Hi.
Test and eventually replace the Dryer thermal fuse
The fuse is located on the blower wheel cover.
The fuse can be tested using a multimeter.
If the fuse has continuity , then is good.
Test the heating element and the thermostat Thermal cut-off .
Both are tested using a multimeter to read impedance. Set multimeter at Rx1, on Ohms.
To test the element disconnect element and point tester probes at element contact.
If there is no continuity, and the circuit is open, then the element is faulty.
The thermostat can be tested jumping its wires to bypass it, but there are many safety concerns doing this kind of test.
Better disconnecting the thermostat and reading Ohms, as for the element.
At
room temp the thermostat must have low impedance, if it goes to
infinity, and circuit is open at room temperature, then the thermostat
is bad.
If both test good, and you have no heating at all, then it may be a bad electronic control, or a wiring problem.
All test and repair must be done by a technician.
If you need to contact a technician you can call the number listed on the owners manual.
