Question about Nokia E75 Cell Phone
I use my phone in the silent profile and for no reason at all it starts to vibrate as if there is an incoming call. It will not stop vibrating until I put the phone in offline mode. This happens approximately every 6 hours. How can I stop it?
My Samsung Galaxy Light won't vibrate anymore. How can I fix it or get it to work again. Thank you
Setup the Vibration
This option allows you to set your device to vibrate and ring.
1. From the main Settings page, tap My device tab ?
Sound.
2. Tap Vibrations.
3. Select a vibration pattern and tap OK.
- or -
Tap Create to then use an on-screen touch circle to
create your own custom vibration pattern. Tap Save to
store the new vibration pattern.
Sound Settings
From this menu you can control the sounds on the phone as
well as configure the display settings.
 From the Home screen, press and then tap
Settings ? (My device tab) ? Sound.
The following options display:
Silent mode via Device Options Screen
Silent mode is convenient when you wish to stop the phone
from making noise, in a theater for example. In Silent Mode
the speaker is muted and the phone only vibrates to notify
you of incoming calls, or other functions that normally have a
defined tone or sound as an alert.
1. From the Home screen, press and hold
(Power/End) until the Device options screen displays.
2. Tap either Mute, Vibrate, or Sound from the Device
options screen to activate or deactivate these features
(the current mode displays).
You can download the User manual from the site below
https://support.t-mobile.com/docs/DOC-9140
Feb 07, 2015 | Samsung Cell Phones
My Nokia 6131 has stopped ringing - it just vibrates when there is a call/text. I haven't done anything different. It's not on silent and I've tried resetting to factory defaults. Any suggestions?
its like the user profile has changed to silent
All you have to do is....
go to the settings on your mobile phone, scroll to profile and select it, click on general or loud, select personalize,check the incoming alert mode and see if it is set to ringing,scroll down and select a tone for the alert then save. after which activate the edited profile as the profile in use..
hope this helps
Jan 25, 2011 | Nokia 6131 Cellular Phone
Samsung gt e2120. how can i have it on silent without it vibrating?
Go in the profile and select any profile then select personalize and select INCOMING Call Alert on Off ( Do not select any Tune). this way ur mobile will recieve the call, the screen will show the incoming call but there will be no voice. Ensure that the vibration should also be off as you want it so.
Sep 12, 2010 | Samsung Cell Phones
HOW CAN I HAVE MY PHONE ON SILENT WITHOUT IT VIBRATING ?
Sep 12, 2010 | Cell Phones
How do I turn off the key pad tone on the impression sgh-a877
The Sound Profile only covers call sounds.
Sound Profiles
This menu allows you to specify how you are informed of
incoming calls.
Selecting a Profile
1. Touch ➔ Settings ➔ Sound Profile.
2. Touch the radio button next to the profile name. The
selected profile activates. Choices include:
• Normal
• Silent
• Driving
• Outdoor
Normal Profile
The phone’s profile defaults to Normal. Use the following
procedures to change the profile.
Editing the Normal - Call Profile
1. Touch ➔ Settings ➔ Sound Profile ➔ Normal.
• Touch the name field and not the radio button to the right.
2. Touch drop-down menu (upper-right of the screen) and
select Call.
3. Select the Call Alert Type field and select one of the
following and touch Save:
• Melody: the phone rings using the ring melody selected in the Ring
tone menu.
• Vibration then Melody: the phone vibrates and then starts ringing.
• Vibration & Melody: the phone vibrates and plays a melody
simultaneously.
4. Touch the Voice Call Ringtone field, touch to select a
ringtone and touch Save.
5. Drag the Ringtone Volume slider to the volume level you
desire (range is 1-7).
6. Touch the Vibration Pattern field, then touch to select
Vibration 1 - 5.
7. Touch Save to return to the Sound Profiles menu.
There is no mention of keyboard tones in the user manual.
Mar 19, 2010 | Samsung SGH-A877 Impression Cell Phone
Silent profile alarm Nokia E71
go to profile activate silent mode in the settings alarm mode vibrating
Jul 15, 2009 | Nokia E71 Smartphone
Can't Turn Off Silent Profile
Go to Menu > Settings > Profiles
Now select the profile that meets your needs,
For vibration alert for incoming phone calls and messages, select the "Meeting" by scrolling up or down and pressing the enter button.
For regular operation later, just turn on the "Normal" profile
For complete silent operation, with no call tone or vibe alert, just select "Silent"
Jun 17, 2009 | Samsung SGH-D520 Cellular Phone
Vibration problem
may be ur mobile ******** currupted....... u can consult customer service centre........
thank u
May 11, 2009 | Nokia N72 Cellular Phone
How to turn vibrate on?
You can change the settings of the selected active profile.
Select Menu > Settings > Tones > Incoming call alert, Ringing tone,
Ringing volume, Vibrating alert, Push to talk settings, Message alert
tone
, Instant msg. alert tone, Keypad tones, or Warning tones. You can
find the same settings in the Profiles menu.
Jan 16, 2008 | Nokia 6288 Cellular Phone
Rings when set to vibrate.
you may need to edit the 'settings' or 'details' for the vibrate profile. hope this helps :)
Oct 28, 2007 | Motorola Mobility RAZR V3c Cellular Phone
Nokia E75 Cell Phone Logo
109 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
