Question about Hamat 3-3942PC Deco V Kitchen Faucet with Metal Side Spray Polished Chrome...
Low water pressure in both cold and hot water. Plenty of pressure at supply but not at faucet. As a matter of fact, if I turn on the hot water and then the cold water at the same time the flow does not increase. If I disconnect the cold water at the supply line and turn on the hot water, I get plenty of pressure back through the cold water line.
  • jimimac169 Nov 16, 2009
    I have checked for twists, and can't find any. I do wonder about the presssure reducer, but don't know where to look for it.The fact that the watrer flowing directly through the hose i.e hot water into the faucet and back through the cold water hose, flows normally, makes me believe that something inside the faucet is causing the problem. Is there a way to remove the effect of a reducer?
    President:
  • 1,653 Answers
You are most likely being severely limited by the bore of the internal pipes in the faucet which are a lot smaller than the supply pipes and effectively act as a pressure and flow reducer.make sure that any flat washers you are using are not causing the flow restriction - I have seen this in many new faucets where the hole in the flat washer is far too small. Also check that the faucet is not fitted with pressure reducers - as again I have seen this in many new faucets on the market. Also try removing the spout end - which may be an aerator fitting to see if the flow improves. Aerators will simply block more of the flow. Other than that make sure that if you are using flexi pipe tails to connect to the faucet that they are not twisted or creased or mis shapen and thatth internal rubber tubes have not collapsed.
Posted on Nov 14, 2009
  • Karl Wright
    Karl Wright Nov 16, 2009
    Having checked over the tap diagrams and parts the only things that will definitely cause a pressure restriction are the flexible feeder tubes & tails and the aerator and screen. The actual flow capacity of the 10mm tube will be 0.44 times that of the main supply line on both hot and cold supplies. The head work assemblies should not cause any additional restrictions but check the sizes of the holes in the head wells to make sure they are not obstructed or have any burring on them. Also check the state of the washers. Assuming that you have isolation valves in the supply lines of both hot and cold supplies you could remove the tap head assemblies for both hot and cold and turn on the isolators to see if they era causing any flow restrictions and make sure that the diverter is the correct way up with the smaller side pointing down. The replace the head assemblies any try the taps again and this time remove the aerator and screen. Otherwise you are simply down to the tap either being defective or simply not being up to the job or the inlet pressures not being high enough. Test your water supply lines for flow rate – how long does it take for each line to fill 2 litres or half gallon in a bucket or measure? Then connect the tails and try the same. Then do the same with the faucet connected to the tails. If you see large differences between the results of the tails and the faucet then you could be seeing design or manufacturing fault with the faucet.
No hot water on New Kohler touch less kitchen faucet. Had plenty with old faucet I'm replacing.
You need to make sure that the small flex line going to the water supply is not kinked than if that dont work make sure theres no trash in the cartridge
Oct 05, 2016 | Kohler Plumbing
When turning on the shower faucet there is no hot water.
Can you remove handle , behind handle there should be a dial to move to increase hot or cold supply.
Remember where you start and remove it and replace a 1/8 to 1/4 turn counter clockwise, just put handle on try it and see if it changes and adjust accordingly.
May 14, 2010 | Kohler K-T12007-4s-BV Brushed Bronze...
adjust ur anti scold the setting is set to low when single handle shower units are shipped they are set in cold mode for safety ur install/instructional paperwork explains such and also advises on how to adjust---remove handle and on shaft will see a blue and red plastic clips that are adjustable slide towards u and move red for more hot water test water continue till comfort level is reached for hot water
Mar 24, 2010 | Kohler K-T12007-4s-BV Brushed Bronze...
The hot water side has low water pressure. The
start by making sure the valve that supplies hot water to the sink and dish washer is fully open. If there is low hot water pressure in any of the other kitchen/bathrooms, then trace the line to see where the pressure drops. If it is only in the kitchen, it should be an old valve, (causes restriction)Good Luck.
Oct 10, 2009 | Whitehaus Kitchen Single Handle Faucet...
No water pressure in bath tub after turning off hot water heater
It could be back flowing into the hot water heater tank which is not full because of the leak. Even though the valve is closed on the cold water entry side, there is probably no valve on the exit side. That is how it is returning to the tank.
Sep 14, 2009 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
No hot water, and low pressure
Do you get hot water at other faucets? If not, check to see if the valves at your hot water heater are completely open. You may also have a blockage somewhere in the hot water line.
If you aren't getting hot water at just one faucet, it's likely that the hot water side of the valve needs to be repaired. It could be that there is a blockage in the valve that needs to be cleaned out, or seals in the valve may need to be replaced. Rebuild kits are available for many shower faucets at your local hardware store.
Be sure to turn off the water supply before attempting to disassemble the shower valve.
Sep 05, 2009 | Home
We installed two new single handle shower faucets with both hot and cold supply lines pressurized to each of the faucets. The problem is that no hot water will come out of either faucets. Their seems to be...
Sounds like the valve is defective. The supply to the stems was not bored out at the factory giving you a valve that is essentially pretty on the outside and solid on the inside. To test it, uninstall the valve. Remove the stems. Then try running a pipe cleaner though the valve from the supply side and see if it stops before the stem.
Aug 15, 2009 | Moen & One Handle Tub & Shower Faucet
Hot water pressure is fine, cold water is low.
You may have debris caught in the supply line or the mixing valve. You will need to take the unit apart after you have turned the water off and inspect those parts. Also, some of the new faucets have cut off valves already installed on the faucet, if you do make sure that they are fully open as well.
Mar 31, 2009 | Grohe Plumbing
Low pressure and flow on hot water side of single handle faucet
It could be one of two problems, one simple, one serious.
  • Easy fix
  1. Turn off hot water angle stop under sink to faucet.
  2. Remove supply line from hot angle stop.
  3. Place end of supply line in a small bucket to catch some water.
  4. Turn on cold water for a couple of seconds and backflush debris from faucet.
  5. Reconnect supply line.
  6. Turn on angle stop and test
  • Complex fix
If you have steel pipes you may be experiencing reduced flow due to corrosion in your pipes. Reduced hot water pressure in the kitchen faucet is usually the first sign since this is the faucet that is most used in the home.
Repiping is a job for a professional. Another symptom you may need a repipe is orange colored or rusty water.
Nov 14, 2008 | Delta Faucet Plumbing
Hamat 3-3942PC Deco V Kitchen Faucet with Metal Side Spray Polished Chrome... Logo
163 people viewed this question
Top Hamat Plumbing Experts
Colin Stickland
Colin Stickland
ray gallant
Daryl Gleaton
Are you a Hamat Plumbing Expert? Answer questions, earn points and help others
