Question about Canon imageCLASS D320 Digital Copier
Crinkly noise There has been a crinkly noise just before the paper feeds through the copier. Now there are also broad striped lines down one side of each copy.
  • ridgewoodcrc Nov 15, 2009
    Thanks! It may just be cheaper to replace the whole copier. It's great to know what the noise is, though.
  • Canon Expert
  • 1,326 Answers
The noise is coming from the fuser film. You will need to have the fuser replaced to solve the problem. You may have to call a service company to replace it for you.
Posted on Nov 15, 2009
What could the Grinding noise be that is coming from Ricoh Aficio MP C2550 for each page copied/printed?
Check for:
-broken plastic gear on right side of copier
-paper or foreign object in paper path
-paper or foreign object near fuser
Oct 15, 2014 | Ricoh Aficio Mp C2550 Copier With Feed,...
Panasonic dp3010 copier stripes on paper
Not exactly sure what you are asking but if the problem is that you are getting fine lines down the paper (the copy is ok though) then take a real close look atr the glass platen (the plate glass in which the paper goes on. Assuming you are using the ADF (Automatic Document Feeder) area. This area is usually about an inch wide by 8.5" long. Look for either "White out" or black ink on the glass (it can be as small as a dot) clean this mark off with glass cleaner and you problem will be solved. Sometimes it helps to orientate your copy with the line on it to the machine to locate the mark causing the issue.
Good Luck!
Mar 01, 2012 | Office Equipment & Supplies
Broad dark line on right edge of copied papers
If you have the black line on copies and scans but printing from P.C is fine, then your scanner is broken.
Contact your printer manufacturer for a replacement or repair.
May 12, 2010 | Office Equipment & Supplies
Lined Copies
If the line is only when you feed the original from the top feeder (not when you place the paper on the glass)....clean the narrow glass (called the **** glass) under the feeder on the right hand side
If that is not it new drum and/or blade is called for
Oct 28, 2009 | Sharp AL 1631 Copier
Officejet d135 Copier copies in 1/4
try to reinstall the driver of the printer, if nothing happen.
your problem in feed of the paper check the feed roller grears,
May 06, 2009 | HP Officejet 5610 All-In-One InkJet...
Sharp AL1631- Paper will not feed through
First off I seen these problems so many many times as an sharp dealer, I think I may drop the support however, the reason why your are getting the misfeed is beacuse your paper feed tires are worn and need replacing, r u in Ct f so we can helpif not call your indepenant dealer , remember Staples will not support this machine, and tell him your paper feed tires are bad and needs replacing
the Noise could be anything let's fix one problem at a time ok.
Mar 06, 2009 | Sharp AL 1631 Copier
HP Officejet J5780 All-in-one Injet prints a grey line down the right side of the page when copying using the automatic document feeder. It does not show up when printing; and it does not show up when...
lift the feed area and look at the small glass plate where the auto feed paper is actually scanned. That needs a good cleaning. Since the paper runs across it even a tiny little obstruction such as paper left from a paper jam or a dot of ink from that pen you used to unstick that last paper jam (maybe its just me??). That one dot turns into a line when the paper rolls across it. Clean well and the line will dissappear.
Feb 27, 2009 | HP Officejet J5780 All-In-One InkJet...
Grinding noise when printing and cuts paper
There may be something stuck in the area of the perforation, like a paper clip, paper debris or some foreign material. I would look in that area with a flashlight and see if there is something in the Paper feed roller area.Something may have come loose if you had a paper jam. Let me know.
Please remember to rate all users who assist you for free :)
Sep 30, 2008 | Lexmark X5470 All-In-One InkJet Printer
Canon PC920 paper feed "clacking" & not working.
check the tray and make sure the guides are set correctly, clacking sound is usually because the tray is set for Legal and has Letter, the paper is towards the bac of the tray and the pick up assembly is making the noise,
otherwise the tray is either not going up (broken gear, )
Aug 22, 2008 | Canon PC-920 Black and White Copier
Canon imageCLASS D320 Digital Copier Logo
131 people viewed this question
old marine
old marine
