Question about Motorola Mobility HS850 Consumer Headset
Can't get the HS850 to pair with my blackberry
I have a Blackberry Curve and just got the HS850. I follow the steps exactly, but my blackberry picks up my computer, my camera, and my printer, but not the HS850 headset. I have tried going away from all other devices, have repeated turning off and back on. Nothing works. Did I just get a bad device? Please Help. Thanks, Tara
  • mziwamadoda Feb 20, 2008
    Mine can not pair with my phone anymore
  • Anonymous Mar 25, 2008
    Yes, I am having the same problem. I cannot get my Motorala HS850 to pair with Blackberry Curve. The phone does not find the device. I have been able to pair with other Bluetooth headsets...
Solution #1 worked. I pressed closed Bluetooth, then when it lit up immediately opened headpiece for pairing. I already had my blackberry ready to discover devices, then I hit discover on the blackberry. It found the HS850; I entered 0000 on the Blackberry, and it paired!
Posted on May 31, 2009
I was having the same problem and found the following help from the blackberrycool website:
Pairing is a bit clumsy with the Motorola HS850. It involves pressing and holding the call button while the microphone is folded closed, then quickly opening it up once the blue LED comes on to put the phone in discoverable mode. The headset is capable of pairing up to eight devices and provides BlueTooth 1.2 support.
Posted on Apr 19, 2008
    Genius:
  • 1,003 Answers
Device is not bad blackberry has a compatibilty issue with this headset try plantronics brand go to www.n1wireless.com
Posted on Jan 15, 2008
When trying to connect my mobile via bluetooth to my car phone it says sim rejected why ?
We suggest you to reinsert the sim once again and check for the same. And try to perform the following steps: Apply the Bluetooth Pairing Helper application to your BlackBerry smartphone. Download the Bluetooth Pairing Helper application file using your BlackBerry smartphone browser Note: The Bluetooth Pairing Helper is available for BlackBerry smartphones running BlackBerry Device Software 4.2 and later. Complete the following steps for the Bluetooth Pairing Helper software. The following steps use the Land Rover as an example. Place the vehicle into pairing mode. For instructions, see the vehicle user manual. Start the Bluetooth Pairing Helper application. See links above. The following message appears on the BlackBerry smartphone: Please initiate the pairing process on your car. Click ?Done? when pairing is complete On the vehicle, press the Dial button. The following message appears on the Land Rover, and the progress bar on the Bluetooth Pairing Helper Application begins to advance: Searching The Land Rover display lists the name of the BlackBerry smartphone (and any other Bluetooth devices found within range). This may take one or two minutes. On the vehicle display, use the dial to highlight and then select the BlackBerry smartphone. The vehicle displays a random personal identification number (PIN) to pair. When the BlackBerry smartphone prompts for a PIN, type the PIN shown on the vehicle display in step 8 and press Enter. The BlackBerry smartphone displays Pairing complete. Connect to and press Yes. Pairing completes and an Connection to vehicle succeeded should appear on the BlackBerry smartphone. If the Bluetooth Pairing Helper application does not close, click Done to close the application. If you find the same error as sim rejected even after performing the steps, you need to check with the service provider relavent to the sim problem.
Oct 18, 2009 | RIM Blackberry 8310 8320 8330 Curve 8100...
Blackberry Curve 8310 won't pair!
Go to this page, it will answer any question concerning the blueant .. including pairing to your phone .. activating your blueant etc http://www.blueant.com.au/index.phpalso gives you step by step instructions on codes, pairing etc
Jul 26, 2009 | Blueant Z9i Bluetooth Headset
Won't pair with Motorola HS850 headset
How to pair a Motorola HS850 bluetooth headset How to place a Motorola HS 850 bluetooth headset into paring mode:
  1. Close the boom to turn the unit off.
  2. Hold down the call button until the blue light comes on.
  3. While holding down the call button, swing the boom open.
The headset is now in pairing mode, and you can search for it using your phone. When it asks for a PIN, use 0000.
Apr 20, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
Blackberry curve won't pair with my bluetooth headset
Try the following. Hope this helps.
Okay,
1. Go into "Media" on your BlackBerry and enable incoming files (Menu-->Receive using bluetooth).
2. Find the file on your friend's device that you wish to send, and beam the said file accordingly.
2a. If you have not "paired" (created a friendship between) the two devices before, you will need to do this first...
2b. One of the devices will ask for a PIN code first and on this device you need to create a four-digit, numeric password that can be anything you like.
2c. On the second device, enter the four-digit, numeric password you created and follow the simple, on-screen prompts on both devices to complete the pairing (you can also pair the devices in advance by going into Menu-->Set Up Bluetooth).
2d. Depending on the devices being used and the time taken to complete the pairing, you may need to re-send the file (go back to step 1), otherwise, continue below...
3. When your friend's device tries to send you the file, your BlackBerry should ask you to name the file and where to save it; if you have not set the device as "trusted" in the bluetooth settings (Options-->Bluetooth-->your friend's device), you may need to approve the file transfer first though.
4. The file should now be on your device.
Note: by default, all
* Pictures are saved into /Device Memory/home/user/pictures or /Media Card/BlackBerry/pictures if you have a memory card.
* Sounds (including songs) are saved into /Device Memory/home/user/ringtones/ or /Media Card/BlackBerry/ringtones/ if you have a memory card.
* Videos are saved /Device Memory/home/user/videos or /Media Card/BlackBerry/videos if you have a memory card.
In other words, unless you specify somewhere else in step 3, this is where you will find your file.
And remember, your incoming file transfer WILL NOT WORK UNLESS YOU FIRST "PAIR" (CREATE A FRIENDSHIP BETWEEN) THE DEVICES, go into Media and CLICK MENU-->RECEIVE USING BLUETOOTH!!!
Jan 28, 2009 | RIM BlackBerry Curve 8310 Smartphone
I can't find my instruction book for the Motorola Headset HS850.
Just google the instructions. Should get a pdf option to download ??
Nov 07, 2017 | Motorola Mobility Universal Wireless...
Motorola hs850 bluetooth headset won't pair with Blackberry Curve
try to delete it out of ur phone all the way and then try to pair it again
Dec 15, 2008 | Motorola Mobility HS850 Consumer Headset
I have a blackberry curve and am wanting to pair my bluetooth HS850 to it. Please help!
There actually is a trick to the HS850 - flip the boom closed, then hold down the button just until the light holds solid - IMMEDIATELY after it does flip the boom open and this should keep the light solid. Then on your cell/device search for bluetooth devices - you should be able to find it now. Passkey for most devices is 0000.
Jun 30, 2008 | AT&T Blackberry Curve 8300 Smartphone
My bluetooth passkey
Passkey 0000 worked for pairing my Motorola HS850 and my Blackberry 8800. Thanks!
Dec 12, 2007 | Motorola Mobility HS850 Consumer Headset
Motorola Mobility HS850 Consumer Headset Logo
297 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
