Question about Echo Garden
The bar siezes. I have had it fixed (home Depot) numerous times - now out of warranty. What's wrong- was there a recall?
  • 279 Answers
Sounda as though the bar is not straight. You can find out by using a straight edge and laying it on the bar. See if there are any gaps. If there are, you and chuck it into a vise and see if you can straighten it. If not, you may look for a replacement bar and/or trimmer. Good luck...Lee
Posted on Nov 14, 2009
The ETC light comes on and I have no control of the vehicle. 2005 Ford Territory Ghia. Used hand brake to stop!
ford territory has a probem with engine control and issued a major recall to have it fixed
indications were
driver unable to stop the engine , stop the vehicle or control vehicle speed \
There are numerous reports and accidents concerning this problem so get a lawyer to discuss the fault with ford as it is covered under a recall and warranty fix
Mar 23, 2018 | Ford Cars & Trucks
RUNS HOT, AND CUTS OFF AFTER ONLY A FEW MINUTES,
It should be under warranty. Call Home Depot and tell them to come fix it.
Apr 18, 2015 | Refrigerators
Pump is plugged into a hot line and will not run. It ran just over 3 months and quit totally.
Hello Mr Johnson.
I will help.
I am timer expert at fixya. Fixya answers question. We are not home depot or warranty carrier for grunfos.
Here are some ideas:
1) Buy another pump at home depot and return defect in new package
2) Talk to manager at Home Depot.
3) Check if outlet has power. Plug recirc pump into different outlet.
4) Check if override lever is set to OFF, because pump will not run when lever is in OFF position: Here is photo I took showing positions for lever:
http://waterheatertimer.org/Water-heater-recirculation-system.html#lever
5) These devices are prone to surge event. Nearby lightning strike can burn out any electrical device by energizing wires. The surge can follow any path seemingly random trying to find path down to ground.
Add a comment and say what happens.
Gene Haynes
Jun 04, 2013 | Laing Thermotech Autocirc Undersink...
Is there a recall for ryobi 18v charger or batteries
I had similar problems with my 18V Ryobi batteries. Called Ryobi customer service, gave them the serial numbers and was told there was a 2 year warranty on them, in my case the warranty was in effect until July 2012. Took the batteries to Home Depot today and they replaced my batteries with two brand new ones. I can't complain about Ryobi customer service
Jan 07, 2011 | Ryobi 18volt 12" Cordless Drill Model P206
I bought a makita tool set from Home Depot not even three months ago and i just tried to charge my batteries and the red and green light is coming on for both batteries. Is it possible both batteries went...
Hi David, there are 2 things you can do.
1) If you still have the reciept, I would take it back to Home Depot and attempt an exchange, assuming the tools look like they only have half an hour on them. That will be the quickest, if it works.
2) Follow the link below, type in your zip code and take it into your nearest Authorized Warranty Center. They will also require a receipt.
At this point it is irrelevant what is wrong with it if its under warranty. If it ends up not being under warranty for whatever reason, your assumptions are correct. It could very well be both batteries at the same time, or a faulty charger. Big box stores like Home Depot dont recycle stock the way they should. I went to a local Home Depot and found a DeWalt battery with a date code that was 4 years old.
http://www.makita.com/en-us/Modules/Service/ServiceCenters.aspx
I hope this helps, and good luck.
Nov 27, 2010 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
Simplicity 4-in-1 crib model 8676c replacmnt prts
The company is out of business. Although your's in NOT one of the recalled items,you will not be able to contact them or buy parts.
Have you tried other hardware stores aside from Home Depot? You could also try an automotive store...sometimes they have those odd sizes.
Please read the following:
About 1 Million Simplicity Cribs Recalled Due To Failures Resulting in Infant Deaths.
Note: The firm appears to no longer conduct day-to-day operations. Repair kits are no longer available to fix these recalled cribs. Parents and caregivers are advised to dispose of these cribs, even if it is believed that the hardware and drop side have been installed correctly. All of the recalled cribs have the potential to pose a danger to young children.
The recalled cribs have one of the following model numbers, which can be found on the envelope attached to the mattress support and on the label attached to the headboard: 4600, 4605, 4705, 5000, 8000, 8324, 8800, 8740, 8910, 8994, 8050, 8750, 8760, and 8996.
Oct 09, 2009 | Simplicity for Children 4-in-1 Convertible...
NEED TO FIND A NEW 14" CHAIN AND BAR FOR ECHO CS 305 SAW. NONE LISTED AT LOWES OR HOME DEPOT. THANKS FOR ANY INPUT.
What you are looking for is the following model bar:
Echo 14A4CD3752
If you cut and paste that into google or another search engine you will find numerous online retailers who can sell and ship you this bar for your CS-305 saw.
Apr 06, 2009 | Echo Garden
Vac won't turn on and the beater bar won't turn.
If you are having the same problem, then maybe there is something that you aren't doing right. But you do have a years warranty on what ever brand and model this is, take it in for warranty repair.
Jun 22, 2008 | Vacuums
LAST NIGHT OUR LESS THAN 1 YR OLD MAGIC CHEF MICROWAVE TURNED ON BY ITSELF AND WE TRIED EVERYTHING TO GET IT TO CANCEL INCLUDING UNPLUGGING IT SEVERAL TIMES. IT HAS A MIND OF ITS OWN NOW. MODEL #MC0160UB...
Have you looked on the magic chef recall website? I read about the same problem on the Samsung recall website about microwaves turning themselves on.
Apr 01, 2008 | Microwave Ovens
Open Questions:
Garden Logo
173 people viewed this question
Top Echo Garden Experts
Jim Parker
Jim Parker
Jim London
Jim London
colesmowers
Are you an Echo Garden Expert? Answer questions, earn points and help others
