FixYa.com
Tags:
Motorola W375 Cellular Phone
Driver download (by 19 users)
posted by notyrmama on Jan 08, 2008
I am trying to find a driver for my new w375 cell phone so that the pic's I take can be downloaded directly to my computer.....for free.
Can anyone help with that?
Happy New year and thanks a bunch
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
18 Other Users Have The Same Problem
Comment by ashiq_afr, posted on Jul 26, 2008
iam going to connect my phone to my pc it connot connect to my pc
Comment by Guest, posted on Jul 18, 2008
drivers
Comment by taj15, posted on Jul 12, 2008
qfwddg
Comment by Guest, posted on Jul 12, 2008
I would like to have a driver that will connect my mobile Motorola w375 to my pc so that I can download some pictures in order to print. Is there any possibility of getting the driver for free.
Thanks
Comment by mitimingir, posted on Jul 09, 2008
Thanks
R.Mitimingi
Best Solution
posted on Jan 08, 2008
FixYa! (100)
Raysagem
Rank:Wiz Wiz
Rating: 82%, 941 votes
This is what you do:
  1. Your phone can upload and download files when connected to a PC running Windows 2000 and higher.
    Note: Mac is not suported.
  2. Open the flip and turn the phone on.
  3. From the home screen, attach one end of the Motorola Original Enhanced USB cable to your phone and the other end to a USB port on your computer.
  4. On your phone, press Yes to use the phone as a portable USB storage device.
    NOTE: When connected as a storage device the phone cannot perform regular phone activities. Disconnect to resume normal operation.
  5. On the PC, open the My Computer window and find where your phone displays as a Mass Storage icon.
    Double click the Mass Storage Device icon.
  6. Drag and drop files between your computer and phone.
  7. When finished, remove the phone safely from your computer. Right click the "Safely Remove Hardware"
    icon at the bottom of your computer screen, then select "USB Mass Storage Device" and click Stop.
  8. Select USB Mass Storage Device and click OK.
    Now it is safe to disconnect the cable. When the cable is disconnected, the phone restarts.
  9. Good luck.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on May 14, 2008
FixYa! (100)
am_pissed
Rank:Apprentice Apprentice
Rating: 92%, 2 votes
i have bought the same w375 from net10 ... and had the same problem when trying to conect it to my computer... i stormed my brain downloading software after software for this phone to realise that is net10 who &*$@*# us in the *** and wont allow the usb conection. my advice also : if all u want is to talk with a good plan ..net10+ motorola w375 is good deal.. but for anything ..literally ANYTHING else... suckssssssss !!! (now i feel better :)
Solution #3
posted on Jan 10, 2008
Helpful (85)
Guest
Guest
Rating: 0%, 0 votes
I am trying the exact same steps to connect my phone. I am failing at step 4. Raysagem: Do you get some kind of message on the phone to press "Yes" or you are talking about pressing the green button on the phone (ie. select button)? I am connecting to a windows XP PC. After step 3, I get prompts to install driver for USB device. Can you elaborate on the install for USB device at step 4? Are you using the USA Net10 phone by any chance?
Thanks
Solution #4
posted on Mar 25, 2008
Helpful (85)
motorolanono
Rating: 90%, 3 votes
i think that the best solution for this problem is to THROW THE PHONE IN THE TRASH...i have downloaded every driver available but none of them work. my solution was to text the photos to another phone so i could transfer them to the computer. nothing else seems to work...best advice is dont buy this phone
Solution #5
Helpful (85)
Delg
Rating: 85%, 3 votes
If you're with Net10, the reason it;s not working is because Net10 have de-activated USB connectivity (other than USB charging, for which you'll need the driver from the Motorola website which is far from easy to install if you don't know what you're doing, and don't expect any help from Motorola). I don't know if this is because Net10 want you to pay to transfer your photos out (because of course you can email or MMS them out of your phone, at your own expense) or because they do not want to field the inevitable compliants that arise when customers realise that this phone's memory is ridiculously tiny (half a MB) - not enough for a single mp3 and barely enough for a few images.
