Question about Hoover SteamVac F5914-900 SpinScrub Upright Vacuum
The hose has a hole in it and the red ball keep shutting it off. Model F581-900 I have another Hoover SteamVac that is broken too. Where can I get these fixed, I live in Crown Point, IN. Thanks Valerie
    President:
  • 3,085 Answers
I have a tube of Goop used to repair shoes. Using a rubber glove with a moist finger apply Goop (won't stick to glove then) over hole and allow to dry for 24 holes. Fixed my problem.
Posted on Nov 19, 2009
How doI hook up furniture/stairs attachment
Hoover Steamvac Spinscrub - How To Attach Hose and ...
? 2:54
https://www.youtube.com/watch?v=XTgoEezUlRs
Mar 13, 2011 - Uploaded by Doug Weeks
... spin tool. Used for stairs and stains etc. hand held. ... Hoover Steamvac Spinscrub - How To Attach Hose and Spin Tool ...Every time I attach the upholstery and then turn the vacuum on, water begins to leak from the bottom.
Hoover SteamVac Connecting Hose & Tools F5915900 ...
? 1:41
https://www.youtube.com/watch?v=heAeez1YlFc
Nov 23, 2011 - Uploaded by HooverVideoGuides
How to properly connect the hose and tools ... Hoover VacuumVideo Guides ... I cant get the water to come out the water isnt coming out the spray part to scrub my furniture ... Get Best Price for Hoover SteamVac Carpet Cleaner here ... for the love of god when not using the hand tool where on the machine ...
Hoover SteamVac Connecting Hose & Tools F5912900 ...
? 1:41
https://www.youtube.com/watch?v=fPU9pXgNo98
How to properly connect the hose and tools ... Hoover SteamVac Connecting Hose & Tools F5912900 F5914900 F591... ... Hoover Vacuum Video Guides .... Hoover Steamvac Spinscrub - How ToAttach Hose and Spin Tool ...
Jan 09, 2016 | HOOVER COMPANY Steamvac Deluxe
I need to replace my hose to my steamvac model F5842 can you help? Ordered a hose but I don't think it's the right one
Hi Chris,
Your Hoover SteamVac model F5842 needs the Hoover SteamVac replacement hose part number 40309007. You may find a link to the correct hose for your model below on our website:
Hoover SteamVac F5842 Replacement Hose Assembly
In terms of replacing the hose, this is an older style SteamVac, which attaches the hose to the front of the Dirty Water Solution Tank.
Here is are instructions on how to attach the hose to your machine:
http://www.fixya.com/support/t4699742-dont_manual_u_connect_hose
Hopefully this was helpful, and answered your question. Please don't hesitate to request a clarification, or add a comment if you have any further questions or concerns.
Thanks,
Chris Jones
Oct 07, 2011 | Vacuums
Re hoover 5914-900/the yellow ball keeps automatically sealing almost as soon as turned on/the mesh filter appears to be clear
Be sure to leave a gap of about 3/4 of an inch between the top of the filter, and the lid of the tank. Without this gap, the ball will shut off the suction prematurely.
Apr 04, 2011 | Hoover SteamVac F5914-900 SpinScrub...
Hoover carpet cleaner won't dispense solution or water. Everything else works.
1.Remove bottom tank and look for pinched hose. 2.Use small screwdriver or toothpick on small holes which disperse solution-remove rotating brush first. These were problems with my steamvac (f5861-900 model).
Mar 16, 2011 | Hoover SteamVac Carpet/Upholstery Deep...
My hoover steamvac wont **** up dirty water float
Check your filter screen insde the upper tank. if your model has a wrap around filter try to pull it down about 1/2" to maximize air flow.
Apr 15, 2010 | Hoover F7431-900 SteamVac Vacuum
The red ball pops up periodically; why is that?
The red ball is the float/shutoff for full tank. That prevents water from overflowing and being sucked in to the vacuum motor. When the float shuts off the vacuum to the tank, the tank needs removed and emptied of dirty water. The float may get activated prematurely if the foam sock around it is dirty. It may be removed and rinsed.
Oct 30, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Ball bearing in brush roller
These can usually be purchased thru a hoover dealer and are not expensive.
Mar 11, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Hoover steamvac
What is you model number??? Is the hose ok and not broken where it goes into the motor? If it is then you will have to replace the hose asm.
Jul 24, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover steam vac
I had the same problem just before the impeller broke. Lower the handle and check the hose connection at the bottom is not broken. Turn the unit on with the handle down, then check the suction on the accessory hose, leae it disconnected. Take off the bottom container, and check the suction on the round intake tube (lower one towards the front), with the handle up and with the handle down. If the suction increases dramatically when the handle is lowered, the impeller is probably in it's self-destruct stage. (same as mine). Soon the impeller will break off, and BINGO no suction at all.
Jun 25, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover SteamVac Model F6056-900 SteamVac/SpinScrub. Indicator light and high pitch suction noise indicates that dirty water tank is full. However, water level indicator (yellow bobbing plastic thing) is...
There are 2 filters, make sure they are clean, one is on the tank lid, the other is from the bottom, it is red, pull it out and clean it. If yours has a foam filter on the tank lid covering the yellow ball, make sure there is at least a 1/4 in. gap from the top. Also make sure that the lid in on and secured tightly.
May 26, 2008 | Hoover Vacuums
Hoover SteamVac F5914-900 SpinScrub Upright Vacuum Logo
74 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
