Question about HP Compaq Presario V6000T Notebook
I turn on my laptop, i get the compaq logo then i seen the press esc. f1, f2, f9,f11, etc but then the screen is blank and nothing else happens what should i do now!! i did the troubleshooting as far as removing the dual memory and only using one then tried the other also i cant hit any of the keys except escape and then the screen goes back to blank no icons no nothing just a black screen.please help asap thanks, jeanie
    President:
  • 2,600 Answers
Jeanie, there is the possibility that your hard drive has failed. Lets try though to boot from the windows install disc. Put the cd in and boot the computer up. If the hard drive has failed the laptop might try to automatically boot the windows program off the disc. If it does go through the steps below to try and fix the windows installation if it is salvagable.
Windows Start-up Errors
First, The basics. You will need a Windows CD. If you only have a recovery disk set like the ones from a HP or Compaq, they will not do what you want. You can normally use a Dell disk, also retail box disks (Windows Purchased from the store), or some OEM versions of Windows will work (most of these will have the Microsoft hologram on them).
When you get the system started and it finds your startup disk you will see a screen that says Press any Key to boot from CD. I normally use the space bar as my any key and then you should see a blue screen that says Windows setup in the left hand corner. Wait until you see the welcome to setup screen and then click the "R" key to get to the Recovery Console How long it takes to get to each of these depends on the speed of your system, but I will tell you that it will take a few minutes to finally get to the Console.
Once you are at the Recovery Console you will be given at least one choice of Windows installations. Normally the choice you want is the number 1 choice. Click the number 1 key at the "top" of the keyboard and click enter.
You will be given a message asking for the administrator password. Unless someone or something has messed with your computer there is no password so you just click the enter key.
This will bring you to a prompt that says:
C:\WINDOWS>
Type: cd \ and then click enter
( Note: between "cd" and "\" there should be a "blank space" otherwise the command won't work. If you find that a command hasn't worked make sure you typed it correctly. These are similar to old DOS commands where spaces had to go between each command so DOS knew where one command stopped and another started.)
You are now at the ROOT of the drive where it all begins. The Prompt should now say C:\>
Now type: CHKDSK /R and click enter.
The chkdsk / r command also includes the P command and will also look for lost recoverable information in bad sectors.
Now after the chkdsk has run type: FIXBOOT then click enter.
It may prompt you with a warning but continue through it and once fixboot has finished type: EXIT and click enter.
Your system should reboot and when it does click the F8 button to get a windows start menu. Use the up or down arrow to highlight the LAST KNOWN GOOD CONFIGURATION and click enter. If it was a simple drive error this should have fixed it.
Posted on Nov 14, 2009
How do I get it to go into bios when pressing f2 doesn't work?
Per the internet site, it depends upon the model of laptop. Here are some examples:
Laptops - Access Bios Settings Key
Issue
The most common Access Bios key is the "DEL" button or "F2". This depends on the laptop model, however, and can be confusing if you do not know which key to press.
Solution
Here is a list of laptop models and brands with the keyboard commands / key for accessing the BIOS Setup:
Acer: F1, F2, CTRL+ALT+ESC
ARI: CTRL+ALT+ESC, CTRL+ALT+DEL
AST: CTRL+ALT+ESC, CTRL+ALT+DEL
Compaq 8700: F10
CompUSA: DEL
Cybermax: ESC
Dell Laptops:
Dell 400: F3, F1
Dell 4400: F12
Dell Dimension: F2 or DEL
Dell Inspiron: F2
Dell Latitude: Fn+F1 (while booted)
Dell Latitude: F2 (on boot)
Dell Optiplex: DEL
Dell Optiplex: F2
Dell Precision: F2
eMachine: F2
Gateway 2000 1440: F1
Gateway 2000 Solo: F2
HP (Hewlett-Packard): F1, F2 (Laptop, ESC)
IBM: F1
E-pro Laptop: F2
IBM PS/2: CTRL+ALT+INS after CTRL+ALT+DEL
IBM Thinkpad (newer) Windows: Programs-Thinkpad CFG.
Micron: F1, F2, or DEL
Packard Bell: F1, F2, Del
Seanix: DEL
Sony VAIO: F2
Sony VAIO: F3
Tiger: DEL
Toshiba 335 CDS: ESC
Toshiba Protege: ESC
Toshiba Satellite 205 CDS: F1
Toshiba Tecra: ESC then F1 or F2
Toshiba Notebook [Newer models]:
  • Turn on the computer by holding down the power button while pressing the ESC key
    • The machine will beep, then display:
    • Check System, then press [F1] key.
  • Release the ESC key
  • Press the F1 key
Laptops Access Bios Settings Key
Apr 03, 2015 | Computers & Internet
Start up, won't go pass the wolvol screen
What the heck is a "WolVol" screen? In any case, you might have a stuck key. Try turning the over with the lid open and gently tapping laterally to dislodge dirt. Then air-spray it out and boot.
Failing that, if you have a PC (HP, Compaq, Toshiba, etc. not a Mac), try to reset the machine to default settings (does nothing to your data or system, just the inner hardware).
