not broke or spinning?
check for power and ground at the connector that feeds the clutch this will tell you if its a switch or the clutch itself
May 23, 2012 | Garden
Husqvarna zero turn runs great but after about 30 mins the blades stop turning
when this happens you need to see if it you loose power to the clutch to see if the clutch is failing or the circuit feeding it power
Apr 27, 2012 | Husqvarna Zero Turn Mower Z5426
My Cub Cadet 1554 PTO Cluch is soking black smoke. It is turning, just greesed all my mower spindles
Tony,
Your mower has a mule drive PTO. The belt starts at the clutch goes down to two idler pullys then back to the deck. You said you lubed the spindles, the only other moving parts (idlers) are preminently sealed. You cant lube these even if you wanted to, they do fail. The usually get loose, but sometimes the seize and smoke your belt. There is a tensioner arm on the deck, remove the tension, then (with the tractor off), spin by hand all of the idlers on the deck and the two up front on the tractor (mule drive). They should spin freely and quietly, if they are loose or wobble or make noise, replace them. Also while you are under there, spin the spindles (blades), they should spin freely as well, with no bearing noise or movement. The way to check that is to reach under, find the end of the blade and lift up on then pull down on, it should be tight. If it moves, the blade is either loose or the bearings are failing. These are the things that are the PTO components, All have to be working with freely moving parts, or you could have resitance that will smoke belts, or shred them depending on the failure.
As far as the clutch, it either works or it doesnt. With the tractor off and you sitting on the seat, turn the ignition to the run, not crank position. When you engage the clutch you should hear a "Clunk" when you pull the yellow knob. If so it works fine.
Hope this helps.
Nov 12, 2010 | Cub Cadet Garden
When deck is lowered blades do not engage
Is the belt in place that drives the blades?
Is the belt at the correct tension?
With the mower engine off.....try to turn each pulley the belt drives and on the mower deck with the mower in up position and or down....do they turn a little......this is to check for a seized bearing on one of the pulleys also look under the deck for something stuck........ jamming a blade.
Also check for the mower belt safety system (which stops the blades quickly when disengaging them) that may be stuck in stop mode.
With the mower engine running.....have some one engage the blades while you look under at the belt system....is the engine driving the belt.....is the belt driving the blades.
DO NOT TOUCH ANYTHING......MOVING OR STOPPED while the engine is trying to drive the blades.
Sep 06, 2009 | Mtd Garden
I have a 18.5 hp 42" electric start craftsman mower. when i went to engage the blades the lever was harder to move than usual and once it was engaged nothing happened. blades not turning! please help.
When you move the lever and engage the blades you are also engaging the belt that drives the blades and sits on top of the mowing deck. Chances are that belt either came off one or more rollers, or broke. The only way to check it out is to get down and look on the top of the mowing deck. Get back and let me know what you find.
Jun 08, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Blades won't turn to cut grass
On the chute where the grass comes out there is a black piece of metal under the edge of the deck held on by the 2 big thumb screws is probably bent. You will need to try to move the blade on the side near the chute by hand (Make sure the mower is not running when you do this) if the blade touches the black piece of metal it will kill the mower if you engage the blades and try moving forward. Anyway you need to take the black metal piece off and bend the corner out of the way (I used a crescent and clamped it to the hitch on my pickup). I am guessing i went over something like a street curb with the deck when it was to low and that bent it. Now when ever I move the mower from someones yard or drive it across the street I always raise the deck up all the way. I hope this helps
Apr 19, 2009 | Ariens 34 In. Zoom Series Riding Mower
BLack and decker electric lawn mower blaDE IS loose and not turn
If it's like mine (MM 875), it has a plastic "clutch" that has little edges on it that broke off when I was chopping sticks with the mower ;-) Went to the local B&D place and got a new one for less than $3.
But now I'm worrying about the nut holding the blade on -- if I try to get it good and tight, the plastic "clutch" spins around off-kilter... Funny how I never even looked at the blade after I bought the mower used, but never worried about the blade being loose and flying off.
Mar 03, 2009 | Electric Lawn Mower
Mtd Arnold Corp  38" /42" Mulch Kits Logo
143 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
