Question about Kenmore 22422 Top Load Washer
Agitation doesn't start. First we could do this when just hit the cover or press it, but now it doesn't help.Eugene and Galina
  • 6,784 Answers
HI. the internal components that make up the agitator should be inspected for damage.
The agitator is fastened to the agitator shaft and its movement is driven either by splines or a simple clutch assembly. The splines are usually plastic or rubber nubs on a cylinder that fits over the agitator shaft. If the nubs wear down, the shaft will not turn properly or it will turn weakly. If the agitator is moving in only one direction, the likely cause is the clutch assembly. The clutch has dogs that depress and pop up with each turn. If those dogs are worn, they will not engage properly and the agitator will turn only in one direction. Another issue that might cause this disruption is the Motor coupler.
Washers with a direct drive motor have a motor coupler instead of a belt. The motor coupler consists of three plastic disks (or tri-stars) with interlocking tabs. Those tabs can wear and break which results in slippage. The slippage causes little or no power to be transferred to the transmission. A worn motor coupling can result in weak or no movement of the agitator and spin basket. Inspecting the motor couplers requires removing the motor, which is fairly easy to do.
Remove the cabinet. Locate the motor. The pump is mounted to one side of the motor. You do not have to remove the hoses from the pump unless they prevent you from moving the pump out of your way. If you must remove the hoses, label where they connect first. To disconnect the hoses, pinch the wire clamps with pliers (or loosen the screw) and slide the clamp farther up the hose. Slide the hose off of the pump port.
There are two clips that secure the pump housing to the motor. Use a screwdriver to pry up the clips and remove the cover. Next, slide off the pump to reveal the motor. Disconnect the wiring harness from the motor, do not pull on the wires themselves. The motor typically is secured with retaining clips and bolts. Remove the bolts and use a screwdriver to pry up the clips (if present). Remove the motor.
Mounted on the shaft of the back of the motor you will find the motor coupler. Separate the three disks and inspect them for damage. If you find cracks or excessive wear, replace the coupler.
**(((If the motor couple is in good condition, replace the agitator components and clutch assembly as well.)))
Posted on Nov 14, 2009
2004 Landover range rover v8 .cranks no start new fuel pump won't turn on all fuses and relay are good.has spark and rpms.I have no communication with body processor .HELP
Hi Eugene, The links below are YouTube videos showing how to fix a car that cranks but doesn't start, Also there's videos down the right side of the links that may help as well..................CHEERS..
Fixing Car That Cranks But Doesn Start Up
Car Cranks But Will Not Start
May 05, 2016 | Rover Cars & Trucks
Will they work together?
Eugene, RE POST your question with make and model of both of what you want to work together.
Show your appreciation and press the helpful button and follow me on fixya for more tips and info.
Feb 16, 2016 | Televison & Video
Water dispenser doesn't work
Hi Eugene Perillo
Check where the water comes into the refrigerator and you should have a solinoid valve...maybe two...if only one...replace the valve, it is defective or has debris or dirt causing the valve not to work...if you have two solinoids then replace the one that feeds the water to the dispenser because it is defective.
Bud
Sep 23, 2012 | Refrigerators
DRYER STOPS/STARTS DOESN'T GET HOT ENOUGH
dryer duct blockage caused thermal limiters to trip. four t 20 screws remove the heater bank cover on the back of the dryer. unplug the dryer. unplug the dryer. did i forget to mention, unplug the dryer? remove the heater bank cover, and press the three red buttons in the center of each thermal limiter. at least one of them should click when you press it. replace the cover, plug the dryer in. it will now heat, but if you dont fix the blockage it will trip again.
Jun 14, 2012 | Miele T9800 Electric Dryer
I have been having trouble receiving faxes. It doesn't always happen, only occasionally. The printout says "no fax detected"; even though it has rung, it doesn't seem to connect....
!st thing that I do with intermittent fax problems is to call the phone carrier.
Tell them that you are having fax problems. Ask them to test your line. You could have a bad cable or noisy line.
Jun 27, 2011 | HP LaserJet 3050 All-In-One Printer
I have a Maytag Model A412, series 11 washing machine. After the machine fills with water the machine appears to start its cleaning cycle but the agitator doesn't work. The water starts & the...
if this is a two piece agitator,it should behave like a ratchet turn freely clockwise and catch counter clockwise if it doesn't catch the agitator "dogs " are shot this is a verry inexpencive repair
Jun 08, 2011 | Washing Machines
Starts to agitate as soon as cover closes, will not spin
Bad timer. It has welded points making it imposiable to change anything on time. Needs replaced.
Please rate solution
Aug 28, 2009 | GE WBSR3140DW Top Load Washer
Washer will not start without hitting lid.I have a Super Capacity Plus Top Loading Washing Machine, Model #LSQ954PW2 and it will not start the agitation without me hitting on the lid.It seems like whatever...
If you look at the lid while opened,you will see a small pin that when closed,goes into a small opening on the washer and contacts with the lid switch.
Jul 29, 2009 | Washing Machines
Soyo m/b model sy-p41 845pe.
Eugene, how are you? Not a problem, firstly have you replaced the motherboard CMOS battery? If you have the next step is to boot into the BIOS, most of the time it will mean pressing the delete key, or F8,F10, F12 and or ESC upon turning on your syst. It all depends on what kind of pc you have.
Once you are in the BIOS setup screens go through each one and just remember to save and reboot your syst. This should set you straight. ;)
Jul 14, 2009 | Computers & Internet
Whirlpool duet post washer 2006 model will not start any cycle and only hums and pumps odl water out
Sounds like your pump is clogged....first you need to remove the front cover below the loading door... (will be 3 Phillips screws on the very bottom). You will see a white cap in the very center bottom. You are going to need a bowl to catch some water and probably some debris when you remove it....Make sure you get all the debris (coins wrappers...ect... I made about $2.75) out before you put the cap back on the drain...Then try to run a normal cycle again. You can always run the diagnostic program that is found in the manual which is also located behind that front bottom cover if the normal cycle doesn’t go all the way through.....then you got me.....the pump is probably out but you will get more information if you run the diagnostics.....Good Luck.....
Sep 21, 2008 | Whirlpool Duet 3.8 cu. ft. Front Load...
Kenmore 22422 Top Load Washer Logo
56 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