Solution #6
posted on Feb 23, 2008
Helpful (85)
ziggykz
Rating: 85%, 1 votes
No, It fails on step 3. The phone never prompts me to use it as a portable USB storage device.
Solution #7
posted on Mar 22, 2008
Thanks for Trying (70)
kaneda74
Rating: 70%, 1 votes
Got my Mother's w375 downloading to xp by downloading the usb charging driver from here.........
http://direct.motorola.com/Hellomoto/uk/support/SoftwaresNDrivers.asp
have had no problems on xp, now have to see if it will work on vista........
Solution #8
posted on Jun 08, 2008
Not Rated (0)
easy_on_macs
Rating: 0%, 0 votes
on MAC it works fine : just make sure to flip it open before plugging it in and when it asks you 'connect as a storage device?', say yes, and then you can access it from your MAC.... GOOD LUCK to the rest of you who're not lucky enough to have it that easy ... cheers
Solution #9
posted on Jun 03, 2008
Not Rated (0)
alec1980tck
Rating: 0%, 0 votes
I have just succeed to follow the above 8 steps to download the pics in W375 into WinXP.
There should be noted in The Point 3 "From the home screen, attach one end of the Motorola Original Enhanced USB cable to your phone and the other end to a USB port on your computer.", it should better make it reverse pluging, i.e. plug the USB port on your computer first and then plug the the Motorola Original Enhanced USB cable to your phone.
Then the rest can be done with the above steps :)
Can you Help with these Cellular Phones problems?
Free unlocking or subsidy code...
Hi, Can you provide free... Answer This...
MOTOROLA W375
MY W375 DOESN'T TURN ON BUT MY... Answer This...
Motorola W375
I am with Tesco mobile and want... Answer This...
motorola 375
how to down load photos to my... Answer This...
my phone is locked
it keeps poping up the volume... Answer This...
18 Other Users Have The Same Problem - Continued
Comment by palauan_isla, posted on Jul 01, 2008
how do I download the pictures out of my phone?
Comment by mikep23, posted on Jun 12, 2008
I have tried downloading several different programs but none of them have worked the only thing I haven't done was contact a local computer store.
Comment by Guest, posted on Jun 07, 2008
nesecito sofware motorola375
Comment by Dante2, posted on May 20, 2008
All I want to do is be able to download the pictures from my Moto w375 to my computer for free if possible. But when I connect my phone to my computer I get a window telling me to install a driver. I have already installed the P2K drivers and one other similar driver but they don't work. I have windows 2000, and would also like to be able to create ring tones from my existing mp3 files.
Comment by xenopress, posted on May 07, 2008
i HAVE WINDOWS XP. THE PHONE CONNECTS WITH WIN 2000 OR HIGHER. I NEED A DRIVER TO CONNECT WITH MY PC
Comment by jabar, posted on Apr 25, 2008
Please give me the driver of my w375. tnx... plz send to my email: - jabar143@yahoo.com.. tnx
Comment by Guest, posted on Mar 30, 2008
device driver not found
Comment by Guest, posted on Mar 18, 2008
id like to connect the usb portal to download the pics and song from my computer but i dont have the installer device for the usb..can you refer me where can i download?
Comment by Guest, posted on Mar 16, 2008
driver wanted for motorola w375 to download photos etcplease
Comment by Guest, posted on Feb 25, 2008
i have tried to download w375 motorolla modem drivers software but cant get plz help
Comment by vally123, posted on Feb 24, 2008
trying to get web access with tesco mobile motorola, need settings
Comment by motorolanono, posted on Feb 19, 2008
i wish i never got this phone, i have lots of photos that i can not get onto my pc. none of the drivers that i have downloaded will work and my pictures are still stuck on my phone. if any one could tell me where to find the drivers to go with windows xp i would really appreciate it.
Comment by Guest, posted on Jan 10, 2008
Thanks
Repair Service
Find Cellular Phone Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
