Question about Element Electronics FLX-1910 19 in. LCD HDTV
Program Blocked errors
I continue to get a "Program Blocked CE-14+" error. The program that i am watching blinks out to a blue screen with the error in the middle and then the program comes back on. In addition to the "CE-14+" number there are several other combination's that i get as well, "CE-PG", for example. It does not seem to be specific to channel or program.
I was having the same problem with the constant blue screen appearing with different error codes. Here is how I fixed the problem on my Elements 19": I did a channel search. I found there were 68 analog channels and 274 digital channels. On a hunch, I went into Skip Channels and checked off all the digital channels since I have basic cable. Although the tv is HD and did pick up the basic HD channels, I choose to skip those two since I do not have a cable box on that tv and only the basic channels were in HD (about 8). I watched my tv for two hours and blue screen appeared once every 30 minutes, but the next day it did not appear at all.
I concluded that those error messages are because those channels are blocked and we have not checked them off to be skipped. When checking the Skip Channels, as you highlight each channel it will either come in or it will not. You will find the "Blocked Program" errors are coming from channels that do not come in and you will need to skip those channels.
I hope you can understand how I solved my blue screen problem on my Elements tv. Good luck!
Posted on Aug 28, 2012
  • Words of Wisdom Oct 22, 2012
    Disregard my above post. Here is the solution to your Elements television blue screen:
    Click menu to go "setup" tab
    go to "parental" hit enter
    password "0000"
    This will bring up submenu
    select "program block"
    scroll down to "system lock"
    choose off and exit
    This worked for me. I hope it works for you.
  • Words of Wisdom Mar 26, 2017
    Update: Shortly after this fix, the TV died. The repair was as much as a newer TV. I bought the newer TV. Problem solved
No, the problem is not fixed. I do not want to subscribe for any plan. Thanks
Posted on Nov 15, 2009
  • Gary Kilday Feb 18, 2012
    I am having the same issue. Did you ever get this solved?
Blue screen error tried to start in safe mode now wont come on
This is most likely the power supply. It could be some other things but the power supply is the cheapest thing to try unless you have the right stuff to test everything. In reality, it was nothing that you did. The uninstall of the program did not cause this. Also you should check the unit to be sure that it is clean. Dust can build up inside and cause over heating.
Apr 27, 2014 | Compaq Computers & Internet
An error has been detected with a required application library and the product cannot continue. Please reinstall the application.
Basically lot of people are getting errors with Acrobat 7 and older versions as Adobe has disabled the activation server for CS2 products, including Acrobat 7, because of a technical issue.
Go to the Click here for the Link to Download Acrobat
Download the New Copy of Acrobat and Activate it with the new Serial No, however you need to un install the old copy from your computer
Apr 16, 2013 | Adobe Acrobat 7.0 Professional
CHECKSUM CANNOT MOVE COMPUTER FROM A BLUE SCREEN
In order to understand what a checksum error is, it is important to first learn what a checksum is. A checksum is a redundancy check during a computer's start up process, which makes sure that the computer's data is intact and unhampered. The data is scanned and tested for accuracy, either based on how well it relates to data elsewhere or based on previous data that was stored on the same computer. Essentially, all of the bits of data in a particular document or file are added up and a number or hash is created. This number or hash can then be compared to the number or hash generated from the same file on another person's computer or at a previous time on the same computer.
When does a Checksum Error Occur?
Although a checksum error can occur at any time while a computer is comparing data, it is most commonly present during a computer's startup procedure. During a computer's start up processes, the BIOS settings, which are stored in a CMOS memory chip, are computed and then checked against the previous value. If the computed values do not match exactly, the computer warns the user with a checksum error message that the data may have been changed or corrupted between start up cycles. All BIOS programs present a different error and therefore will either continue with booting or refuse to boot until the problem is corrected.
Depending on the type and the severity of the error generated, there may be one of a variety of ways to rectify the issue. The most common cause of a checksum error during the startup process is a faulty battery that is not providing sufficient power to the motherboard when the computer is off. However, motherboard malfunctions and viruses can also contribute to checksum errors.
Other Types of Checksum Errors
Another type of checksum error may occur with any program at any time. It is usual for many programs to now provide checksum information when that program is downloaded. Using a checksum program or MD5 hash checker, a user can quickly compare the checksum of a downloaded program with the checksum that the software developer provides. This is a common way to make sure that users are downloading the proper program and that no data was corrupted during the download process. Checksum errors originating from download errors can easily be corrected by re-downloading the problematic program.
if you have a windows disk you might try doing a repair from disk
Apr 14, 2013 | Dell Inspiron Computers & Internet
Hdmi blocked blue screen
If you are using a box for signal have you unplugged it also?
Dec 22, 2012 | Philips 42PFL3704DF7 42 LCD TV
Blinking a printer screen number h then 4
press on the keypad, # * C * the machine will enter a diagnostic mode. Then enter 14 as if to make 14 copies. You may then have to press 1 and execute the program. But that will clear the H4 code 99 percent of the time. Once you enter 14, just press start and follow the directions on the screen. An H4 means the machine was just slow to warm up. It can be a fuser error, but there actually being a problem is extremely rare. Performing a clear 14 will almost always clear that. It may also be P * C * to enter diagnostics.
Feb 22, 2011 | Sharp AR-M205 Copier
Windows 7 Blue screen at start up. Shows "Starting Windows" then memory dump/ blue screen. Recovery = No points created by the owner. Roll Back = Tried the 3 points for installs which all still...
Operating System does not respond is the major problem.
This is a very commonly faced error by the users of the Windows 7 which leads to the Blue Screen of death to the system. The error message appears on the computer screen in the following form: "Windows Operating System is not responding" along with two options one "Close the Program" and other "Wait for the program to respond". But whenever the user attempts to close the program he comes up with a serious data loss. To solve this problem apply different troubling shooting methods or take help of the technical experts.
Jan 12, 2011 | Toshiba Computers & Internet
Error messages temporarily blocking our programs
Reset your TV to default settings through the menu, go from there.
Feb 07, 2010 | Element Electronics FLX-2210 22 in. LCD...
Error code H5-01 sharp MX2300N
pascale_algu
Its a cause by continuous misfeeding. You better find the cause of that problem.
to cancel the code press program key(P), asterisks, clear key, program key . when the stand by for simulation code appears type 14 to cancel the trouble code.
Good Luck
Aug 13, 2009 | Sharp MX-2300N Color Copier
Sharp Copiers Error code : F1-14
I was making copies through the document feeder and got the F1 error, and it's blinking and I can't make copies. Any ideas? Thanks!!! Christine
Mar 02, 2009 | Sharp Office Equipment & Supplies
Futura CE-100 software
I did and they gave me no answer to the problem. They had told me I could buy a new software disk from them. Buy?!?! I got the disk with my machine! I still can't figure out this problem, I uninstall and reinstall the software everytime I use the embroidery part of the machine. This is driving me nuts..
I am a seamstress and a costumer, having this problem with the machine is bad for my business. If I would have known then what I know now about the machine I would have never bought it.
Jan 13, 2008 | Singer CE-100 Futura Computerized Sewing...
Element Electronics FLX-1910 19 in. LCD HDTV Logo
780 people viewed this question
Top Element Electronics Televison & Video Experts
LP
Are you an Element Electronics Televison and Video Expert? Answer questions, earn points and help others
