Question about Indesit WA 115 Front Load Washer
The rubber seal around the door of the washing machine is black and slimy. It doesn't matter how often I clean it, it comes back black.
  • Indesit Master
  • 3,463 Answers
The problem has been caused by doing too many low temperature washes, this has allowed the bacteria to build up on the seal.
The only long term solutioin is to fit a new door seal, and do more high temp washes, at least once a month, do a 90 degree wash or hotter with powder in, but no clothes.
This is called a maintenance wash, and helps stop build up of bacteria, and keeps door seal clean.
Please rate my solution.
Thanks
Posted on Nov 14, 2009
Gunge in door seal samsung Q1233 washing machine
It's caused by using too much soap powder or fabric conditioner,it doesn't get rinsed away properly and goes greasy & slimy,,,,,if its starting too smell change door seal,,,,,use bicarbonate of soda 1 or 2 times a month, no clothes or detergent,& on a 90 degree wash,,,that should stop it returning
Jun 19, 2013 | Washing Machines
Mouldy very smelly rubber seal around the door of machine. Normally only use 40 degree or lower washes have tried washing at 90degrees but has made smell much worse.
Hello, W/D here.
If you feel around the underside of the bellows seal (the rubber piece that extends from the door opening to the tub), you will feel that it is slimy and will have debris stuck in it. Use paper towels or similar to remove as much as you can all the way around the circumference of the seal. Mix up a solution (about a quart/liter) of bleach and water in a 50-50 ratio, and wipe down the underside of the seal liberally, then clean the facing side as well. Pour the remainder of the solution into the tub of the washer, along with two more cups of bleach. Fill all of the dispenser cups (detergent/softener/bleach) with bleach, and select the hottest, longest cycle available. For us, this is the "sanitary" cycle. Run this cycle, and follow this with a normal cycle to remove the bleach residue. Front loaders are more prone to moisture build up than top loaders, and, for this reason, they are more likely to produce mold and foster bacterial growth. One very good thing to do after the sanitizing cycle that you just ran is to leave the door open between wash cycles. Top loading machines were normally left open as a matter of convenience, and did not produce as much of the smells associated with front loaders. This was due to air being allowed to circulate freely in the machine between washes, keeping the moisture contend lower,making it harder for growth to occur. Top loaders also drained around the seals better due to gravity. Even with the door being left open, you may have to run a sanitizing cycle as before from time to time. How often depends on your washing pattern, the quality of your water and other variables, so let your nose be your guide. In the most severe cases of odor, where the seal itself is permeated with bacterial growth, the seal can be replaced. Other options can also include removal and cleaning of the strainer. Normally, these are not required. Regular cleanings with proper air flow will normally be sufficient to keep the washer sweet smelling.
Try the cleaning first, as this normally does the trick, and leave the door open. If need be, post again, and one of us will guide you through the process further.
Best regards, --W/D-- Please take a moment to rate this solution. Thanks.
Apr 25, 2011 | Washing Machines
Lg washer leaving black greasy marks on clothes
This is usually to do with fabric softener. Dilute it with more water. The fabric softener makes clots, and these make the marks on your clothing.
Hope it helps
* If you found this solution helpful, please vote positively.
Feb 17, 2011 | LG WM2077CW XL Front Load Stackable Washer...
Seems to collect very yucky greyish gunge around door seals which then gets on the washing and won't come off. Is there something I can run through the machine to clean it?
This video will show you how to change the door seal gasket on your washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Dec 21, 2010 | Siemens WFXD8400UC Front Load Washer
Hi, can u show me how to clean my washer to get rid of that moldy smell. there's also mold around the rubber ring around the opening and it feels slimy. Can u please help
First you should reach deep into the front door seal and run your fingers around. There is probably slime in there. You will need to thoroughly clean this with a bleach water mix about 50-50. You might need to pull the seal almost inside out to get in there good. If after scrubbing you still have black in the rubber the mold will come right back, in that case you will need to replace the seal. They are not to hard to replace but a little tricky. Here is a link that should help if you need to replace the seal or if the wire ring pops off when cleaning. Now if all cleans up well or you replaced it be sure to wipe out the seal after each use (deep in there) and /or leave the door open.
If the seal is clean and no mold present and it still smells then you likely have a clogged drain pump filter or pump. Here is a link that should help cleaning a drain pump or try this one for cleaning a ge drain pump filter and this one for cleaning/replacing a Kenmore drain pump
Oct 07, 2010 | Maytag Neptune MAH9500A Front Load Washer
The rubber on the inside front of the washer ("the door boot") gets very dirty, slimy and is all stained. As I pulled the rubber back to clean it, it was digusting ! It is starting to leave marks on the...
at this point and time the best thing to do is replace the door seal.and then make sure after each wash cycle you dry out or leave the door open somewhat in order to help keep it dry and clean
Jan 27, 2010 | Frigidaire ATF6000ES Front Load Washer
Hotpoint Aquarius WF740 My washing is coming out with dirty marks and bits of slimy dirt. I wonder if it is from the door seal as this is dirty or could it be something else? I used the persil gel filled...
Your pipe to the water pump exit is probably blocked with bits of old fluff or missing sock, i found that the clothes had slimy bits on mine, i tilted it up and removed the rubber water exit pipe from under neath, cleaned out all the rubbish and works a treat now.
Oct 19, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Slimy mold in rubber seal
Hi, Just dry the seal after a wash and leave the door open just a little. Leaving the door cracked will also help with the smell allowing air to circulate through the machine. ALL front loads have this problem with mold and that strange smell.
Sep 05, 2009 | Washing Machines
Mold on the rubber seal of bosch washing machine
RUN A LOAD OF HOT WATER WITH 1 QUART OF WHITE VINEGAR, THAT WILL KILL THE MOLD, THEN WIP IT OFF THE SEAL
Aug 24, 2009 | LG WM-2277HW Front Load Washer
Indesit WA 115 Front Load Washer Logo
293 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
