Question about Panasonic CT-32HXC14 32" TV
Replacing CRT neck socket after arcing problem.
Hi, see below for more info, I am trying to find a parts source for this plastic socket guide. it is the piece that fits on the end of the CRT to protect the glass end and support the pins, it also aligns the neck board socket so it goes on correctly. also, is moisture likely to build up on the neck of the CRT? I live in the southwest US where its normally pretty dry, seems odd that moisture would collect inside the set. I still plan on getting the service manual for the set and verifying all the neck voltages etc. don't want to repair it and have it arc again because I overlooked something. Also, if you know the actual industry term for this part so I can search the web for a replacement that would help too. If you need photos ans measurements of the part let me know. Thanks posted by wastric on Jan 08, 2008 Report abuse
there is a random arcing between the pins of the crt neck connection on my CT-32HXC14J, worse on power up , gets less as it warms up. I have isolated it to under the plastic alignment cap that fits over the end of the CRT and its pins. After carefully cutting thru the sealant that holds the plastic cap to the CRT neck and cleaning off as much of the charred and blackened sealant as possible, the arcing has gone away. I need 2 things, 1 what should I check that might have caused it to start arcing, i.e. B+ too high, bias off, loose ground etc. and 2. whats the best way to clean off the glass around the pins to reduce the chance of re arcing? should I use some corona dope coating as well? Thanks
Comment by wastric, posted on Jan 08, 2008 I hope thats all that caused it. anyone know where I can buy a replacement CRT base socket , there was no arcing on the neck board socket half so its good to go. I really don't want to leave it without that socket piece. it makes sure the neck board goes on correctly, and helps support the weight so the crt pins are not carrying all the weight. Its been a long time since I worked in consumer electronics so any ideas about a parts supplier that can get me that plastic socket end/guide would be great. I can post a photo and take measurements of it. Is it a generic part or unique for every make of TV?
Still need a solution for this problem?
Try our Premium Assistance plan Best Solution posted on Jan 08, 2008
chrispurs1
Rank: Wiz
Rating: 82%, 121 votes
  • 3 more comments
  • William Strickland
    William Strickland Jan 10, 2008
    I have ordered the socket base from Panasonic. as far as your other question, yes I am sure it was arcing outside the CRT, I tested it in a dark room and was able to see it was above the back layer of glass at the end of the neck. after removing the old crt base socket and cleaning off alot of the RTV silicone adhesive used to hold on the socket( that showed signs of arcing i.e. carbon traces etc. ), I put the neck board back on and turned on the set. no more arcing was seen. before it was very bad right when you turned on the set, after letting it run for about 5 min. without arcing I turned it off and went to work trying to get more of the adhesive off. still alot left but will have it cleaned off by the time the part gets here.
    William Strickland Jan 17, 2008
    bad news, the part I ordered turned out to be the socket that is soldered onto the neck board, not the CRT end. Panasonic checked and the part I need is not available, so I have to find another way to fix this. any ideas? I have no problem with ordering the part from Asia or Europe if its for sale there. I am going to identify the CRT manufacturer and see if I can order it from them. they must use this same crt end on more than just one crt.
    William Strickland Jan 18, 2008
    I will take a photo tonight when I have time to open up the set. I don't need the socket that solders to the neck board, I need the plastic end cover that protects the CRT glass nipple and gives extra support to the pins of the crt as well as helps align the neck board socket when you are plugging on the neck board. this plastic cap/support/alignment guide is held onto the end of the neck of the CRT with white silicone sealant/adhesive.it has holes in it to go over the pins and a center cap area that protects the glass nipple that sticks out between the pins. the arcing happened between the pins of the crt right along the outside of the glass,it arced thru this adhesive, the adhesive and the plastic cap are slightly charred with carbon from the arcing. I am in the process of cleaning off all the adhesive and plan on cleaning the glass with alcohol and a synthetic scrubber to prevent scratching of the glass, but getting all the carbon off. then I want to spray the glass surface with red corona preventing spray coating. I am worried tho that if I don't replace the plastic cap, the residual carbon imbedded in it will cause future arcing. my next step will be to identify the CRT manufacturer and try to contact them about a replacement CRT end cap. any ideas would be very helpful. the tv still arcs every once and a while, but getting the charred adhesive off reduced it greatly.
    William Strickland Jan 20, 2008
    here are some photos of the part I need
    William Strickland Feb 13, 2008
    I actually saw the arcing happening under this plastic cap between the pins of the CRT. it arced enough that it caused charring of the underside of this cap and of the silicone adhesive that bonded the cap to the end of the CRT. once I removed the cap and cleaned up the adhesive, the arcing stopped. I still have the replacement crt neck board socket. altho the arcing was happening clearly at the very end of the crt itself, not inside the neck board socket, I might still swap out the socket since its too much of a pain to send it back to Panasonic. once I put the plastic cap back on the neck of the crt, it would randomly arc every once and a while, I think the carbon build up impregnated the plastic and allows it to arc when the cap is re installed. I can not find a source for the cap so I plan on cleaning it as well as I can, then coating it with anti arc spray coating before re installing it.hopefully this will be enough to stop the arc path.
    Problem Solver:
  • 7 Answers
If anyone is looking for a solution to this problem my CRT tv was arcing as well. I disassembled the white socket that the crt plugs into which is on the neck board and found a TON of corrosion making it hard for electricity to pass through the connections. I cleaned them as best as i could and the set quit arcing. I figure the excess energy it couldn't pass through the contacts arced to the next pin over.
Posted on Mar 12, 2010
  • 372 Answers
Hi.
