Question about Home
The water was of in my area for most of today now its back my triton shower wont work its turns on but the the water is only driping out
    President:
  • 1,515 Answers
Hi, the reason for no water is you have picked up dirt and sediment in the lines when they turn you back on.You will find aerater on faucets to unscrew and clean the screens, try taking the end of the shower head off to clean out the sediment. This is the reason for no pressure. You may have to wrench the head completely off to clean it. Good Luck,
Shastalaker7
Ps, After removing it, let the water run to clean the pipes and flush the water heater.
Posted on Nov 14, 2009
Triton shower faults
If its a trickle occasionally its normal, when you turn off shower the water is still in pipe right up to shower head, it cools down, contracts and backs away from the head, when house gets warmer water expands up to the shower head and trickles out.
Dec 14, 2013 | Home
My Triton t80si shower "cycles " going hot then cold then back to desired temperature - only just started happening no problem with flow of water
It sounds like the cartridge has to be changed. Pressure balance is not working in the cartridge.
Apr 13, 2013 | Home
We have triton cascade power shower and the water keeps coming out even when the power is isolated.
I too am having exactly the same problem with my triton 300 si. I have noticed that since this behaviour started the red light around the on/off switch is no longer illuminated (whether it's on or off).
I have tried calling the technical support but they wont help since it's out of Guarantee. Have you noticed any other features missing or not working?
Aug 01, 2010 | Hansgrohe Showerhead Shower Power ...
Hi i just installed a triton cara shower and the water wont turn off
It is probably the water solenoid valve wich is stuck or bunt out.
If it is brand new, maybe you have warranty.
May 20, 2010 | Home
I have a triton shower and today when I switched it on only cold water was coming out... Now when I tried to switch it on again the pressure light is not on and now not even any water is coming out of the...
It is a rare occasion that the system needs to be replaced. I would call a local professional plumber and have them repair the problem. If you are unsure as to getting a "GOOD" plumber ....contact your local Plumbing Wholesale Company and ask them for a referral make sure you tell them you have a Triton System with the model if possible.
Aug 06, 2009 | Home
My triton martinique electric shower low pressure light comes on and the water goes cold but there is nothing wrong with the pressure
I had a brand new Triton Rapide 3 with this issue, we had good water pressure but the light on the front would keep coming on.
I found there was a micro switch located at the front almost dead center of the shower, couldn't miss it when you removed the cover. A plastic arm below this switch is raised when the water pressure increases tripping this switch and allowing the heater to come on.
I found two things wrong with this, one this plastic leaver was thin and bent easily and secondly the switch did no line up overly well with the lever. Easily fixed, I cut an inch off the end of a zip tie or panduit strap, and super-glued it to the top of the lever (not the switch as the glue will probably ruin the micro switch.) 5 minute job later and with the shower back together it works beautifully. My wife will be happy, you wouldn't believe the torrid of curses I got this morning having only replaced the old unit last night.
Probably don't need to say this but, make sure you isolate the power before removing the cover.
Jun 03, 2009 | Sony Playstation 3 (PS3) Console
Triton electric shower T90si ran dry and not now working.
pump needs attention and the heating element has burnt out
pump needs water to run and the heater element needs water to keep it cool
Sep 07, 2017 | Heating & Cooling
Triton T80si shower will not switch off
its the water solenoid valve stuck in the open position so when the shower is turned off the shower stays running
Dec 09, 2008 | Home
TRITON Trance electric shower
I have a triton trance shower not working with power and water both connected properly! low pressure light coming on and nothing happening????
Mar 27, 2008 | Dishwashers
Home Logo
116 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
