Question about Ovens
HOW TO TAKE OF DRYER FRONT COVER - Ovens
    President:
  • Ovens Master
  • 1,922 Answers
Remove the screws on the lower edge near the floor and then raise the cover like a car hood and it unclips at the top
Posted on Nov 14, 2009
I HAVE A DOUBLE OVEN GE MODEL JKP55DPEWW WHITE AND WANT TO REPLACE THE DOOR WITH STAINLESS STEEL,PLEASE HELP
When I removed the front cover there were other color door fronts stored in side. I would just order a SS door front from a dealer or parts supply house
Apr 30, 2014 | Ovens
Fagor oven has error code F06
I cleaned the smoke filter, took of the top cover, in front of electronics is the brown smoke sensor. I took of one wire off the sensor, started the oven (beware of not shortcutting anything) the f06 error message had disappeared. I put back the wire, mounted the top cover and the oven functions like new.
Nov 28, 2012 | Fagor 5HA-196 X Single Oven
Oven will sometime take an hour to get to temp after being turned on. any thoughts?
If your oven is older or you live near the water check if there is a build up of fine rust over the burners. A fine wire brush lightly run over the top of the burners may be your solution. Before you attempt this disconnect electrical power and turn off the gas supply. If you are mechanical remove the front lower cover by opening the doors, removing the two screws located in the top of the lower cover next to the door hinges. The cover will remove to the front. Next remove the screws holding the shield in fromt of the burners. A long handled fine wire brush will allow you to brush the top of the burners. If there is a film of fine rust it will not be apparent when looking. After careful reinstallation of the burner shield and ensuring there is a safe area away from the exposed electrical connections for you. Reconnect electrical power and gas to the oven temporarily. This will alow the unit to be operated enableing you to look past the pilot flame to see if the burner flames are even across the burners. Disconnect electric and gas supply from the unit prior toiInstalling lower cover. After complete reassembly reconnect power and gas and enjoy.
Aug 08, 2011 | Blodgett DFG-100 Gas Single Oven
My company has Blodgett Gas Convection ovens, model # DFG100. Where is the serial number located on these ovens
The serial number is under the left side door behind the cover. Open the doors take out the two phillips head screws which go into the top of the lower cover, one on each end just inside the door hinge, the lower cover will remove to the front.
Jun 28, 2011 | Blodgett DFG-100 Gas Single Oven
I have sanyo microwave oven purchased in 1996 in dubai was fully functional untill few weeks back it has not been serviced for long time ,i am looking for advice on service or replacement
Usually when a microwave quits either the Power Diode or High Voltage Capacitor has failed. When they fail they usually also cause the internal 15 Amp fuse to fail. The back comes off by removing the 4 screws (2 on each side) and 6 screws in the back. (UNPLUGGED!) The you slide the cabinet cover back about 1/2 inch.. lift the rear of the cover 30 deg and remove the cover by pulling to the rear of the unit.
Once inside take a bladed screwdriver and short across the capacitor at least 3 times just in case it was not the failure. If you don't do this and the Cap is good it can really ruin your day! Then isolate the Cap by removing the set of terminal connections that include the power diode connection. Use an analog meter on R x 10K and probe the cap terminals. You should see resistance then watch the resistance increase to infinity. Reverse the leads and watch for the same indication....resistance then increase to infinity. It should do this each time you reverse the leads. To check the diode you read both ways with the meter leads across the diode. One way will read ZERO ohms and the other way should read close to infinity. (You have to reverse the leads.) Like I said usually the Cap or the diode fails. Make sure you check the fuse for continuity also. Most of the time they fail when one of the 2 components above fail. DO NOT replace the fuse until you replace the failed part. Otherwise the fuse will fail again.
The fuse is located in the fuse block at the end of the power cord.
When your reinstall the cover make sure you ensure the front side locking tabs near the bottom front are engaged with the front of the internal chassis.
If you need product specific parts replacement information we will need your exact model number. I will tell you that if you find the problem via the steps above you can walk into any LOCAL Appliance Parts source store and they will have the part you need in stock.
Thanks for choosing FixYa.
Kelly
Sep 13, 2010 | Ovens
I have a hotpoint dryer CDT00P which is running but theres no heat. What could this be?
Most probably open circuit thermostat or heater element.
You will need a meter to test them with, as you cannot tell if they are faulty by looking at them.
They are located behind removeable cover at rear of dryer.
Please rate my solution.
Thanks.
Nov 24, 2009 | Ovens
Grill control knob broken
hello sir/mam
please check the back portion of the oven you will see the screws which will be fixed to the top cover you should unscrew the screws and using a screw driver push the top cover .Then you can fix the control knob.
Oct 04, 2009 | Smeg DO 10PSS Stainless Steel Electric...
Need Manual For Electrolux Oven Model EOB 985GR
Having trouble locating the correct model number. Look at following areas for the model number
  • Under Right Front Burner
  • Under Left Top Burner Front Or Rear
  • Under Main Top Left, Rear Or Center Front
  • Under Left Rear Or Right Front Element
  • On Nameplate Inside Burner Box
  • On Front On Burner Box Bottom
  • On Nameplate On Oven Door Liner
  • On Main Front Behind Oven Or Compartment Door
  • On Front, Center Bottom Of Burner Box
  • On Thermostat Cover Under Main Top
  • Let me know, Sea Breeze
Mar 27, 2009 | Electrolux Ovens
Trying to replace main oven bulb: cover jammed
Try heating it up with a hair dryer or similar if that does not work then you will probably have to break the glass cover.
Nov 17, 2008 | Neff U1461 Double circotherm plus Electric...
How do i change light bulb for my oven
Here is a simpler method from the same website mentioned in solution #1:
1) Turn off power to the unit
2) Open the lower oven door
3) Remove the side trim screws and pull the trims down and out.
4) Remove 2 screws on the sides of the control panel.
5) Open the Microwave door. Remove the 3 screws on the Air Vent Plastic Cover on top of the microwave. You can then remove the Air Vent Cover by pushing the control panel up and pull out slightly at the bottom.
6) Remove the 4 screws on the Air Vent Plastic Cover on top of the lower oven and remove the Air Vent Cover. (You may have to remove the left under side bracket of the Microwave door temporarily just for the Air Vent Cover to clear the screw of the bracket. Re-secure the side bracket of the Microwave door panel as the front panel may fall)
7) Remove the 2 screws which held the Microwave unit in place behind the Air Vent Cover on step 6.
8) Wiggle the Microwave unit out about half way to expose the light bulb unit on top center
9) Wiring to the Control Panel will prevent you from pulling the Microwave unit out any further. And you don't want to do that as the unit may fall. Space is cramped, but working carefully with pliers you should be able to release the springs which held down the light bulb unit and change the bulb.
By the way, the bulb is Osram 64405S. It's available online for about $2.00 plus shipping.
See more info. at: http://www.howtomendit.com/answers.php?id=51232
Mar 13, 2008 | KitchenAid KEMC378KSS Electric Double Oven
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