Don't know what happened to the last post I sent you its disappeared.
What I think you should do is definately replace the CRT white socket (tube base plug).
You can either take the CRT number from the label on the tube & put it in to google then search for Crt base plug.
Or see if there is A repair shop local to you who can order the tube base for you.
Are you definately sure the arcing is external to tube & not happening in the tube neck ?
Is the CRT made by LG / PHILIPS. These are notorius for for arcing over internally I must write at least 1 A week off for this problem.
If you can still run the set try tapping the neck of tube with screwdriver handle if pic flashes or goes predominately1 colour you are looking at the tube with internal short.
If this is the case there are ways of trying to get rid of the internal short let me know what you find ?
http://dysonmanuals.llc.nu/
Chris...
Posted on Jan 09, 2008
  • chris pursloe
    chris pursloe Jan 18, 2008
    Hi
    Im A bit confused by your last post.
    The plug you need is the one with approx 8 holes to go over pins protruding from the tube neck & solders to rectangular pcb.
    But I think im right saying this is what panasonic sent you & thats not what you require.
    Can you post A picture of what you are after.
    Chris.
  • chris pursloe
    chris pursloe Feb 12, 2008
    Hi.
    I have looked at the pictures this socket will not cause any problems with arcing.
    You need to replace the plug that connects crt to the pcb I think you said you ordered this part & sent it back.
    If you desolder the old plug from the crt pcb & cut it open you will see that it has been arcing internally.
    They do break down its very common in some sets.
    Chris.
2 Suggested Answers
chrispurs1
  • 372 Answers
SOURCE: Arcing between pins on CRT
Hi.
Your problem is due to moisture in the the Crt base socket you will need to replace the white plastic crt plug I have tried to clean & dry them out but it never fully corrects problem.
As far as the pins & glass crt neck goes clean them with Isopropyl alcohol this will thoroughly clean all the carbon off.
Chris..
Posted on Jan 08, 2008
RCA projectionCTC169 Chassis PTK169PTBTV CRT cup arc to chassis
Fixya is unable to suggest sources for RCA parts (perhaps RCA).
Aug 08, 2018 | RCA Televison & Video
Sonykv32s20 screen wont turn on, stays dark, but sound works
Its a older set, if you are able to open safely and run set JUST look to see if the faint filaments in the neck of the picture tube are lit, 6.3 volt filaments, and if they are not somewhere between source at High voltage transformer up to the PC board and socket at end of tube neck you have either a broken/bad solder connection or a open part--only about a dozen connections/parts between the two----set will have a ground and a voltage source at both ends of this chain, a bad solder connection will do this if filaments not lit(3 of them in neck of tube).
Oct 15, 2012 | Sony KV-32S20 32" TV
Hi i have a conia c2906 and today we have hypercolour red yellow and we have tried almost everything, no red
You better check the CRT socket section,it is connected to picture tube neck.It is a small PCB board.Resolder the terminal of CRT socket and the color output transistor around the CRT socket.Resolder also the chroma section at the main board located at the center part of the board.Hope it will help you.Thanks..
Sep 04, 2011 | Televison & Video
Picture keeps gettingn dark and you cant see anything? what can i do
hi,
may be ur tvs picture tube base ( crt socket) have some problem. u can see socket on the base board on the end of picture tube neck. replace the same and then try again.
ok
Dec 27, 2010 | Sansui DTV2750 TV
I hear audio but the screen is black.
If everything else works - there is sound and high voltage (static on the screen) - but there is no picture (including no on-screen menus), this limits the likely area of problems is the video output circuitry or CRT filament connections. Check to see if the CRT filaments are glowing. If they are not glowing, check for bad soldering on the CRT neck board and around the flyback transformer.
Where the picture is erratic - coming and going entirely or changing brightness suddenly, with power off, remove the picture tube socket (carefully!) and clean the pins with fine sandpaper and use contact cleaner on the socket. This source of bad connections can result in a variety of erratic symptoms. Check for bad solder connections on the CRT neck board.
Hope this will help...
Jun 01, 2010 | Emerson EWC1304 13 in. TV/VCR Combo
The picture on our tevion television just disappeared. We have sound, but no picture at all. this happened very suddenly in the middle of a news broadcast.
May 26, 2010 | Televison & Video
I have a Digital Lifstyles 42
GOOD LUCK....
May 21, 2010 | Digital Lifestyle FA1B32Z 32 in. LCD...
MY SONY DOESN'T WANT TO START..IT WILL SNAP TO TRY AND COME ON...THEN TURN OFF AFTER ABOUT 5 SECONDS..HELP?
The snap you hear is likely from the high voltage in the set. The worst case scenario is that the picture tube (CRT) is shorted and is arcing internally causing the set to shut down. There are other less expensive possibilities such as the flyback transformer which can also fail in such a way as to arc. You may be able to see through the top ventilation slots in back as you power the set. The neck of the tube extends back into the rear cabinet and you could possibly see a flash inside the tube neck if it is arcing. I would have to recommend you have a technician check this problem to diagnose it. The tube, if it is defective and out of warranty, would exceed the cost of replacing the TV. Check your warranty as the tube generally has a two year warranty and other parts one year with 90 days on labor.
Nov 12, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Hi.
Chris..
Jan 08, 2008 | Panasonic CT-32HXC14 32" TV
Arcing around neck board
sounds like bad crt if you saw arc inside glass...no economical fix-replace the monitor
May 30, 2007 | Likom ViewMate LP995 (White) 19 in.CRT...
Panasonic CT-32HXC14 32" TV Logo
5,062 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
