Question about Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White
Me the owner greats you at the door and explains half of the house is completely without power. None of their 220 volt appliances seem to be working, however when the stove is turned on the receptacles and lights which are currently not working begin to work. What is the cause of this problem? Where would you look first and what would you be looking for?
  • 68 Answers
Check receptacle wiring, then breaker box.
Posted on Nov 14, 2009
What is the power requirement for installing a Simpson 2001 66-647 thermaflow freestanding oven?
For Electric Range - 220 - 240 volt, 60 hertz, properly grounded circuit with 40 amp breaker or fuse protection with #8 gauge wire. With a 50 amp breaker, # 6 gauge wire is required.
The owner's manual below mentions the wattage. (download the document, hit CTRL-F on your keyboard, type in wattage.) You might contact the manufacturer or for that matter the electric company servicing you.
https://john.daltons.info/appliances/Simpson_2001_models_68-642_and_68-646.pdf
Jun 11, 2017 | Ovens
Oven doesn't seem to work though te light goes on
Check your circuit breaker for the house. It will be 2 breakers side by side with their handles pinned together. If one trips, but not the other then you'll get 110 volts to work the light and the control panel but not 220 volts for the element.
May 15, 2017 | Ovens
Top oven door is locked...cant open
It should go without saying that it is IMPOSSIBLE to answer your question without first knowing the MAKE and MODEL of your oven.
That being said, if you just ran a self-clean cycle, you cannot open the door until the oven has cooled. If you have not just run a self-clean cycle, the interlock may have failed.
May 14, 2015 | Ovens
I bought a GE microwave oven model wes1450dm1bb at the USA, but now I am in a different conutry that uses 220 volts as standard. I just read the user manual and in any place says the voltage of the...
No, You'll burn up the appliance. When I was in Germany there were commercially available transformers to step the current down. The transformers plug into the 220 sockets and provide several 110 sockets to plug your appliance into. We purchased several transformers and ran our 110 tvs, kitchen appliances and other 110 appliances. The 220 sockets in Germany were different than 110 and 110 plugs sould not fit.
Feb 23, 2011 | Ovens
How do I know if my Hotpoint oven 920 years old0 is on a 220 0r 120 line? The serial plate says 120/220.
An oven uses both 120 & 220 -- actually it would be 120 volts and 240 volts or nominally, 110 volt and 220 volt.
The 120 is used for the lights. The 240 is used for the heating elements.
A 240 volt breaker (nominally 220 volt) -- supplies both 120 and 240 volts depending on how the supply is connected to the appliance.
There will be a 240 volt (nominally 220 volt) breaker in the main panel for the oven. This is two 120 volt breakers side-by-side with their toggle switches connected together with a strap across the top of the toggles.
Charlie
Jan 11, 2011 | Hotpoint Ovens
3 wires black white ground from box from oven red black white ground what goes where
the appliance is 220 volt and the box you are describing is 110 volt. You cannot connect to this box. You need a new 220 volt circuit ran from your main panel box to the appliance with a 220 volt 3 prong outlet box like an electric dryer uses or make the connections in a box without using the plug system
Aug 17, 2009 | Frigidaire (FEB30S7D) Oven
Maytag elect. wall won't bake nor broil
I suggest checking the voltage going to elements. If there is no current, trace wires. Not exactly sure if there is a fuse/relay on your model. If there is current, than the elements may have gone bad.
May 22, 2009 | Ovens
3 prong outlet/4 prong plug
If you bought an electric range , it is a 220 volt range with a BIG plug and can only be used in a 220 volt outlet.
If you can plug a small appliance into that outlet then the outlet is only 110 volts and you need an electrician to run a new 220 line!!!!!!
Was the range you are replacing a gas range??? If so that runs on 110 volts like you TV and toaster and every other small appliance in your house!
If you are not sure what you are doing get a professional to help you!
Every year in the United States thousands of people die buy trying to fix the electrical in their home alone!
BEWARE 220 Volts will shock you! BUT USUALLY will kill you if you touch it!
ngafm
Please rate me on this site before you sign off!
How old is the appliance?
If the appliance is 10 years old or more you it may not be advisable to put good money into bad!
New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
Water,Electric and detergent! And put money back in your pocket!
The new appliance will pay for itself in only a few years!
You will be fine
Bless You ngafm
PLEASE GIVE ME A GOOD RATING HERE AT FIXYA.COM BEFORE YOU SIGN OFF!!!!!!!!!!!!!!!!!liance in your house!???????????????
Sep 06, 2008 | Ovens
3 wire oven with 2 wire source
Your new oven utilizes 220 volts, but it also has some 110 volt features that need a neutral to work properly. Your old oven was wired without the neutral, probably when the house was built. There are 2 answers to your question. #1, no you should have an isolated neutral or common (same thing) wire, so it should have one. #2, if you connect the white on the new oven to the ground wire it will work. The neutral wires are all connected to the grounds at the breaker panel. Look at it if you don't believe me. The ground is there as a safety to you. if you connect the neutral (the white wire on the new oven to ground) you will be eliminating the safety feature on that appliance. So, I do not recommend you connect the white wire on your new oven to the ground wire out of the wall. But if you do it will work, you will just not have any back up protection if there ever is a problem with the electrical on that appliance. I hope this wasn't too confusing, the answer is you will need to wire the oven properly by adding another wire if you want to be completely safe and within electrical codes.
Dec 06, 2007 | Frigidaire FEB24S2AB Single Oven
Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
53 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
