Question about Western Digital (WD3200JS) 320 GB Hard Drive
My 320g my passport from WD does not start anymore the light just stay on what can i do. can you help me
SOURCE: dropped a WD passport drive, now it won't load. HELP!
Unfortunately, these drives are not made to be dropped.
It sounds like it was damaged by the drop which could have rendered the read/write heads inoperable or mis-aligned.
Contact Western Digital for a warranty replacement.
Posted on Apr 29, 2008
SOURCE: WD Passport not recognized anymore
Change your USB cable, I had same problem...changing the USB cable woked for me.
Posted on Oct 22, 2008
gambit3rogue
  • 106 Answers
SOURCE: Guys, I have the same problem. I got a WD passport
Sorry to hear of your misfortune I know how lossing data can really hurt. So you're saying it recognized the drive before and now it doesn't? Ok this is a simple way to find out what the problem. Go to the Control Panel, Click On Add Hardware press ENTER and a list of hardware will display; what you want to look for is ant type of Yellow Symbol (be it a question mark or a Yellow triangle. Highlight any Yellow objects, Click Next. and Voila your question will be answered, all you gotta do is get what is missing be it a Driver or a cable and your good to go. Hope this helps.
Good Luck =)
Posted on May 30, 2009
bob_computer
  • 3153 Answers
SOURCE: 320G WD Passport, it stopped working!
One or more of the hints below will probably sort out most USB problems with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
6. For FLASH DRIVES you should ensure that the device is set for "quick removal" using the drive control panel properties or use the USB "Safely Remove Hardware" option. If you dont do this there is a very strong chance that any files you transfer may not be there when you plug into another computer.
7. It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
You should also do this to cheack the drives connections are not bad inside the enclosure.
8. If none of the above steps help look at updating the drivers from the manufacturers web site in the support section.
9. If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
SPECIAL NOTES
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care.
This is a real hard drive ! and knocks and bumps can quite literally kill them.
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear.
Known as "The Click Of Death"
Posted on Nov 01, 2009
Testimonial: "Thank you for these details and different answers! I hope one of them will be the solution! Thanks again!"
bob_computer
  • 3153 Answers
SOURCE: 250gb wd passport contents not visible in my computer
10. ensure that you have set removable drives for "quick removal" or that you use the "Safly Remove Hardware" option often shown on the lower toolbar.It is possible that files my not be fully written to external devices before they are removed. This corrupts the file itself and even on occasion the drive.
Posted on Nov 10, 2009
WD MyPassPort 320 GB partially dead after an attempt to make it Win8 recovery drive.
Maybe you can try to format it to see if you can get the space back. But one thing important is that you may need to backup your files first. If not, you may lose them. Or you may try some file recovery tool after you format your drive. This may be help, I've try it, workable. http://www.uflysoft.com/data-recovery-mac/ Hope it can help and hope you can get back your 320G back.
Jul 16, 2013 | Western Digital Wd 320gb My Passport Elite...
My WD my passport not working
maybe the cable plug of the WD my passport is broken
Apr 18, 2013 | Western Digital My Passport Essential...
I want to unlock WD My Passport 320G
These WEB site may remove the hard drive password.
HARD DRIVE PASSWORD UNLOCKING - Purchase
http://www.hddunlock.com/purchase/ A-FF HDD Unlock Wizard (HDD Password unlocking - Free)
http://www.hddunlock.com/download/
Feb 12, 2013 | Western Digital My Passport Essential...
I dropped my WD Passport 750gb drive. When connected the light comes on and blinks at times, I can also feel the disk spinning, and it makes some sounds like 'sparks'. After a while (3-5 minutes)...
Test the drive for problems using Data Lifeguard Diagnostics for WindowsPlease refer the link below:
http://wdc.custhelp.com/app/answers/detail/search/1/a_id/940/c/130/p/228,195,255
hope this helps.
Feb 11, 2013 | Western Digital 750GB WD My Passport...
When I plug my 320G WD Elements there is no WD icon on my windows or my computer window. thanks
Have you used this HDD before?, it this is the first time?
Sometimes you have to install the WD Smartware Software. In the case of the 320G, which are the first HDD released, The computer should detect them automatically.
Try with another USB port. Do not use a USB multiport because it won't power the HD.
If it doesn't work on your computer, try it on another one. This way you can discard the possibility that the HDD is damaged.
God BLess You!!!
Feb 14, 2011 | Western Digital Passport 320GB External...
My external harddisk - WD 320G(my passport essential) can not recoginze on Window 7. Please help to slove.
First check physical connections of hard disk to your cpu. Check in 'device manager' disk drives tab. If its found check in "disk management" in that drive which file system its showing. If it shows raw partition mean your file system is corrupted. It requires remove that partition and create a new partition.
for open device manager : start > run > devmgmt.msc
for disk management : start > run > diskmgmt.msc
Aug 04, 2010 | Western Digital 320GB MyBook External USB...
Western digital 320g elements portable won't work
Hey,
try connecting it o another computer and check
if not yet, use only the WD USB transfer wire supplied in the box.
because WD External HDD only recongize its own USB and none other.
May 03, 2009 | Western Digital Elements powered by WD 320...
Guys, I have the same problem. I got a WD passport 320G. At first It work perfectly then became not detect anymore.I choosed to call up WD support office and they agreed to change a new set for me but the...
Good Luck =)
Apr 03, 2009 | Western Digital Passport WDXML800UE...
Jul 30, 2008 | Western Digital Passport WDXML800UE...
Western Digital (WD3200JS) 320 GB Hard Drive Logo
211 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
