Question about HP Compaq Presario CQ50-103NR Notebook PC
Hi i had arrived to the dc socket how do i remove it???
    President:
  • 2,600 Answers
Below is the service manual for your laptop. Disassemble the system down to the motherboard. The power socket is described on page 83.
http://h10032.www1.hp.com/ctg/Manual/c01572022.pdf
Posted on Nov 14, 2009
How to replace the dc socket
Generally speaking if you are not competent with a soldering iron it is best left to the professionals to sort out. However having said that, Dc sockets on most laptops are often easy to get to once you have removed the keyboard and perhaps a few other removable parts such as hard drive and possibly cpu fan. All depends on the location. I don't know without checking a service manual for this model but the dc socket normally has two cables with a possible earthing third.
The question really is why do you need to replace the socket in the first place. If it is because you have intermittent connection with the power supply, rather take laptop to shop or friend and try alternative power supply transformer as this is usually the fix.
However if the DC socket is truly messed up for another reason such as a small child sticking something in there that wont come out or such like, then the laptop will need to be dismantled accordingly.
Apr 30, 2014 | ASUS Eee 1001PX MU27 Netbook
Broke off my ac power supply nipple on the inside of my laptop where can I get a new one to solder on
Hi, if the Notebook is still under Warranty it is not recommended to remove and solder the Notebook with a Female DC Input socket of the Notebook. Although the DC input socket is available in any near by Electronic repair shop, please repair only if the Notebook Warranty is expired.
Mar 29, 2011 | Gateway MD7820u Laptop AC Power Adapter...
I have a hp pavilion dv7 and the power socket has come a lose i need to know which wire goes where.....
The DC Power Jack that the AC adapter (Charger) plugs into?
Look into the DC Power Jack with a magnifying glass and light you'll see it's a center pin surrounded by a barrel. Barrel has an inside and an outside.
1) Center pin. Gold and buried down in the plastic. Connected to WHITE wire at motherboard connector.
2) Inside barrel has 4 Brass fingers.
Orient the laptop so the LED is at 12 o'clock and you'll see fingers at 12, 3, 6 and 9 o'clock.
These fingers carry the + 19 volt power to computer.
The ones at 6 and 9 o'clock do, Noon and 3 are not connected.
+19 Volt power arrives at motherboard connector on RED wire.
3. Outside barrel has six brass fingers, at 2, 3, 4, 8, 9 and 10 o'clock.
2, 3, and 4 are not used,
2, 8, 9 and 10 are the power return (common, or ground) to computer.
It arrives at motherboard on BLACK wire.
4. LED is connected to YELLOW wire and controlled by computer.
Other side of LED is jumpered to a Black wire,(Ground), outside barrel 8, 9, and 10 o'clock.
From > analog posted in an HP Support Forum.
Nov 12, 2010 | HP Pavilion dv1000 Notebook
Where i can buy, power socket for my amilo pro v2010?
Just one example,
http://www.laptopjacks.com/view_part/For-Fujitsu-Amilo-Pro-V2010-DC-Power-Jack-FJ41420.html
The power socket in the laptop that the AC adapter (Charger) plugs into is a DC Power Jack.
Type Amilio Pro V2010 DC Power Jack in your browser search bar, press the Enter key.
To add:
http://www.laptoprepair101.com/laptop/2007/12/06/dc-power-jack-repair-guide/
Nov 07, 2010 | Fujitsu Siemens AMILO Pro V2010 Notebook
Hi Mu c1020 have prover problem , it seems that
It sounds like the DC socket has either worked itself loose from the motherboard or it has broken off. Either way this problem can be repaired.
You have 2 choices available to you, you can take the laptop to reputable computer repair store and have them fit a new DC socket for you, or you can purchase a DC socket from places like eBay for example and disassemble the laptop to solder it in yourself.
In both cases the cost should be fairly inexpensive.
Please post back if you require anymore assistance.
Regards.
Jan 06, 2010 | Fujitsu Lifebook C1020 Notebook
How to replace power socket connected to the mobo in Gateway 4540?
You have to strip it down, remove motherboard, desolder old DC socket and solder new DC socket in.
If you never done soldering, then i not recommend to do it by yourself, otherwise go ahead - it's not very hard.
Unfortunately i can't find any instructions how to strip it down, but you can get replacement DC socket here
Aug 02, 2009 | Computers & Internet
Amilo Pro v2065 shuts down when battery is plugged
you need do check:
1) no charging means adapter input problem, first check your adapter DC output voltage is ok
2) check DC jack socket on the motherboard:
--- DC socket any pin disconnected, you need use iron and flux to fix it
--- DC socket damage(broken),you have to change it
3) if DC socket connection normall, the DC/DC circiute near around DC socket some component damage, you need find a technacian to repair.
hope help you to deal it well
May 14, 2009 | Fujitsu Siemens AMILO Pro V1000 Notebook
Intermittent dc jack connection for Gateway mx3215
Here is how to disassemble Gateway laptop,
Here is replacement DC socket (needs soldering),
Here is DC board (no need soldering, but expensive).
Hope this helps.
Mar 17, 2009 | Gateway MX3215 Notebook
Cpu chip fan
This sounds as if the motherboard arrived with some form of issue. It has been happening quite frequently with ASUS boards recently. The retention bracket which connects the heatsink/fan to the CPU? If so, yes, it should be connected to ensure the processor remains cool. You are correct, you will need a DVI-HDMI cable. Not to worry, though. They have become quite popular recently.
Let me know if you have any other questions.
Mar 11, 2009 | ASUS A8N-SLI Deluxe Motherboard
HP Compaq Presario CQ50-103NR Notebook PC Logo
57 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
