I have a Mitsubishi WD52525 and the green light is blinking. I have changed the capacitors on the DM board and also a couple noticably bad ones on the Power module. The green light problem still exists. Is it a bad DM module?
  • 1 more comment
  • kep890 Nov 15, 2009
    Thanks. I believe I found a DM board on ebay. They have the part number listed as WD-52525 DM Board 934C1160 P447. I sent the seller a question about the part number because the one you listed has 02 at the end. I need to pull my DM out again and verify the number, I guess.
  • kep890 Nov 24, 2009
    Changed DM board and blinking light still persists. What next??
    I have checked and rechecked the connections and nothing. I do have one question about the connectors. I noticed that connector PA on the DM did not have anything to connect to. Is this left open intentionally?
    President:
  • 1,462 Answers
Yes, you have a bad DM board, you have to change the DM board..
THe part mumber for the DM board is DM PCB part # 934C116002
You get the detailed reference for changing the DM board from the following link
http://www.chrisandnat.com/temp/BlinkingTV.pdf
Please leave me comment, if you need further assistance
Thanks for using FixYa!
Rnj VINODKUMAR
Posted on Nov 14, 2009
  • Vinod Kumar
    Vinod Kumar Nov 15, 2009
    THe DM board you mentioned has the same series and works perfect with yout TV..
  • Vinod Kumar
    Vinod Kumar Nov 24, 2009
    Have you fixed the connector firmly, verify whether you have connected the board correctly
Mitsubishi green blinking light of death
Hi Jim,
Green blinking light of death on Mitsubishi DLP TV means that the DM failed to booted up. I would advice you to replaced the 7 1000uf electrolytic capacitor on the DM board. Most of the time it fixed the symptoms. Please inquire at tvrepairworld.com if they have an available DM repair kit for V36 chassis (WD-57733 chassis).
Jdvillanueva
Jan 10, 2012 | Mitsubishi WD-57733 57" HDTV
AFTER A POWER FAILURE GREEN TIMER LIGHT WILL NOT STOP BLINKING. HAVE TRIED TO RESET TIMER, UNPLUGGED POWER SOURCE. THIS IS A MITSUBISHI DLP WD52525
The Capacitors on the DM board need replaceing. The V26 DM repair kit from www.tvrepairworld.com will usually repair that issue. The kit contains the capacitors and the CD with instructions.
Dec 14, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Why doe my wd52525 dont turn on and all it dose is a green blinking star light
The DM capacitors have failed. You can get the V26 DM repair kit at www.tvrepairworld.com which should repair that issue the kit contains the capacitors and the CD with detailed repair instructions
Nov 22, 2009 | Mitsubishi WD-52525 52" Rear Projection...
I have a Mitsubishi WD52525. Green timer light blinking, tv won't come on. Read all directions for troubleshooting in owner's manual. Have pressed reset button, timer light never stops blinking. Unplugged...
You are not going to like this one little bit. The reason the LED won't stop blinking is because the digital module is not booting up. I have been fighting this model Mitsubishi for over five years now and the only solid fix is to send the entire chassis back to Mitsubishi for rebuilding. Pulling the chassis is a major job and with shipping costs and Mitsubishi's charges this repair usually runs around $750 to $850. However many owners that contacted Mitsubishi about this problem have gotten that portion of the repair bill coverd. That still leaves $300 to $400 for the tv shop that pulls the chassis and reinstalls it once it is rebuilt.
Jun 14, 2009 | Mitsubishi WD-62827 62" Television
Green power light blinking all the time on TV
After changing a defective capacitor, my TV still would not power up. After using a solution I found on this site, I held the power and volume up button down on the TV itself for several seconds, the TV powered up normally. I did notice that you had to do this while the timer light was flashing. Doing so after it went out was not effective. I initially only replaced one capacitor which was noticeably defective, and the flashing green timer light eventually returned. I will be replacing all 7 capacitors and resetting the TV. As mentioned above, the capacitors may look good but in fact may be defective. These are high temp caps which breakdown under a load but function normally when cold. Several people have mentioned replacing the capacitors didn't fix the problem. It appears that you must replace and reset using this method to repair some of these TVs.
Jun 06, 2009 | Mitsubishi WS-65615 65" TV
Blinking timer Light (Green)
Thats a common problem caused by defective capacitors on the DM PWB which prevent the set from booting up. The V26 DLP DM kit at the following link will usually repair that issue and it comes with step by step instructions on how to do the repair. Look under the repair kit category.
http://servicemanuals.vstore.ca/
Mar 14, 2009 | Mitsubishi WS-65513 65" Rear Projection...
Green screen
sound like a DM or FMT board failure. this is not the 4 cap blinking green light problem. check out
www.tv-techs.com
Nov 20, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Green blinking light problem too. on a Mitsubishi WS65869
You can go to this link they have the kits with the high temp higher volt capacitors and complete detailed instructions on how to do the repair.
Jun 03, 2008 | Mitsubishi WS-55909 55" Rear Projection...
Mit 52525 from blinking green light to still green light.
bad capacitors 1000uf on the PWB, FMT and DM boards will cause those symptoms. All capacitors 9 in all need to be replaced
May 06, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Televison & Video Logo
130 people viewed this question
Top Televison & Video Experts
