Question about Hotpoint Ultima WF860 Front Load Washer
What does f-12 mean on the control panel and how do i get rid of it
    President:
  • 1,653 Answers
The Hotpoint F12 error is a Serial Communication Error.
This is a communication error between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
  1. Check Wire Harness connectors to the MCU, the motor, and Central Control Unit (CCU)
  2. Check the Drive system for any worn or failed components
  3. Check MCU
  4. Check CCU
  5. Check Motor
  6. Check Wire Harness
You may be able to reset it by switchg off the AC power to the machine and leaving it for 30 mins. Then switch back on to see if the error persists.
    Posted on Nov 14, 2009
    J ,m ,mnjv ,vhj mkj
    Posted on Jan 23, 2010
    How do I uninstall unwanted downloads
    Use the uninstall option in the control panel.
    Jan 10, 2016 | Computers & Internet
    How do I get rid of tool bars
    Do you mean you want to hide the Ribbon? That's easy to do. Just click on the down-arrow next to the Quick Access Toolbar in the upper left corner (see screen shot below) and select "Minimize the Ribbon."
    Feb 19, 2014 | Microsoft Word 2007 Home and Student...
    I want to remove ASK
    Go to control panel, and in the search bar at the top, type "Programs"
    Then select "Add or Remove Programs"
    Find ASK and double click it. It should start the uninstall process. (This is assuming you mean the ASK toolbar, not the actual website... Getting rid of the actual website would be incredibly difficult).
    Aug 12, 2013 | Computers & Internet
    Check engine light on & get trouble code 12. I havent disconnected the battery so why the error & how do I GET RID OF IT? Thanks
    depending on , make and model code 12 mean battery disconnect. take it too local auto parts maybe they can erase the code if not dealer. thanks
    Sep 29, 2010 | Dodge Ram 1500 Cars & Trucks
    Whats the best settings to have for best picture with this t.v. meaning brightness,sharpness,ect...
    You should NOT have to turn CONTRAST up to more than 70%....brightness controll should be set MUCH lower......sharpness should be adjusted left or right to get rid of graininess(sp) of picture... turn color all the way down then move up according to how you like colour!
    May 19, 2010 | TruTech PVS31170S1W 17 in. LCD Television
    I have a networx nx-12 (d.a.s.) home alarm and the power light is flashing. What does this mean and how do I fix it.
    This indicates a low battery condition for the main control panel. Replace the battery in the main control. 12V 4-7AH usually.
    Alarmprofessor.com
    May 16, 2010 | Home Security
    Is there any way to turn off the buzzer when the drying time is over...or at least turn it down?
    If the model number you have this listed under is correct, there is a buzzer module located inside the control panel. It is a fixed module, which means it cannot be adjusted. So, if you wish to get rid of the noise, you will have to unplug it. All you should have to do is UNPLUG the dryer and remove the back of the control panel. Disconnect any leads from the buzzer module and wrap them each in electrical tape to keep them insulated.
    If you go to appliancepartspros.com you can view what I am talking about. The buzzer is listed as item 12 under the "Backsplash, Blower and Motor Assembly" heading. When typing in your model number use "DBXR463ED0WW. The digit before the that two letters is a "zero", not the letter "O".
    If you have questions, or if you have not provided the correct model number, pease post back with the correct information so that I maybe able to assist you better. I hope this helps you.
    Oct 15, 2009 | GE DBXR463EDWW Electric Dryer
    Ademco 6128 keypad beeping at random times & says bat on the display screen now - is there a battery in there we need to change?
    you need to change your main control battiery.
    the main control panel takes a 12 volt 7 amphour or a 12 volt 4.5 amphour battery. the larget the amphour the longer the system will last when the power is out. available at fry's radio shack or on line. ps: if the key shows a zone number with the bat, that means you have a wireless sensor low battiery.
    mj
    Aug 29, 2009 | Honeywell 5804 Ademco Wireless Security...
    SONY - PFM-500A2WE 16:9 42-inch Plasma fault 22-12
    According to the Sony Service Manual for the PFM-500A3WU, 12 22 means either the Plasma Panel has failed or the Power Supply has failed. 12 means "warning decrease of panel high voltage" and 22 means "warning of decrease of middle panel voltage".ve had a look on other forums and someone as narrowed the 12/22 code down to the (ic102) its only outputing 5volts its something to do with the (b+ power supply)
    Feb 01, 2008 | Televison & Video
    Hotpoint Ultima WF860 Front Load Washer Logo
    368 people viewed this question
    Top Hotpoint Washing Machines Experts
    vince
    Todd Arndt
    Todd Arndt
    puggy666
    Level 1 Expert
    Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
