Question about Cycling
I have a Cannondale R600 and the gears won't shift at all. The last time I rode it they shifted but that was about a year ago.
  • matthew kuhl May 11, 2010
    Can you describe more precisely what you mean? Are they not moving or not correctly shifting?
  • 255 Answers
Something corroded in place - the most common thing is that if the bike were left out in the rain, water got in the shifting cable and the cable siezed in the sheathing. Sometimes they can be freed, but usually it requires a cable replacement. Your local bike shop can do this for a fair price.
Posted on Nov 25, 2009
1998 Chaevy Cavalier manual transmission won't shift
Hi orvil brad hear, I would guess since you said you have a brake fluid leak, all of the master cylinder pressure is going out through the leak, not leaving enough pressure to actuate your clutch. If its not this it will problem be inside the tranny and thats another story. Good luck
Jan 01, 2018 | 1998 Chevrolet Cavalier
I have just refurbished a 1976 Bmw R600/6 which has been stored for over 20 years. Once i got it running i found i could only select 3 gears i believe the missing ones are 1st and 5th. Is this a common...
hey shane my recommendation is to replace the gears 1st and 5th and not to my knowledge is that a common problem to break gears like that you have to shift hard with out clutch ( power shifting )
good luck.
Mar 26, 2011 | BMW R 60-7 Motorcycles
Its been 23 years since i rode a bike.im on a new excercise phase of life, so i brought a cannondale 900 series. how and when ,do i change gears to get the most benefit out of them.i was strickly bmx as a...
1st:
http://www.cannondale.com/deu/deu/Instructions
2nd:
as you drive ,you will KNOW when to shift,Anytime it gets to quick to pedal fast enuff>shift UP....when going up grades,shift to lower gears(but don't wait till your crawling)
Mar 28, 2010 | Cycling
ITS NOT REALY A PROBLEM I JUST WANT TO KNOW HOW YOU CHANGE THROUGH THE GEARS WHEN RIDING IS IT 4 DOWN 1 UP.ITS A 2001 SOFTAIL STANDARD
The last Harley-Davidson motorcycle to use the 1 up - 3 down was the 1973-74 Sprints. The U.S. law was adopted in 1974 effective with the 1975 and later models that required all motorcycles to shift on the left side and be in a 1 down and 3 or 4 up pattern. Today, they are still 1 down and the rest up. How many up is dependant on the year model. The last year for right side shift Sportsters was 1974. In 1975 and 1976, they put this funky crossover linkage under the bike to convert the right side shift transmission to a left side shift. Then, in 1977, Harley modified the cases and the transmission to be a true left side shift. Man, that was a long time ago. Means I'm old and I might not be totally correct but close enough.
Feb 01, 2010 | 2001 Harley Davidson FXST Softail Standard
My stick shift has troubling getting into 3rd gear
your probly not puting your clutch in all the way and not shifting fast anoth.Or it was not installed the right way and it was unbalanced so probly need to check it out or go a proformace place and have them look at it.
Jan 27, 2010 | 1998 Toyota Corolla
The gears won't select on a gsx-r600
If the shift pedal is hard to push down and/or hard to lift up, the problem is a bent shift fork. If it feels like it always did, then I have to ask if you have changed oil in the last month or so. Did you use anything other than standard 10w40 motor oil? Synthetics and oils with "special" additives can make a clutch fail to engage. Some of them swell the friction plates and the clutch will not dis-engage. If you did use the wrong oil, drain it and flush it from the gearbox as best you can. The clutch may or may not return to normal.
Can I get a “very helpful” rating on this answer?
Aug 15, 2009 | 2004 Suzuki GSX-R 600
Yamaha Raptor Shifting
Well, it seems like there is a problem with the shift return spring; it's on the backend of the gear, Seems broken or not attached properly, so first of all do this check.
Good Luck!!
Thanks
Jul 08, 2009 | 2005 Yamaha TT-R 125 LE
90 Accord won't shift
I have a 1993 honda accord and my clock won't keep time,can you help
Apr 03, 2009 | 1993 Honda Accord
Gear shifting is hard to impossible
Synchronize the gears is what a trans does when you shift it, the part that makes this possiable is a part called a sycronizer ring, if they (4 of them) wear out prematurely then you end up with a hard shift issue, does this answer your question? I do assume your clutch is ok?
Nov 01, 2008 | 2006 Saturn Vue
Cycling Logo
155 people viewed this question
Top Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
