Question about Saeco Magic De Luxe Espresso Machine
My saeco machine is not functioning in the right order, it grinds after it makes the pad. So I first hear the clicking sound (meaning it is making the pad first with old grinded coffee) and then it grinds the coffee beans (which will be used in the next shot). How do I change that order so it grinds first, then clicks (making the coffee pad) and then runs the water through? Mail to yvonne@crowdedhousebonaire.com
  • 1,089 Answers
HI
Read the first then go to the bold letters.
To program your Magic Dlx: Press and hold the steam and small espresso buttons at the same time, then push the energy saving button (top right). Water Hardness. The large coffee button programs the water hardness. Press the button once and you will have one light in the top row, left side. Press it again and you should have two lights lit. Press it three times and you have three lights lit. Four and you have four lights lit. Press it a fifth time and it goes back to one light. Each light represents your water hardness. So if you have a water hardness of 3, press it until you have three lights lit. Press the energy saver button to exit the program and save your hardness level in the machine’s computer. It will now tell you when you should descale your machine. Pre-infusion. Press the medium coffee button to activate and you should see the light come on. Press the button and turn the light off to deactivate the pre-infusion. Pre-grinding. Pre-grinding is turned on with the cup warming button. When it is lit, the pre-grinding is on. Press the button to turn it off.
Posted on Nov 14, 2009
2007 ford sport trac new brakes hear a clicking coming from brake caliper when stopping can i just bleed them or is it going bad? disk front and back
If the brakes are making a clicking sound when the brake is applied, that means that something may not have been put back together right. I would definitely yank it back apart and check to make sure that the brake pads fit securely in the brackets with no play at all, too. It's easy to get the wrong pads for a Sport Trac; the parts are completely unique and a lot of parts stores even have incorrect listings for brake and suspension parts for those things. Brake system wear can create a grinding, pulsing, or squealing sound, but shouldn't produce a click. Something isn't right there!
May 05, 2016 | Ford Cars & Trucks
My Saeco Vienna Black Automatica Espresso maker will grind coffee only about one-fourth of the time. Other times, it makes whirring sound and then shuts off and red "coffee bean" light comes on.
Your grind is to fine. Turn the big knob in the bean hopper up 4 clicks and try again. It could be oily beans which would require the same solution.
Nov 02, 2010 | Saeco Vienna Espresso Machine
Unable to get White Saeco Cuppacinno Machine to work.
Hi
I would say that your brew unit is not locked in.
Brew group missing indicator
Open the door on the right. Push on the upper left side of the brew unit until you hear a click. Close the door and see if the message is gone. If it is make sure that the grounds drawer is in place.
Tip: Pull the grounds drawer out, then push it back with only 1 finger and push it on the right side of the drawer. This will make sure that it engages the micro switch.
May 04, 2009 | Saeco Magic De Luxe Espresso Machine
Incanto Sirius - grinds but cannot hear coffee getting ground
The chute is clogged or the grind is too fine on the machine. To clean chute remove the brew unit and check to the right, clean chute.
Mar 12, 2009 | Saeco 00034 Incanto Sirius Super Automatic...
Saeco Roayal Sup 016
Hi
I am assuming your machine grinds, then clicks twice, then the brew drive starts but you never hear the pump.
If this is so? The there is a lever at the top center of the door on the right. Pull the lever back 1 click, and try again.
Mar 10, 2009 | Saeco Vienna De Luxe Espresso Machine
Ground coffee Saeco Royal
Hi
thedalys. you probably have a bad micro switch on your doser. and that just needs to be replaced. If the grinder does not sense that the doser box is full it will keep grinding until it times out.
Guest. Try pulling the dosage lever back one click from the full and push your grind lever to the largest # and see if that helps. Sounds like you grinds are too fine and its clogging the the grind box. If the dosage level is too full it will cycle and dump the brew unit or break the brew drive gears, then you will hear a clicking noise when it trys to make a coffee.
Dec 12, 2008 | Saeco Royal Digital Plus Coffee...
Saeco digital plus not grinding
Sounds like your grinder is clogged and do you hear a clack, clack? That would be the solenoid opening the doser box.
Oct 13, 2008 | Saeco Royal Digital Plus Coffee...
Saeco magic deluxe machine is making crunching noises when makes coffee and when returning to start position. Sometimes does not make the coffee grinds coffee but not letting water through almost seems...
There is a lever inside the door on the right. It is at the top in the center. Pull it back one click and try again. The crunching noise does it sound like a clicking noise?
Aug 31, 2008 | Saeco Magic De Luxe Espresso Machine
Small coffee and coffee not dispensing?
Try to program it, press and hold the small cup button. When you have enough of coffe, release the button.
Now try to make a cup of small coffee.
Hope this will help you.
Best regards
/Mirran
Aug 31, 2008 | Saeco Royal Professional Espresso Machine
Sirius Incanto loud noise
When you power on the machine, can you hear the machine do the self test?
is there a crack sound when the brewing unit is in work?
Aug 01, 2008 | Starbucks Saeco Italia Digital Barista...
Saeco Magic De Luxe Espresso Machine Logo
144 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