When booting, go into settings, usually by repeatedly pressing F2 or F11 as it boots. When the settings screen appears, press F9. It will ask if you want to reset to defaults. Say yes then press ESC until it says "Save settings?" say yes again and ENTER to reboot.
Hope this helps.
Dec 26, 2013 | Wolvol Boys Black Computer Laptop Mini...
What keys do I press to get the CMOS setup screen on a Compaq Presario 5222?
Try F2 or F8 or F9. Shouls tell you just before the splash screen comes up ...
Jan 28, 2012 | Compaq Presario 5222 PC Desktop
I have set up my compaq computer , it was working fine, then I shut it down. Now when I start it up it goes into the compaq screen asking for press esc or f11 or f10 etc for rebooting etc. What have I...
The Start up screen for Compaq series computers is normal, that screen takes you into your BIOS mode. when the screen appears press F1, at the bottom of the screen it will say press F5 or one of those keys to install your Default Settings, Click Yes and Exit. That should do it. Good Luck.
Oct 28, 2008 | HP Computers & Internet
Toshiba Satellite 1400
To Access the Bios Setup Utility Here Is A List Of Key Commands And The Make/Model They Are For..
Acer - Aspire, Power, Veriton, Extensa, Ferrari, TravelMate, Altos
  • Press Del or F2 immediately after powering on.
  • The BIOS on the Acer Altos 600 server uses the Ctrl+Alt+Esc key and the F1 key for advanced options.
  • Older Acer computers may use also use the F1 or Ctrl+Alt+Esc keys to access BIOS.
Compaq - Presario, Prolinea, Deskpro, Systempro, Portable
  • Press F10 while the cursor in the top right corner of the screen is blinking.
  • Older Compaq computers may use the F1, F2, F10, or Del key to give access to BIOS.
Dell - XPS, Dimension, Inspiron, Latitude. OptiPlex, Precision, Vostro
  • Press F2 when the Dell logo appears. Press every few seconds until the message Entering Setup appears.
  • Older Dell desktops and laptops may instead use Ctrl+Alt+Enter or Del to enter BIOS.
  • Older Dell laptops may use Fn+Esc or Fn+F1.
eMachines - eMonster, eTower, eOne, S-Series, T-Series
  • Press Tab or Del while the eMachine logo displays on screen.
  • Other eMachine computers may use F2 to enter BIOS.
Fujitsu - LifeBook, Esprimo, Amilo, Tablet, DeskPower
  • Press F2 once the Fujitsu logo appears.
Gateway - DX, FX, One, GM, GT, GX, Profile, Astro
  • Press the F1 key repeatedly after restarting the computer.
  • Some older Gateway computers use F2 to access the BIOS Setup utility.
Hewlett-Packard (HP) - Pavilion, TouchSmart, Vectra, OmniBook, Tablet
  • Press the F1 key after restarting the computer.
  • HP Tablet PCs may use F10 or F12.
  • Other HP computers may allow access to BIOS using the F2 or Esc keys.
IBM - PC, XT, AT
  • Press F1 immediately after powering on the computer.
  • Older IBM computers (including some laptops) may utilize the F2 key for BIOS entry.
Lenovo (formerly IBM) - ThinkPad, IdeaPad, 3000 Series, ThinkCentre, ThinkStation
  • Press F1 or F2 after powering on the computer.
  • Older Lenovo products allow access to BIOS using Ctrl+Alt+F3, Ctrl+Alt+Ins, or Fn+F1.
Micron (MPC Computers) - ClientPro, TransPort
  • Press F1, F2 or Del immediately after powering on the PC.
NEC - PowerMate, Versa, W-Series
  • Press F2 to enter the BIOS Setup.
Packard Bell - 8900 Series, 9000 Series, Pulsar, Platinum, EasyNote, imedia, iextreme
  • Press F1, F2, or Del to enter BIOS.
Sharp - Notebook Laptops, Actius UltraLite
  • Press F2 after the computer starts.
  • Some very old Sharp PCs require a Setup Diagnostics Disk to access BIOS.
Shuttle - Glamor G-Series, D'vo, Prima P2-Series, Workstation, X Mini XPC, Surveillance
  • Press F2 or Del on startup.
Sony - VAIO, PCG-Series, VGN-Series
  • Press F1, F2 or F3 after turning on the computer.
Toshiba - Portégé, Satellite, Tecra
  • Press F1 or Esc after powering on to access BIOS.
The following companies are either closed for business or no longer manufacture or support mainstream computers systems so verifying the following BIOS access information is nearly impossible. I have included what I could dig up for anyone who might be interested:
ARI / ALR / AST (Advantage) - Press the Ctrl+Alt+Esc or Ctrl+Alt+Del keys.
Cybermax - Press the Esc key.
Tandon - Press the Ctrl+Shift+Esc keys.
Good Luck and Hope it helps...
http://www.wnycomputerpro.com
Jun 12, 2008 | Toshiba Satellite A35-S159 Notebook
Bios problem
try to press del,f1,f9,f12 try these keys when you start the system only
Mar 25, 2008 | Compaq Evo N610C Notebook
HP Compaq Presario V6000T Notebook Logo
164 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
