Question about 2wire 2700HG-B Router (2700HGB)
Cant remember passkey for wireless laptop connection
  • 68 Answers
If you hook into the router with a wired connection, youu should be able to get into the router setup menu to find the passkey. If you can't remember the access for the router menu, you may have to reset the router and redo setup.
Posted on Nov 14, 2009
Wireless conection
To enable or setup the wireless on a modem router you usually have to connect the computer to the router with a lan cable first, go in to the routers settings, most routers use the web browser to access the settings but read the manual for the correct procedure. Then you put in your account details supplied by your internet service provider.
Enable wireless and apply security settings like a wep key, wpa, or wpa2 passkey. Restart the router, remove the lan cable and you're done.
When any wireless device tries to connect it will need the wep key, wpa, or wpa2 passkey to be entered to allow access.
Feb 19, 2012 | Computers & Internet
Do not know passkey. Where can I find passkey?
The network security key (passkey) is the router's wireless encryptionkey.
To connect to your wireless router, it needs the router's wireless settingsconfigured ie SSID, WPA or WPA2 encryption key and also the wireless cards inall the laptops and or computers needs to be configured with these router'swireless settings. Then the laptops and desktop computers can communicate withyour wireless router.
Feb 20, 2011 | Samsung Computers & Internet
Trying to sync with my blackberry 8900 asking for numeric passkey for my plantronic 220 ... dont think I needed this when I had a Motorola Razor.... annoying.... any thoughts.
the passkey is just like a password which is a single time entry into your phone for connecting blue tooth devices in a secured way.
once you enter the passkey the phone will be able to identify and connect to your device each time you search for blue tooth devices in the phone.so please do not get annoyed, go ahead and give a passkey of your own choice(like birth date. so that you wont forget it easily since you wont use it again until you reset the phone or connect other devices).
this passkey can also be used to connect it to laptops, desktops if they have blue tooth.
also remember this passkey is used to restrict any unauthorized access to your phone.!!!
should you have any questions please write to us again.thanks for contacting fixya !
Oct 23, 2009 | Plantronics Explorer 220 Bluetooth Headset...
Cant connect to the internet on my laptop
HI! I bliv u are having some issue setting up ur router.. I will be more than glad to assist u. . here are the steps u need to do:
1. connect the ethernet cable to port1 of the router and the other end to the lan port of your computer..
2. pull up ur browser then type at the url:192.168.1.1. or u can check the routers default gateway by right clicking the network icon on the lower right of your task bar and click on status and it will show the ip address of the computer, subnetmask and default gateway, the default gateway is the routers ip address, once u type in to the url, it will ask u the username and password, by default the username is admin and the password, just leave it blank
3. it will show the setup page of the router. u can set the router on the specific internet setup that u have. look for the wireless settings once u are on the wireless settings of your router, it will show the type of security and the password that you create..
if you have any querry pls feel free to get in touch.. good luck
Sep 01, 2009 | Linksys BEFW11S4 Wireless-B Broadband...
I have installed wbr-1310 to main puter but cannot install on lap
Make sure the wireless capabilities are turned on on your router.
On your computer scan for available networks and it should detect the router.
Once detected it will ask you for the Passkey/WEP/Secutity Key.
You should have a note of this when you originally set up your wireless connection.
If not then your computer network set up wizard may 'kick in' and just follow the instruction.
Remember to keep a note of your PASSKey/WEP as you will require it in future
Good luck
Jul 19, 2009 | D-Link 802.11g Wireless Router WBR-1310...
I don't remember my broadband security enabled passkey
Run this program to see the wep key (you have to do it on the computer that has access)
http://www.nirsoft.net/utils/wireless_key.html
Nov 19, 2008 | D-Link 802.11g Wireless Router WBR-1310...
Aspire 3000 laptop
Normally you setup a passkey or use 0000 or 9999 as a passkey.
The question is, does that pop up when you try to connect a USB device? Do you get that when you try to install the dongle? (That shouldn't happen). If you are trying to connect a PDA or cell phone, you setup the passkey for the connecting device on the computer then type it in to the PDA or mobile phone. If you are trying to connect a bluetooth headset, then you use whatever code is from the manufactorer. Normally this is 0000 or 9999.
Hope this helps!
Oct 18, 2008 | Adapters.com Bluetooth USB Adapater, USB...
Cant connect PC after encription
You may have a setting on the router that limits the number of authenticated wireless connections at one time. You will have to enter the web utility and check the wireless settings, particularily the security settings.
Apr 14, 2008 | Belkin (F5D7230-4) Router (587009)
Cannot connect the wireless,. only cable
pls go to control pannel u will see wireless icon double click on it, follow the instructions, use it, it will help u to setup wireless network
Dec 14, 2007 | Sony VAIO PCG-K25 Notebook
2wire 2700HG-B Router (2700HGB) Logo
172 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Bruce Silvernagle
Bruce Silvernagle
Level 1 Expert
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
