Question about Kenmore 2.1 cu. ft. Portable Top Load Washer
I am thinking of buying used kenmore model 110.49722992. I live in an RV, and I need to know what the "empty" weight.
    President:
  • 1,937 Answers
Please see the following Sears Parts list and Owners Manual.
The loaded weight is 260 Lbs.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.49722992
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0710496.pdf
Water is 8.35 pounds per gallon. Plus the weight of your clothes.
Posted on Nov 14, 2009
Curb weight 1986 29 foot southwind motorhome
The weight is about 17000 lbs.
The weight is posted somewhere in the RV. Could be on a visor, inside a closet or cabinet door, or on a door panel.
Oct 09, 2016 | RVs
Weight of travel trailer
Robin, not much to go on, my guess is 2200 to 2500 Lbs.
You could probably phone any RV center for more accurate weight or drive to any near by gravel pit that has a scale and get it weighed.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Jul 03, 2016 | Cars & Trucks
What model number Dometic AC unit to add to RV?
usually 13,000 in front but if enough power and you don't mind the more expensive one go 15,000
Jun 26, 2012 | Dometic Rooftop RV Air Conditioner
We just got back from a extended RV trip driving 30 foot RV with a clearance of 12 feet. on three occasions the rout chosen b the gps took us into some really tight situations. is there any way of letting...
I know with Magellan GPS you can buy a pogram for Trucks/RV's for $ 149.00 that lets you input weight, height etc. maybe on Tomtom's website they have something like this available. Sorry not to be able to help you more.
Oct 10, 2010 | Tomtom GPS
Manuals for Onan 6.5NH-3CR/16004P RV generator
onan mcgraw RV model NH-3CR/1600HP, need to know how much oil,what weight of oil how much etc, the type of spark plug , oil filter, all the specs
Aug 04, 2010 | Garden
Pump Lubrication
I believe the standard for pressure washer pumps is 30 weight non- detergent pump oil. Do not use motor oil. Also don't forget to winterize the pump if you live in the snow belt. Use RV antifreeze.
Jun 24, 2010 | Mi T M WP-2700-4MHB Pressure Washer
Rooftop RV Air Conditioner: what type freon is used on a 2001 model...
Look at the labels on the unit, it should be on 1 of them along with the weight of the charge.
May 06, 2010 | Dometic Rooftop RV Air Conditioner
Spin cycle problem
I suspect you definitely have a clutch problem. It might be the liner or it could be the transmission seal leaked some oil into the clutch you would know it by the oil on the cabinet74eb356.jpgThats a hint of a clutch problem with leaky top seal. An easy fix.ef45d86.jpgthe newer washer have a square recess you unscrew and lift the top of the agitator off and then you have access to the bolt that holds the lower portion on. The agitator has to come out first then drop the tranny
(3 bolts) Put the tranny on a bench. You can use a pair of pliers and squeeze the spring and the clutch liner comes right out. You can buy just the liner, no need to buy the kit but you can do that too. None of the parts are expensive and anybody can do these repairs.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 16, 2010 | Kenmore 24962 Top Load Washer
Hotpoint condenser tumble dryer aquarius cdt00- wont dry
I am not familiar with this particular unit, but I have a condensing dryer (Malber) which pumps out the water by itself. I am guessing that your unit requires you to empty a bin manually. Even if the bin is empty, I think the unit thinks it needs to be emptied and that is why the dryer will not work to give you hot air. If you do have such a bin, it might have a weight switch which the unit uses to detect if the bin needs emptying. See if the weight switch is working. The same weight switch idea is used on dehumidifiers.
Mar 09, 2008 | Dryers
Kenmore 2.1 cu. ft. Portable Top Load Washer Logo
113 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
