Question about Lite On LH-20A1H DVD RW Dual Layer Burner
Open-close tray swithc
I really like this burner but lately I have to depress the open-close switch for the tray numerous times before it will open. I hear it clicking (the switch itself) but it doesn't initiate opening.thanks for any help.
  • Jim Lawson Jan 09, 2008
    Hi Craig........thanks for the reply. Any ideas where to get repairs done. I live in a small town without much support for these items. Or could this be a do it yourself project. thanks again, Jim.
  • 34 Answers
The only way to solve that problem is to replace the belt to eject the tray
Posted on Jan 09, 2008
I have an older dvd player that has always worked great. Lately when I open it, it doesn't want to stay open and closes the door again, right away.
There are two small switches under the tray, one to say it's open and one for close to activate the laser, these can be dirty or faulty
Oct 20, 2014 | Televison & Video
DVD Tray will not stay closed
There is a leaf switch inside the loading mechanism, which detects the tray to fully closed state. If this switch has damaged, this kind of fault will occur. To repair it, you have to open the set, and take the loading mechanism out, and disassemble it. If you wish to get some details, check the site linked here.Pull up older posts.
Dec 06, 2013 | Haier TDC1314S TV
followt this step and fix it. God bless you
However there are a small hole in the CD/DVD burner use clip and make click and open it.
  1. Open the housing by removing mounting screws and anything blocking the tray. Press the open/close control to the extend tray, then unplug the unit. To remove a clip-on tray front, brace the tray and slide the panel to one side.
  2. Unplug cables between the front panel and the interior. Remove any screws securing the front panel and remove the panel. If it won't move, check beneath it for clips or additional screws.
  3. Remove the hold-down on top of the disc tray and gently pull the tray out of the player. Clean the travel rail and guides with a swab dampened with denatured alcohol. Lubricate lightly with white lithium grease.
Remove the drive belt (using gloves or tweezers) to inspect for dirt, water, or damage. Clean with a lint-free cloth moistened with denatured alcohol. If the belt is damaged, replace it. Service a DVD tray motor:
  1. Unplug the player and test the motor with multimeter
  2. Unplug the motor plug and spray it with electrical contact cleaner, then plug it back in.
To remove the motor, unscrew or depress the end of each bale and lift out the motor. Replace the motor if necessary.
Nov 23, 2013 | Computers & Internet
Dvd player ejects automatically
its not locking there is a switch inside that tells it when the tray is closed. if it dont read this switch then it will open back up thing something is stopping the tray from closing. some times if it does close with out a disc in then it is the laser asmbley is not moving with the tray movement and tou will need to find out why.
Sep 15, 2013 | LG Computers & Internet
CW088D CD-RW Tray ejects with CD in it but not empty
If the tray retracts but doesn't close 100% then it will open back-up. If it is closing fully then returning open then it is a bad drawer switch. It's hard to get to but if you do get in there, a little WD40 lube might help it actuate. Good luck!
Mar 15, 2010 | CyberDrive CW088D CD-RW Burner
I have a Lite-On DVD writer that will not open unless disk is in.
The problem is with ur DVD Writer Tray, Some of the reason ur dvd writer tray get jammed. For the temporary purpose you can use the manual eject pin hole Technique.
Nov 07, 2009 | Computers & Internet
No Response To Open Button on Remote
I had the same problem- the door would not open.
I opened up the unit removed the drive and discovered a lever which allows to manually eject the tray. After playing with this a bit, I discovered that if I hit open on the until and depress this lever, it would open reliably. Not ideal, but at least it gives me ability to open/close.
Unfortunately once I put the unit back together, it no longer recognizes any disks. I must have damaged some disk sensor mechanism in the process. On the bright side however, it open/closes reliably now, doesnt even require the lever to be depressed manually. So if I can just get it to recogize disks, I am in good shape again.
You may not need to open up the unit and remove the CD burner to get to the manual lever, but you have to remove the fancy cover plate for the tray to be able to access the lever. The cover plate on mine is silvered and says "All write". The lever is on the underside of the tray to the left side, a paperclip might be able to poke thru to access it without removing the whole front cover.
Good luck.
Dec 27, 2007 | Lite On LVW-5005 DVD Recorder
Burner not igniting
The switch is just behind the nob WB24K10003 SWITCH-BURNER VALVE you will have to open the top and remove the manifold panel to get to them. let me know if this helps
Aug 25, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Lite On LH-20A1H DVD RW Dual Layer Burner Logo
115 people viewed this question
Top Lite On Computers & Internet Experts
John Anderson
John Anderson
Rommel Balcita
Are you a Lite On Computer and Internet Expert? Answer questions, earn points and help others
