Question about Intel Celeron D 2.8GHz 478-pin 533MHz CPU OEM (CPUSKCD280533)
Intel 2.8G\400MHz problem
Have a Foxconn 661MXPlus Motherboard that seems to post fine, but when it gets to Windows XP Home Edition it flashes the startup screen and then goes back to rebooting -- and it keeps doing that. The HD is a WD 250G IDE drive that was pulled from a working system. It still operates in older
E-machine, but won't operate in the case with the Foxconn motherboard. I did put an older Conner hard drive on the Foxconn board and it booted to DOS like that drive was supposed to. Any suggestions would be appreciated, as I have three of these boards to put into use.
Thanks
Jim K.
    President:
  • 2,351 Answers
I would agree that 50% of the time you may get away with putting a working Hd with windows on it to run when changed to another board. When you change your motherboard, there are certain entries in the system registry that are looking for the components of the old motherboard. If the registry does not find these components, the system can become unstable.
The fact that you got windows to some what start is a good sign for the Hd. Try setting the CD as first boot device & have your windows XP in the drive. Do a format & install. I'm sure windows will install. Since you have three boards all the same you will only have to do this once. Foxconn warrants all Mb for life. You can always call at 580-272-0035
Mach Speed Technologies, Inc.
110 East 10th Street
Ada, Oklahoma 74820
Posted on Jan 09, 2008
I want to instal a windows XP SP3 on Foxconn 915 series with north bridgegrantsdale G-i915G with a IDE H.D.D (pata) and sata O.D.D,it seems that i need a floppy disk for raid driver,but i lost motherboard...
There are a couple options.
  • Check in BIOS to see if your motherboard supports IDE emulation mode. If it does turn it on and XP will install just fine.
  • Download and read about using nlite to incorporate sata drivers into an Windows XP installation disc. (You will need another working computer. Download nlite and insert the XP disc run nlite and select your CD as your windows install file location. Download generic sata drivers, intel has a bunch you can get for free. In the nlite menu to add drivers select folder option and select the folder with the drivers. Set anything else you want in nlite and burn the new XP disc. This disc will install just fine as it now has sata drivers.
Comment if you need further instruction.
Aug 18, 2011 | Foxconn 915P7AC-8KS Motherboard
Pci driver is not installing
Intel DG31PR Motherboard has Intel 3 Series Chipset and you have to install the chipset drivers, which would install the PCI Drivers as well. Please visit the link given below, download the chipset drivers and install them.
Intel DG31PR Chipset Drivers
The above drivers support Windows 7, Windows 2000, Windows XP Home Edition, Windows XP Media Center Edition, Windows XP Professional x64 Edition and Windows XP Professional
Hope it helps! Good Luck!
CreativeTECH
Apr 09, 2011 | Intel DG31PR Motherboard
Sm bus controller
Intel D102GGC2 Motherboard has ATI Radeon Xpress 200 Chipset and you have to install the chipset drivers, which would install the SM Bus Controller as well. Please visit the link given below, download the chipset drivers and install them.
Intel D102GGC2 Chipset Drivers
The above drivers support Windows 2000, Windows XP Home Edition, Windows XP Media Center Edition, Windows XP Professional x64 Edition and Windows XP Professional
CreativeTECH
Apr 01, 2011 | Intel D102GGC2 Motherboard
What cpu can the motherboard 661M03-G support?
Vendor Type FSB Frequence
Intel Pentium Northwood 400MHz 2.0, 2.5GHz
Intel Pentium Northwood 533MHz 2.4-3.06GHz
Intel Pentium Northwood 800MHz 2.4-3.0GHz
Intel Pentium Prescott 800MHz 2.8GHz
Intel Celeron Northwood 400MHz 2.0-2.4GHz
Intel Willamette 400MHz 1.8GHz
Intel
Jan 30, 2010 | Foxconn 661M03-G-6EL Motherboard
Computer turns on then shuts off.
Hi there.
Have you tried clearing CMOS? look on the motherboard for the battery, the jumper should be near that and with most motherboards should be marked with "CLR_CMOS" like this >>>>>
If you cannot find the jumper then chances are the board does not have one so to clear the cmos you have to take the motherboard battery out for an hour or so making sure you remove the power cord from the back of the machine, also take out and reseat the memory
Please post back with the results and more help if needed, good luck and thanks for using FixYa!!
May 21, 2009 | Foxconn 661FX7MF-S Motherboard
Here's the info....
The term you posted, (AWRDACPI model) - AWRDACP, is the name of the bios.
If your motherboard model number is the Intel D915GAG than click on the link below;
http://downloadcenter.intel.com/filter_results.aspx?strTypes=all&ProductID=1672&OSFullName=Windows*+XP+Home+Edition&lang=eng&strOSs=45&submit=Go%21
Support for, Windows* XP Home Edition, Windows* XP Media Center Edition, Windows* XP Professional, Windows* XP Professional x64 Edition
Mike
Apr 30, 2009 | Intel D915GAG Socket 775 Motherboard -...
Lost my driver cd
Intel D845GVSR motherboard?
This is Intel Support, and the Driver download page for the
Intel D845GVSR motherboard. This is for using Windows XP Home,
http://downloadcenter.intel.com/filter_results.aspx?strTypes=all&ProductID=1065&OSFullName=Windows*+XP+Home+Edition&lang=eng&strOSs=45&submit=Go!
This is if you're using Windows XP Pro,
http://downloadcenter.intel.com/filter_results.aspx?strTypes=all&ProductID=1065&OSFullName=Windows*+XP+Professional&lang=eng&strOSs=44&submit=Go!
This page, is for choosing what Operating System you're using, if it's Not Windows XP Home or Windows XP Pro,
http://downloadcenter.intel.com/Product_Filter.aspx?ProductID=1065&lang=eng
Apr 19, 2009 | Intel D845GVSR Motherboard
Fw82801db chipset audio driver
akhlesh143
u can download this driver(Windows* 2000, Windows* 98 SE, Windows* Me, Windows* XP Home Edition, Windows* XP Media Center Edition, Windows* XP Professional, Windows* XP Professional x64 Edition)
from this link http://downloadcenter.intel.com/filter_results.aspx?strTypes=all&ProductID=1065&OSFullName=Windows*+XP+Professional&lang=eng&strOSs=44&submit=Go%21
or this link http://downloadcenter.intel.com/Product_Filter.aspx?ProductID=1065&lang=eng
Buddhadev
Jun 29, 2008 | Intel D845GVSR Motherboard
Cannot Install Windows
Well it sure sounds like an overheating problem, and 77 degrees celcius is way too high, specialy if it's right after boot! try reseatting the heatsink and make sure the repair place put a thin coat of heatsink compound paste on the processor. You need to bring that number down so really pay extra attention to the heatsink.
The next thing would be a bad memory module check out http://www.cas411.com/ShowArticle.aspx?ID=66 , it talks about surprising behaviors of PCs when a memory goes bad.
Hope this helps!
Alex J.
Mar 23, 2008 | Foxconn 661MX Motherboard
Intel Celeron D 2.8GHz 478-pin 533MHz CPU OEM (CPUSKCD280533) Logo
276 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
