Carrier Window AC 19,600 BTU with Remote / Model is APX195BA
When checking the control board, what are the output voltages on the PCB Transformer terminals 5, 6 ,7 & 8. Terminals 1 and 2 are 220V line to line. I am assuming it should be 12 V and 5V but not sure. Thanks
  • Anonymous Jan 12, 2008
    I was able to determine that on the PCB Transformer Terminals 1 and 2 are 220 V line in, terminals 5 and 6 not used with terminals 7, and 8 being 12V AC.
  • 26 Answers
Hi,The PCB Transformer use for the relay switch 12v ,The Term.# 5,6,7 is for the Fan Motor speed Low,Med,High 220v .
Posted on Jan 12, 2008
  • Anonymous Jan 13, 2008
    Hi,Good Morning,The output Terminal 5,6,7 & 8 is 220v,because the three terminal using for Fan Motor Speed & Auxilliary .The 12v from transformer use for PCB switch relay.thanks
6ya staff
SOURCE:
Dynapro 65000 btu heater looks like not getting ac fuse g good no power led lite not coming on
check incoming voltage if ok check switch and fuses and check transformer voltage if ok bad board
Dec 29, 2017 | Pool & Spa
I have a carrier model 58sta110 that does not come on at all when I try to turn on the Ac. The led is OFF continuously
70 Volts is too low. IT should be the same as the house voltage. Check the outlets and breakers.
Sep 12, 2014 | Heating & Cooling
Carrier Model 310AAV036070ADJA Furnace with a Honeywell EMM 3 Zone Controller went out after storm with voltage spike. No power going into Zone Controller or from Furnace Control Board to Transformer. Got...
if it was a big spike then i am afraid that the board might be damaged. check to see if you have a voltage safety on the board if not then you may have to replace to pc board
Sep 04, 2013 | Heating & Cooling
Carrier ac light on board out
High voltage goes to board then to transformer. 24v comes out transformer into board. Check high voltage going to transformer if have votage but no low voltage out other side 24v then transformer is bad.
Aug 28, 2012 | Carrier Heating & Cooling
Carrier fernace light on board not comming on
check high voltage going to board and transformer then check low voltage from transformer to board. If you have voltage on these board is bad. Correct voltage that is.high 110v-120v low 24v-28v
Luxaire AC unit control works but the ac unit will not turn on
Sounds like it could be your transformer. See if you can locate it. It should be in the air handler indoors. Check the voltage going to the transformer and check the output of the transformer. You should have around 24 vac on the output of the transformer. If you don't have voltage on the output make sure you have it on the input (120vac). If you don't have it on the input you need to find out why. If you have it on the input but don't have an output then your transformer is likely gone bad. Let me know what you find.
May 18, 2010 | Heating & Cooling
My Carrier Infinity Hybrid Furnace/HeatPump is suddenly not responding. It's been working for a few years, but today it's acting dead. All the breakers are on. At the furnace (58MVB series 100) I hear a...
The buzzing sound your hearing is a transformer that is producing 24v ac current to the main control Board, this is what controls the unit. you can check for 24v to the main board by removing the front panel access door and finding the safty shut off switch that the door touches, and depress it or tape it so you can test for voltage.. if you have 24v ac from the transformer next test at the board, if you have voltage there you may have board issues??? check the fuse on the board, make shure all connections are good... if you do not have 24v to the board your transformer is bad, have a hvac technician service this, don't attenmpt to do this yourself if you don't have experince, you could destroy your cont. board.....
hope this helps
Jan 17, 2010 | Heating & Cooling
Screen is blank ... changing to new batteries does not help?
see if voltage coming into transformer if ok check transformer for 24 volts ac at back plug of PCB board also check fuse on back of board
Jan 04, 2010 | Jandy AQUALINK RS TELELINK KIT
Heating & Cooling Logo
171 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Donni Steen
Marvin
Marvin
