Question about HP Pavilion a1610n PC Desktop
I am having problems with the network interface card. Having problems pulling up my emails and opening other sites. How can i solve this problem?
  • tech_babee Nov 14, 2009
    I will let you know soon.
  • 4,281 Answers
First make sure ethernet driver working fine .
Reinstall lan driver again.
Sometimes firewall issue create this issue.
So check your windows firewall or antivirus firewall.
Make sure 110 port is open for pop3 and http port 80 is open.
Sometimes in router some sites block so check in router to.
For access router try below link
http://192.168.1.1
or
http://192.168.0.1
type user as "admin" and password as "admin" or blank or "password"
then you can see configuration page of router.
Posted on Nov 14, 2009
No connections are available windows 7 but computer connected with network as well.
Boot the machine at first. If the problem still remains, make sure you have installed latest network card drivers from manufacturors site. You can also try to disable the network interface card, then enable it.
Aug 14, 2012 | Dell Precisions Workstations T1600...
My us 122 usb audio/midi interface want down load
Hi, I realize now that if I unplug the tascam from the computer and plug it back in after it's been asleep, it's starts up again without having to shut my mac down. So I've solved my own problem. Thanks!
Aug 28, 2011 | Tascam US-122 USB Audio/MIDI Interface...
I am having problem getting the Web site feature for remote access to the switch.
if the switch doen't display the Web interface, you might have 2 issues.
1) network port 443 is closed on your network... open it and test again.
2) the DSR was part of a DSView setup and has a Security Certificate and the Web Interface is blocked internally. To clear this you will have to access the Console (Comp port) and go into Security and Unbind from DSView, or clear Security Token (Depending on Firmware).
I hope that helps
Mar 17, 2011 | Avocent (DSR4010-AM) 4-port KVM Switch
My computer comes on n gives me an error message saying UNDI Intialized failed, no media detected.
Hi, UNDI is a shorthand for Universal Network Driver Interface.
CAUSE OF ERROR: It sounds as if you are having some trouble with your NIC {Network Interface Card}.This error message can occur if no network adapter is detected in your computer or if no connection to the network is detected when the network adapter is initialized.
RESOLUTION: To resolve this issue, perform network troubleshooting on the hardware.Check the network adapter cable, cable type, hub, router and so on.Also check the computer's BIOS settings to make sure that the network adapter is disabled.Try logging in safe mode and then disable your NIC in control panel.Reboot and see if that solves the problem.If it does you can start looking around for an updated driver or perhaps a new card.Enter the safe mode by pressing the F8 keywhile booting up. Also try doing a system restoreto a earlier point.This also fix your problem.
Thanks for using fixya....Best Wishes...Wish you a happy New year..
Dec 31, 2010 | Dell OptiPlex GX150 PC Desktop
Pls. help us,how can we used land cord to connect printer konica 7035 to computer. we already down load a driver from internet . we try many times to check sa IP address and test print but still we cannt...
Using arp command (UNIX)
From UNIX you can use the arp command to assign the IP address to the network interface card.
Perform the following procedure:
1. Turn off the print controller and the main body printer.
2. Log in as superuser on a host on the same subnet as the network interface card. However, if
the server resides on another subnet, complete this procedure to store the IP address in the
3. Find the MAC address of the network interface card. The address is printed on the Status Page
each time you turn on the print controller and the main body printer.
4. Edit the hosts file (usually /etc/hosts) or use NIS or DIS to add IP address and node name of
the network interface card. See the network administrator for the IP address. For example, a
network interface card with a name of printfast and an IP address of 192.9.200.200 has the
entry:
192.9.200.200 printfast
5. Add an entry to the arp cache for IP address and Mac address of the network interface card,
as:
arp -s 192.9.200.200 0:40:c8:0:0:ff
RS6000 (AIX) requires the ether option after arp -s. For example:
arp -s ether 192.9.200.200 0:40:c8:0:0:ff
6. Check the print controller and the main body printer to see that the network interface card is connected
to the network. Turn on the print controller and the main body printer.
7. Send a ping command to the network interface card to verify it is running on the network, as
for example:
ping 192.9.200.200 or ping printfast
The network interface card will not respond to this ping command but it will read its IP address
from the packets.
