Question about Medion MD-1704 PC Desktop
XP OS switch on my computer Windows XP OS and it just restarts and restarts. How do I stop that
    President:
  • 4,402 Answers
Press F8 at startup and go into safe mode
Posted on Jan 08, 2008
Asus a2800s
Hi George, sorry to hear/read this about your laptop.
One, you need to make sure your laptop's configuration matches the recommended environment under which Windows 7 OS was to be installed.
Check what system requirements for Windows 7 OS is and compare with your laptop.
Second, you may have to revert back to Win Xp for your laptop to re-stabilize.
Another option is to install Windows 7 Ultimate. This should operate fine on your laptop.
Post an update or feedback please.
Oct 11, 2017 | Computers & Internet
Error on windows xp desktop page_fault_in_nonpage_area
You receive "Stop error code 0x00000050 (PAGE_FAULT_IN_NONPAGED_AREA)" or "Stop error code 0x0000008E (KERNEL_MODE_EXCEPTION_NOT_HANDLED)" when you restart a Windows XP-based computer uparrow.gifBack to the top ' Give Feedback 20x20_grey_minus.png954211 MS08-061: Vulnerabilities in Windows kernel could allow elevation of privilege
  • 959252 Error message when you switch the operating system from a dual monitor setting to a single monitor setting on a Windows XP-based computer or on a Windows Server 2003-based computer that has the security update 954211 installed: "Stop 0x0000008E"
  • Note Update 959252 addresses a known issue that was introduced by update 954211.uparrow.gifBack to the top ' Give Feedback 20x20_grey_minus.pnguparrow.gifBack to the top ' Give Feedback 20x20_grey_minus.png824684 Description of the standard terminology that is used to describe Microsoft software updates
    Jan 06, 2014 | HP Computers & Internet
    My windows OS is not genuine. How can I change my operating system without using CD? or free download
    Unfortunately if you don't have your CD key, there's no way you can make your Windows XP genuine, without purchasing a new one or installing a valid copy of windows. However, there are operating systems out there that are free to use. Linux is a great operation system capable of nearly anything. Depending on what you are using your PC for now it may be an easy and great switch. Pinguy OS is a variety of Linux designed to be easy to use for any user. All you need to do is download it and install it to a disk. Pop in the disk and restart your computer to install. If you prefer windows, now is a great time to get a genuine copy of Windows XP for a cheaper price now that Windows 7 is available, or you might even consider making the change to Windows 7. It's really a great OS! Hope this was helpful. Here is a link to Pinguy OS: www.pinguyos.com
    Jan 05, 2011 | Microsoft Windows XP Professional
    My computer keeps on restarting everytime I connect a USB device like, flash drive, printer etc. I tried restarting my computer, then when everything's done loading, i connected a flash driver and after a...
    I would reinstall xp OS... you should be able to do a restore without loosing any of your own files. After an os restore you may have to reinstall a few programs but your data files should be ok if you do the correct type of install.
    Sep 22, 2010 | Microsoft Windows XP Professional
    Insataling windows xp problms
    i believ ur using 32 bit operating system.change the boot sequence by pressing F12 at restart and select cd/dvd rom option while the windows cd still inside the drive,,format the c drive completely{if possible format the whole hdd} and then reinstall the windows os xp..i hope it will work fine,,just follow the screen prompts very very carefully and u will find everything mentioned,,best of luck
    May 14, 2009 | HP Compaq Presario CQ60Z Notebook
    Error installing windows xp
    hi! there,set up exe. that was when your setting up win 98 you have to install that came from floppy disk before you can install win 98.there is an os win 98 in your system you have to delete that previous os before installing another win xp.restart ur computer. press F2 to open your bios set-up . then select bios set-up priority your cd-room drive second,your hard drive. last, quit and save set-up. and then your computer will restart. insert your cd windows xp then reinstall your window xp. delete the previous os then follow the set up on your window xp until you install your new window xp.
    Apr 01, 2009 | Compaq Presario S4020WM PC Desktop
    Computer restarts on shutdown
    If your computer constantly restarts while you are using it, or if you are trying to shut down the computer after it has stopped unexpectedly, click to clear the Automatically restart check box. If you clear this check box, you receive an error message when the computer stops responding. This error message may describe the cause of the problem. You can also review the system log in Event Viewer to view the critical stop error that occurs when the computer restarts.
    1. Click the Start button, right-click My Computer, click Properties, click the Advanced tab, and then click Settings under Startup and Recovery.
    2. Under System Failure, view the Automatically restart check box. If the Automatically restart check box is selected, Windows automatically restarts if the computer stops unexpectedly.
    Thanks & Regards
    Nandu :)
    Mar 25, 2009 | MSI Computers & Internet
    Dunno what happen??
    When You Boot up your screen goes in to the windows xp loading bar and after a quick blue flashin screen pops up and it restarts unfortunately this is what they call the Blue Screen of Death so more than likely you harddrive with the os is corrupted so either you will need to reload the OS or by a new harddrive and load the Os on that Harddrive
    Jan 22, 2009 | Microsoft Windows XP Professional
    Windows XP stops at "shutting down"....
    It seems to me that You need to uncheck the "delete paging file at shutdown". Deleting the paging file slows the shutdown of Your system considerably.
    Jan 11, 2009 | Microsoft Windows XP Professional With...
    Medion MD-1704 PC Desktop Logo
    Top Medion Computers & Internet Experts
    Larry Chandler
    Are you a Medion Computer and Internet Expert? Answer questions, earn points and help others
