Question about D-Link DCS-5220 Network Camera
Settings on Linksys router for the DCS 5220 to view remotely and settings on Securicam
    Novelist:
  • 111 Answers
Configuring your Linksys router for remote desktop is a task that's needed before you can access your computer from outside the network. If you plan to connect to your remote desktop machine from the Internet, you need to configure the router to allow traffic to the PC. Linksys is a common router used on home networks for wireless and LAN configurations. Configuring your router to allow port forwarding to a remote desktop only takes a few steps through the graphical user interface.
  1. tep 1 Open your browser window and type the IP address of the router in your address bar. This opens a window for the username and password needed for access to configure the router.
  2. Step 2 Click the "Applications and Gaming" tab on the opening screen. This opens a window with a list of ports of which you can open for access on your network.
  3. Step 3 Type "Remote Desktop" in the application textbox.
  4. Step 4 Enter "3389" in the "Start" and "Stop" port ranges. This port number is specific to the remote desktop application.
  5. Step 5 Leave the value of "Both" in the protocol listbox.
  6. Step 6 Type the IP address of the internal machine on your network. The IP address is the machine running remote desktop. When traffic from the Internet reaches the router, it forwards the request to this IP address.
  7. Step 7 Check the "Enabled" checkbox and click "Save Settings."
  8. Step 8 Close the browser window.
Posted on Nov 14, 2009
How to setup aztech router for remote ipcamera (dlink dcs-5220 model)
Install the installation disk of the ipcamera. Configure the ipcamera base on your requirements. Then install the ipcamera on the position you require.
Sep 13, 2010 | D-Link DCS-5220 Network Camera
Can't view IP cam externally
Follow The Process:-
1.Visit https://www.yougetsignal.com/tools/open-ports
input the port 5000 and check is it open or not, if it is not open it means you need to check port forwarding in your main internet router/modem.
2. By Default Routers/Modems Http port it 80. so you need to change ip camera http port 80 to 81 and do port forwarding and to view on android devices check another ports in ip camera network settings. so same port forwarding and check in yougetsignal website.
Visit Here for next level help:-
CCTV Networking Technical Support
Jun 10, 2017 | D-Link Securicam Network DCS-950G Wireless...
How to set Static local IP Address for D-link DCS 5220 IP Camera? Am using Linksys WRTG54 Router, with SSID & WPA. I had set the D-Link DCS wireless to use the same SSID and WPA, but once I plug out...
To set a static IP on the camera, do the following:
1. Chose an IP address for the camera that is outside your normal DHCP range but within your network subnet.
For example, if your router uses DHCP and gives out addresses in the range of 192.168.1.1 up to 192.168.1.10, you should chose an IP address beyond that (e.g. 192.168.1.20).
2. Login to your camera's current IP address and go to Setup -> Network setup
3. Turn off DHCP and type in the IP address that you chose into the configuration.
4. Restart your camera.
The above should fix your Static IP address question.
With regards to your Wireless question, you should make sure of the following:
1. Your router is set to broadcast its SSID
2. Your router is setup to use WPA (not WPA2)
3. Your AES password in the camera config is the same as that as the routers
Hope this helps
Nov 24, 2009 | D-Link DCS-5220 Network Camera
What should the securicam setting be, to view remotely for the dcs 5220 wireless camera
Wireless camera security systems are available at many stores such as Wal-mart, Fry's and Best Buymag-glass_10x10.gif. These systems can be used to monitor your home and possessions while away. This article will show how to set up such a system.
  1. Step 1 Decide what you want to see on your security system. Front doors, back doors and driveways are popular choices. Other choices may include living rooms, hallways and garages.
  2. Step 2 Wireless cameras are not completely wireless. They still need a wire for power. Most systems come with plug in adapter to power each camera. Most power wires are 4 to 6 feet long. The location of your cameras should be close to power outlets. Professional installers may run electrical wire inside walls and conceal the power outlets and adapters in junction boxes.
  3. Step 3 Each camera will need to be set to its own channel. Common channels for such systems are labeled A through D or 1 through 4. Drill holes into walls and mount the cameras with screws.
  4. Step 4 The wireless camera receiver will be positioned next to the television. Connect the receiver to the television using a cable that has a yellow, red and white connector on each end. Some systems may have an "S-video" connector and cable to connect it to the television. The receiver will also be powered by a plug in wall adapter. Connect it to the receiver and plug it into the wall.
  5. Step 5 Set the receiver to channel A or 1 and turn on the television. The channel of the television may need to be set to Game, Video In or some other name designating the input jacks used. Consult your television for more information.
  6. Step 6 The view from the camera that is set to channel A or 1 should be visible on the TV screen. Tilt the camera if needed to get the view you desire. Set the receiver to channel B or 2 and repeat with the camera that is set to B or 2. Repeat with the remaining 2 cameras.
  7. Step 7 More advanced users may connect the receiver to a VCR, DVR or computer. Digital video capture devices can be used to connect the receiver to the computer. Using video capture software, the video from the cameras can be broadcast on the internet using software such as Yawcam or WebcamXP. HomeCamera.com can also be used to monitor your cameras on the internet.
Nov 14, 2009 | D-Link DCS-5220 Network Camera
Wlan does not connect
Plug in the network cable first and make sure the following settings are correct:
1. SSID is the same and set to broadcast
2. You are using the same WPA AES password as the router
3. The wireless antennae is connected
4. The camera is located not to far from the router
After that, remove the network cable and restart your camera.
Oct 14, 2009 | D-Link DCS-5220 Network Camera
Reset admin pw on Linksys RV042 VPN Router?
unplug router on the back is a reset hole use a pen or paperclip and press for 30 seconds this will set the unit back to factory settings
Default IP: 192.168.1.1
Username: Admin
Password: Admin
http://www.smallnetbuilder.com/content/view/30186/51/
Apr 16, 2009 | Linksys RV042 VPN Router
Wireless installation for DCS-5220
2. You are using the same WPA AES password as the router (or WEP password if you are using WEP)
May 19, 2008 | D-Link DCS-5220 Network Camera
Inability access from other computers
You need to check with your router vendor on how to setup DMZ or Port Forwarding for your DCS-5220 in your router. (For Port Forwarding, please open BOTH HTTP Port and RTSP Port and select the Protocol as TCP for HTTP Port and select the Protocol as TCP/UDP(Both) for RTSP Port.
Nov 14, 2007 | D-Link DCS-5220 Network Camera
D-Link DCS-5220 Network Camera Logo
791 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