8. Turn off the print controller and the main body printer and back on again and then send the
ping command again to verify that the network interface card obtained its IP address. A confirmation
message displays as:
192.9.200.200 is alive
9. Remove the entry from the arp cache using the following command. Specify the network
interface card either by its IP address or by its name, for example:
arp -d printfast
Konica Network Interface Card INSTRUCTION MANUAL 2-5
Chapter 2 Setting Up the Network Interface Card
Using MAP
By using MAP (Management Access Program) included the CD-ROM that comes with the network
interface card, you can automatically identify the network interface card on the network and set it up
for TCP/IP by using Web Utilities. To use this method to assign the IP address to the network interface
card, the following procedure should be performed on computers in advance:
• TCP/IP correctly configured
• IPX/SPX-compatible protocol installed
• MAP installed and MAP setup correctly executed
About how to set up TCP/IP and how to install IPX/SPX-compatible protocol, refer to Windows Help
menus for example. For MAP, refer to “Using MAP (Management Access Program)” in this chapter.
To change an IP address already assigned to a network interface card, you can not use the
arp command. Use Web Utilities instead. These methods also allow you to set up subnet
mask and default gateway, etc.
Using NIManage
Refer to “Chapter 7 AppleTalk Configuration”.
 Accessing Web Utilities
The network interface card is provided with an HTTP server having Web Utilities. By accessing this server,
you can change settings of the printing system. There are two ways to access Web Utilities, through a Web
Browser, either through Netscape Navigator, version 4.x or greater or through Internet Explorer, version 4.x
or greater.
• Use MAP to have the network interface card on the networks identified automatically, thereby accessing
Web Utilities.
• Use a Web Browser to type the IP address assigned to the network interface card, and thereby access
the Web Utilities. For example:
http://192.168.0.128/
If you designate the proxy setting in your Web Browser you cannot access the Web Utilities.
For more information see your network adminisrator.
2-6 Konica Network Interface Card INSTRUCTION MANUAL
A utility called MAP is provided on the CD-ROM that comes with the network interface card.
This program automatically identifies the network interface cards on the networks and lists them on Web
Browser screen. From this Web Browser list you can select a network interface card to change its settings
and control Web Utilities.
Aug 31, 2009 | Konica Minolta Office Equipment & Supplies
GET A MESSAGE: NO INTERNET CONNECTION DETECTED
Check the network interface card where the RG45 network cable plugs in, and verify that both the amber and green lights are on. One normally flashes the other stays lit. If not? Check the router/switch/modem for light activity where the same cable is plugged into. Also try uninstalling and reinstalling the network interface card device in Device manager. Reboot after doing so to see if that fixes your problem
Jul 26, 2009 | Computers & Internet
I was told by my isp that I need to uninstall and then reinstall my network interface card. How do I do this?
Go into device manager (control panel, system, hardware, device manager). Under network connections, right click your network interface card and select uninstall. Reboot the computer and it will automatically reinstall.
Jun 14, 2009 | E-Machines eMachines Desktop PC
Dwl-520 PPPoE problem
Besides the DHCP/PPoE issue that cnavarro already said, I recommend you to check the interface metric, click on start, then on run, type cmd and click on ok
then in the black window type "netstat -r" that will tell you the metric of each interface according to each network destination, depending on what you see in there (like windows looking for a network trough another device) then just change the metric to 1 in your dwl520.
here is how to do it http://www.windowsreference.com/windows-2000/change-the-interface-metric-on-a-network-adapter/
Apr 18, 2009 | D-Link DI-514 / DWL-520 Kit...
My gateway gt5432 wireless interface is not working
Go into the device manager and uninstall (right click and choose uninstall) the network card, reinstall it by chooseing actions, scan for hardware changes (in the device manager). Its an Ip address conflict probably. or open a command screen by typing cmd in the run dialog and then type ipconfig at the curser. See if you have an Ip address, if not type in ipconfig "space" /renew. This will give your computer a new ip addy. Good Luck!
Mar 21, 2009 | Gateway Computers & Internet
Aardvark Problem
You are looking for: "6' length, custom 25 pin shielded cable" Try on shopping.com or Amazon...: http://www.shopping.com/xFS?KW=custom+25+pin+shielded+cable&FD=0 You will find it there.. Good Luck. K.
Sep 10, 2005 | Aardvark Direct Pro Q10 (bundle) External...
HP Pavilion a1610n PC Desktop Logo
24 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
